Question about Jenn-Air JCD2389G Side by Side Refrigerator
Jenn-Air Refrigerator JSD2789AES broken shelf support studs
Several of the plastic studs attached to the inside walls of the refrigerator compartment which support the shelves have broken off. I can't find these listed as Jenn-Air parts. Can these be fixed/replaced? If so, what is the part number?
Thanks.
Jim Vahl
  • onegrillgirl Jan 14, 2009
    ditto
  • Anonymous Apr 06, 2009
    same problem in my refrigerator (identical model) - the attachments for the cabinet containing my crisper drawers are what broke on mine, and they appear to have been a part of the inner refrigerator liner, not a separate replaceable part. any solutions would be appreciated.
Part number is AP4069509 this fridge is such ****! i still need three parts
Posted on Sep 25, 2010
Fridge compartments too warm
There are several possibilities on your model. Compressor start components and Adaptive defrost Control. I would like you to pull away from wall and unplug , rempove the cover over compressor and feel the compressor to tell me if warm, hot or too hot to keep your hand there, Waiting for your response, Sea Breeze
Mar 27, 2010 | Jenn-Air JCD2389G Side by Side...
Kenmore Cold spot refrigerator model 106 70182001 leaking inside in the back of the refrigerator. Having to keep bowls in the back of the top shelf. How can I fix this?
Your defrost drain in the frezer is cloged. Every day when your refrig sellf defrosts the water should drain into a hole that leads to a tube wich drains the water to a pan under the refrig. You need to turn offrefrig and remove frezer floor and rear wall and clean out hole and tube with hot water.
Dec 12, 2009 | Cars & Trucks
Refigirator is freezing my liquids on top shelf only
If its anything like a GE refrigerator, there is a flapper valve between the freezer and refrigerator that controls the temp of the refrigerator compartment. There should be a plastic shroud at the top refrigerator compartment against the freezer wall. Remove it and see if the flapper is broken. Usually you can epoxy the flapper or if not, buy a new part.
Keep in mind my experience is with a GE, but I think its pretty much the same machine.
Feb 28, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Can't remove broken refrigerator shelf studs
I had the same problem and used a pair of pliers to twist the broken shelf stud 90 degrees and it pulled right out with minimal force.
Can you respond with the link of where you found the relacement studs as I haven't been able to find one yet. Thanks.
Feb 14, 2009 | Refrigerators
Broken refrigerator drawer support pin
I have a Kenmore 2 door,freezer on bottom, mod# 795.77309600,the shelf that holds the crisper draws cracks,front & back corners, also the back,middle. this is the 2nd time for me. Is there a solution??
Nov 24, 2008 | Refrigerators
JENN-AIR REFRIDGERATOR JSD2789AES
HI thanks for your question. remove cover to the compressor relay, check for burnt wires. clean all coils. replace the relay. thanks
Aug 30, 2008 | GE GSS20IEP Side by Side Refrigerator
Jenn Air model JCB2388AR, about 11 years old
We got heavy duty velcro and put it on the back of the bins. Works like a charm
Aug 08, 2008 | Jenn-Air 25.6 cu. ft. Side-By-Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
366 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Jose Pino
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
