Ive put bad diesel in it i think once or twice and ive noticed a big lack in power after this ive put an`injection cleaner into it and tried to blow it out down the motorway but still the same
Mr Allan first thing you must do is to renew the fuel filter,check if there is any other filters and then if you still have any old fuel in tank drain it,fill it up with a clean diesel and my personal advice as an automotive engineer try what I do personally,ask from a petrol station if they sell- " TWO STROKE OIL " yes is the oil use in mixing with petrol for mopped motorcycles. Use 250ml in tank full of diesel ,-full tank to empty -before light comes on and re-use again 250ml for another full tank and continued for four times. It is also good to do this even for two times filling every two months,. Two Stroke Oil has the power to clean and lubricate the feeding system of a diesel engine also treats the fuel injectors even when you might hear them working rough. It is like a cough medicine. Try it and let me know.
SOURCE: My car lacks power whil ein gear driving and will
Yes,do that,and change the fuel filter,and do a tune up on it too.
SOURCE: X type turbo diesel. When
use a fuel additive to clean fuel lines and injectors,redexe/wynns,one can to 1/2 tank fuel.then see if you need to do any other work.....
Testimonial: "Thanks a lot! will try this, I thought I might need a new turbo! Great stuff."
SOURCE: Toyota d4d avensis lack of power black smoke ,
black smoke is one indication of a motor running very rich...the sensor that has the most control of this will be the the airflow meter...ive seen black smoke coming from all types of cars when these go bad
