Question about Dishwashers
My dishwasher makes noises when filling, why?
The pipes knock.
    Sergeant:
    Champion:
  • 338 Answers
You need to replace your fill valve. guaranteed fix
Posted on Dec 25, 2008
My dishwasher is making a loud noise when water goes through the pipes
Do you mean when it is emptying out, or when it is filling? When pumping out, there is a pipe in the bottom (under the screen) that sometimes gets a lump stuck in it. You probably need to take that out and clear it -- then re-install.
Jan 06, 2014 | Miele Advanta G2170SCSF Dishwasher
Srs45e02
How about a malfunctioning/defective fill control valve?
Sep 07, 2012 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
It will not fill with cold water. Could it be due to the cold weather - the cold water pipe frozen. Kitchen is very cold (pipe is next to an east facing wall). Same pipe also fills the dishwasher,...
If youve taken the fill hose off and checked for running water out of tap and its not coming through, your machine is ok, you have a water fault.the humming is the water valve working.
Dec 21, 2010 | Washing Machines
Pipe knocking on dishwasher when taking water from cold fill
probably cold water feed pipe knocking when the solenoid opens and shuts
Jan 20, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Plumbing makes loud intermitant knocking noise.
Does this happen when yo turn of the water from the tap or shower, right when you turn it off? If so, that is called 'water hammer'and is caused by too high water pressure. It's shaking the pipes when you suddenly shut it off. Turn the water of 'slowly' and see what happens, it goes away.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Nov 08, 2009 | Kuppersbusch 24 in. IG6344 Built-In...
Vibrating dishwasher pipes
a plumber needs to install a anti knock pipe at the valve under the sink ....this should stop the vibes ...should only cost about 50 -75 bucks ...depending on the per hour rate of the plumber
Jul 26, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Loud humming noise when dishwasher is filling with water
sounds like it could be furring in your water piping. may need a plumber to check it out.
Mar 16, 2009 | Dishwashers
Need help with GE triton
That knocking noise is probably coming from your water line, and that happens when there is some kind of a ripple/wave effect when the water goes into your dishwasher (DW) thru the inlet/fill water valve. First turn your hot water valve off, underneath the sink coming from the wall and it usually is also going to your kitchen faucet. Then turn the electricity off by locating the breaker to the DW line and turning it off, or if it is plugged in an outlet under your sink, just unplug it. Then take the kick toe panel (panel with 2 or 4, 1/4" or philips screws) from the bottom of the dishwasher. You will then see the water hose, or could be a copper pipe, going into the valve (will have a selenoide, cylinder shape on top and have 2 wires plugged in to it). Unscrew the hose/pipe from the water valve and get a small wide bucket or pot and aim the hose/pipe to it. Slowly have someone open the water valve from under the sink while you hold it in the bucket/pot. If you hear the knocking again, you will need a plumber to check the pipes, hoses and water valve at your wall. If you don't here the knocking noise, just replace the dishwasher inlet/fill water valve part # 785330. http://www.repairclinic.com/0080.asp. Please post back.
Oct 07, 2006 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwashers Logo
67 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
