Question about Sony Handycam DCR-PC100 Mini DV Digital Camcorder
Sony DCR-PC100 does not eject (well not really!)
This is weird:
I had a DCR-PC100 with a jammed tape inside (and C31:30 error). When trying to eject the mechanis would do some noise, ejecting the tape half way then taking it back. all the normal trick/reset/unpower did not work.
I got hold of service manual, opened the camera, _removed_ the mechanism put it on a test bench and operated the eject motor with a 4.5 V power supply. which immediately resulted in a "normal"  ejection. The tape was out of the cassette but could be manually rewound in so all OK up to here.
I tried few times using the 4.5 V to verify I could operate the mechanism "standalone" both loading and unloading so the mechanism works fine outside. but  when the mechansim is put back in the camera, any attempt to operate the button to open the tape compartment results in a bit of noise, wirling noise but no movement of the tape compartment (not even half way).
Any suggestion before I dismantle it once again ?
Thanks
    Problem Solver:
  • 10 Answers
Don't think this is a complete solution, but it might help. Try checking out the buttons on the camera. I've got one of those same cameras but my problem is the ribbon cable in the cassette carrier broke and I'm on the hunt for a new one, and a service manual. By the way, how about emailing a copy of the service manual to me at ljmagnuson@aol.com. Thanks. I might be able to help further with a copy of that.
Posted on Feb 24, 2009
Sony handycam ccd-trv59e C32 10
The camera's firmware has sensed a jam or too slow rotation in the cassette's take-up roller. Really difficult to overcome. The tape may already be snarled round a roller, but is certainly in the "loaded" tape path. I've had this and had to disassemble the whole tape transport mechanism - which is really difficult - after trying unsuccessfully to drive the unload motor from an external 6v power supply. Sometimes a really hard sideways bang on the camera can free up the roller enough to let it rotate a bit, satisfy the motion sensor and allow an eject.
Jul 07, 2014 | Sony Handycam DCR-TRV520 Digital Camcorder
It wont eject or play makes lound noise for a min
There is a broken plastic part on the cassette. Needs to be replaced.
Mostly caused by improper position of the tape and camera jam(tape jam)
needs sony camera technician who can replace the part inside the cassette.
Apr 03, 2010 | Sony Handycam DCR-TRV310 Digital Camcorder
Sony DCR-HC28E Camcorder tape won't eject
I\'ve got a Sony DCR-HC28E Camcorder power switch off position but it's turn on automatic when I put power AC adaptor in DC inlet and battery not charg
Dec 29, 2009 | Sony DCR-HC28E Camcorder
I have a Sony DCR-TRV250 Digital Handycam Camcorder. Currently a tape is stuck in it and the camcorder won't eject it. The tape unit comes out but won't open.
I got the tape to eject by removing the battery from the camcorder, putting it back on so that the tape would go back inside the camera. Then I had the tape eject again. Several times the tape would not be ejected but I repeated my steps until the camera released the tape.
Nov 16, 2009 | Sony Handycam DCR-TRV280 Digital Camcorder
Cannot find way to eject tapecassette
Check eject lever near battery, press it downward to open tape compartment, take out old tape and put new tape, close tape door and let it go inside by itself. Close tape compartment.
Below image will help you to locate eject button/ lever in DCR-HC18E camcorder.
Thanks.
Sep 20, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
Mini DVD tape will not eject.
i read in the manual that if a tape gets stuck to take off the battery and connect the AC line. surprisingly it worked.
Apr 05, 2009 | Sony Handycam DCR-PC100 Mini DV Digital...
Sony Cam DCR-PC100, "eats" tapes and when ejecting, pulls tape
The take up spool is not working upon ejecting. I would take it to a Sony Service Centre for service.
Jun 03, 2017 | Sony Handycam CCD-TRV43 Camcorder
Sony Handycam DCR-TRV330 Digital-8 won't calibrate tapes to be able to view
hi there. i just actually had this problem right now. and heres how i fixed it :) it had the error so i took out the tape left it ejected for about 5 seconds. then put the tape back. it read for a little then errored again so it was close. next what i did is plugged the camera in (last time this error happened i plugged in the power and it fixed it) still no fix so i took off the battery waited 5 seconds then put it back on. after that i ejected the tape again and re put it in and it worked! you could try anyone of those things. and usually they work for me. maybe it has something to do with the cameras being old.
Sep 16, 2008 | Sony Handycam DCR-TRV330 Digital Camcorder
Problem loading tape
the tape may be the wrong sort for you particular camera or there could be falty wiring in the display box i suggest that you get a specialist to help this isn't really my cup of tea.
Jun 27, 2008 | Sony Handycam DCR-PC100 Mini DV Digital...
Opening the tape compartment
something may be jammed in one of the hinges of the compartment door.
Jun 26, 2008 | Sony Handycam DCR-PC100 Mini DV Digital...
Sony Handycam DCR-PC100 Mini DV Digital Camcorder Logo
440 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
