Question about Konica Minolta magicolor 2300DL Laser Printer
How do you replace the black toner cartridge
I can see the blue cartridge in the slot to remove it but how do I rotate it around to get the black cartridge in the removal slot?
  • 126 Answers
You will need to call our technical support line on 0845 20 20 118
Posted on Dec 24, 2008
I have a Konica Minolta Magicolor 1650en. When replacing color toner, I managed to install magenta and yellow, following menu prompts, but when I try to install Cyan, the cartridge doesn't...
I had a similar problem in that after changing one of the cartridges (I bought a whole set), the message "cannot rotate cartridge" appeared. I tried pressing the cartridge in more firmly and may have caused the carousel to rotate a little in the process. I cycled the power which seemed to clear the error message and allowed me to select the next cartridge to change, but upon opening the door to change it, was unable to remove the old one as it was positioned a little too high. I eventually cleared the problem by manually rotating the carousel by pressing in and holding the carousel release (see arrow) mmgazette.jpgwhile rotating the carousel downward slightly, to line the cartridge up as it appears in this picture. Then powered it back up and was able to do the normal cartridge replacement procedure for the remaining cartridges without further error messages.
Jun 11, 2011 | Computers & Internet
Dell 3000cn Printer
I think the following instructions are quite clear. In any case, before giving an inappropriate rating pleas contact us. Thanks for trying rating should be used only for unhelpful solutions and I do not think these here are the cases. Please follow the instructions from point six:
6 - Connect the printer to power and turn it on
7 - The toner cartridge carrier rotates and then stops. After confirming
the Insert Black Toner (K) message, open the front door.
8 - Hold the tape on the protective cover and gently pull it forward to
remove the cover from each cartridge slot. You only have to remove the
cover from each toner cartridge slot the first time you use your printer.
Toner will be present on the roller.
9 -
10 - Lift the tab up 90 degrees and pull the toner seal straight off, keeping it
parallel with the toner cartridge.
cf252ec.jpg 11-
To insert the toner cartridge, face the label on the cartridge to the front
and align it with the arrows on the printer. Guide the cartridge until it
snaps into place and then push down the handhold to lock the cartridge
in place.
12 - Close the front door. The toner cartridge carrier rotates to the next
empty slot. When the color of the newly inserted cartridge appears on
the display, followed by the Insert message, insert the next toner
cartridge. Repeat steps 6-11 until all cartridges are installed.
Here is the link to download tha manual:
http://support.dell.com/support/edocs/systems/3100cn/he/placemat/3100cn_setup_diagram.pdf
Hope it had been helpful, let me know if you need further support
Feb 15, 2008 | Dell 3000cn Laser Printer
I ran out of toner so I ordered a new black toner cartridge. It arrived today. I can not find the directions to replace it in the literature I have for the MC 2400 W. How do you replace the toner...
push rotate button until it get to black, pull the handle on the front of the toner and release/remove the old one. Line pegs up with slots and lock in place. close all compartment doors.
Apr 26, 2011 | Konica Minolta magicolor 2400 Laser...
I wish to replace the black toner cartridge in the Dell 3010cn. How do I gain access to it. There is easy access to the cyan cartridge at the moment
if you want to replace black one only you should follow these steps Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier does not rotate).
1. After confirming the Insert Yellow Toner(Y) message, open the front door.
2. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
NOTE: You need to remove the protective cover only the first time that you install the toner.
NOTE: Dispose of the protective cover after you remove it.
NOTE: The protective cover is attached to each toner cartridge mount.
3. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
4. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
5. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
6. Close the front door.
NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly.
7. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
8. Repeat steps 1 through 7 when inserting the remaining cartridges.
plz do rate the solution if got help
Nov 25, 2010 | Dell 3010cn Laser Printer
How do you change out the black toner?
If you can not rotate the toners by using the DISPLAY MENU,
You can rotate them MANUALLY, using a flat head screwdriver or even a key for your car or front door.
Open Front Cover/Door of Printer
Remove Waste Toner Box
Where you see the side of the Blue Cartridge, look to the LEFT and locate a small rectangle with a circle inside it.
Push your car key or flat head screwdriver into this rectangle and the circle will push back and release the lock on the cartridge, holding in with one hand and turning cartridge with the other hand until you get the cartridge you want to replace.
Remove the screwdriver / car key and pull out the empty cartridge and replace with new one.
Replace Waste Toner Box, close front cover/door, switch on and the printer will rotate back itself to it's normally position...... JOB DONE
Jan 19, 2010 | Minolta magicolor 2300W Laser Printer
How do you remove toner cartridge from a Dell 3010cn color laser printer correctly.appears to be stuck trying to remove
This is how to Install or replace the Toner Cartridge.
Cheers!!
Apr 21, 2009 | Dell 3010cn Laser Printer
Black toner replacement will not go into machine
If you cannot install the toner on the a cover
try this solution
close cover a
turn off the printer
open cover b remove the pcu rotate the carousel when the specific toner that you want to replace facing the cover f remove the old toner and replace it with he new one. you will know that the toner is properly placed if the carousel is rotating freely
Oct 02, 2008 | Epson ACULASER CX11NF All-In-One Printer
Cyan toner does not rotate to front to be change
um... Cyan is blue isn't it?
Magenta Pink,
Yellow = Yellow and
Black = black.
Oct 02, 2008 | Dell 3010cn Laser Printer
How to remove the toner cartridges
Close the cover to the machine and make sure you aren't getting any other error messages other than the toner. When the printer is at the ready state press the rotate toner button. You should hear the printer rotate the toner and then the light over the cyan cartridge will come on. Keep pressing the rotate toner button until you get to the color you want to replace. Open the top cover and front door where the KM logo is. You should see the cyan cartridge in place. Pull the cyan tab back toward you. The front part of the toner should release. Now pull the tab and the toner straight up and out of the printer. If you are having problems getting the toner out it is probably not in the correct position. There is a slot on either side of the printer that he back end of the toner cartridge needs to be in before the toner will come out.
Jul 10, 2008 | Minolta magicolor 2400W Laser Printer
Installing new black print cartridge
Manually Removing Toner for magicolor 2400W
1.  Hold down the Cancel button for 10 seconds or longer.
2.  With the Cancel button still held down, also simultaneously hold down the Rotate Toner button for 10 seconds or longer.
3.  When all LED indicators are blinking rapidly, release both the Cancel and Rotate Toner buttons.
4.  Then hold down the Rotate Toner button again for another 10 seconds or longer.
5.  The Cyan toner cartridge moves into the proper position, so it can be removed.
6.  Remove and/or replace the Toner Cartridge if necessary.
7.  Open and close the covers. Each time you do this, another toner cartridge moves into the proper position, so it can be removed and/or replaced (in this order: cyan, black, yellow, magenta).
The link is located here
Oct 21, 2007 | Minolta magicolor 2400W Laser Printer
Konica Minolta magicolor 2300DL Laser Printer Logo
59 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
