Question about Pentax Optio 33WR Digital Camera
Optio 33WR screen issues
I recently used the camera functions to delete all the images on the memory card (usually I do this with the the computer). Since then, it won't take pictures. Back display shows no image, but only a window of light that runs vertically for about 25 % of the screen, and moves as your move the camera relative to the ambient light. I have checked every setting I can, swapped memory cards, removed batter (it's new) , etc. Still no luck. It has had no shocks, drops, or bad treatment.
I fear that in navigating the menu, I inadvertently hit some global setting that nuked it. Any clues, are greatly appreciated.
Many thanks,
Bruce in Antarctica
5 Suggested Answers
Quack
  • 542 Answers
SOURCE: Bug in the Optio S40?
I've never had my S40 "wipe" any of my SD cards, but I have had it not recognize the card as readable when I first insert it. Every time that has happened, reinserting the card once or twice has solved the problem.
Posted on Sep 08, 2005
Quack
  • 542 Answers
SOURCE: Optio 33WR SD Card Capacity
Don't own the camera - but the figures indicate the 512 should hold a max of 250. Please have a look at the following: http://www.imaging-resource.com/PRODS/O33WR/33WRDATA.HTM
SOURCE: Memory card locked!??
What you need to do is take out the card, and on the side of it there should be a little gray thing which can slide up and down. It needs to be slid all the way up. I hope this helps!!
Posted on Mar 22, 2008
lock123
  • 6831 Answers
SOURCE: Optio E10
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Nov 24, 2010
Pentax Optio M30- How do I transfer pictures from the internal memory onto an SD card??
this model not support it, To do that, you need to connect to pc and transfer it. As long you inserted the SD card, IT will use memory from SD card and not display image, video from built in memory.
if you want to delete file in built in memory, you need to remove memory card.
check this :
PENTAX OPTIO M30
May 09, 2011 | Pentax Optio M30 Digital Camera
I have an optio33wr digital camer. The memory card accidentally got locked. How do I unlock it?
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 24, 2010 | Pentax Optio 33WR Digital Camera
Internal Memory on Camera wont allow format
You usually have to take out the SD card, close the door and then delete images in camera in the normal way (press delete button in play mode, when confirmation dialogue appears, press delete button again, select >delete all< and press OK). Most cameras default to the memory card when one is inserted, that's why you have to take it out to delete data from the internal memory.
Hope that helps
Aug 01, 2010 | Pentax Optio M60 Digital Camera
SD memory prohibits functioning of Pentax E30
I know that usually, you should format the card for the camera that your going to use. Try formating it in the camera and see if that works. Let me know if I can do anything else for you,
Rob
Feb 22, 2009 | Pentax Optio E30 Digital Camera
Memory card is full and when I plug in the USB cord and turn on the camera I get a message that my device is not connected or is busy, or that it contains no pictures!!
Causes of memory card corruption
  • Turning off a camera before an image is completely written to the memory card.
  • Removing the memory card from a camera while an image is being written to the card.
  • Removing the card from a memory card reader while files are still being transferred to a computer.
  • Batteries conking out as files are being transfered directly from the camera to a computer. Note: always make sure you have fully charged batteries before transferring images.
  • Removing the card from a card reader while folders and files from the card are open on a computer.
  • Opening, deleting, renaming or moving files on the card while its contents are open on a computer.
  • Using a memory card which has not been formatted in the camera. Use the delete/erase function when needed, however a card should be regularly formatted.
  • Formatting a card in a computer instead of the camera.
  • Inserting a second memory card into a card reader before closing and removing the first when viewing images on the card from a computer.
  • Taking photos when camera batteries are nearly empty.
  • Taking photos too rapidly so the camera can not complete writing one image before starting the next.
  • Continually shooting and deleting, shooting and deleting images when the card is full.
  • Letting a memory card get too full before downloading the images to a computer or storage device. Cards that are too full may overwrite the card headers.
  • Using a memory card from one camera in a different camera without formatting it in the new camera first.
Feb 28, 2008 | Cameras
Optio S5i
Read the manual- you have somehow initiated this feature to prevent removal of existing images.
There may be a key/padlock symbol button on the body or a similiar instruction on the menu screen.
There is usually a comprehensive manual in PDF on the disk to supplement the booklet.
Dec 20, 2007 | Pentax Optio S5i Digital Camera
The card locked usually means 'protected' Check out the manual for image protection - on/off. Or put card back into computer and delete[NOT FORMAT] from there. A more comprehensive manual is usually found the the CD that came with the camera
Jul 05, 2007 | Pentax Optio E10 Digital Camera
Images speed & capacity
You can read all about continuous shooting in the manual, here: http://www.fixya.com/BrowseManual.aspx?mnlid=2575&prdid=153915&__PAGED_=58
Sep 08, 2005 | Pentax Optio 33WR Digital Camera
Somewhere I read to be careful using cardreaders, using your memory card in different camera's and managing your card via the computer. Appearantly all of these can corrupt your card. The advice is to hook your camera directly up to your computer to transfer images and perhaps it is wise to erase images through the camera's menu instead of via the transfer program of the computer. Try formatting the card using the camera's menu and see if the problem persists.
Sep 08, 2005 | Pentax Optio S40 Digital Camera
Pentax Optio 33WR Digital Camera Logo
44 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Mohamed Ismail
Mohamed Ismail
Are you a Pentax Camera Expert? Answer questions, earn points and help others
