Question about HP Compaq nx9010
I can't shut my notebook off
I have tried to turn my notebook off but I am getting an error message - The instruction at 0x1240b767referenced memory at 0x00000000. The memory could not be "read"
Click on OK to terminate the program
Click on CANCEL to debug the program
None of these options work. When I try to X out nothing happens. The error message remains on screen.
HELP!
  • 126 Answers
You will need to call our technical support line on 0845 20 20 118
Posted on Dec 24, 2008
Cant set up
You need to insert the CD/DVD that came with your computer and boot from that.
Apr 24, 2013 | Dell Latitude D600 Notebook
Aspire One netbook BSoD
Those error codes don't really mean very much to the general consumer, but blue screens of deaths are caused by bad RAM memory in your computer, not viruses. I'm going to take a guess that your computer is either several years old and/or it constantly get quite warm? Heat can shorten the life of computer components by quite a bit. You may need to get one of your RAM cards replaced to solve this issue.
There's a free program called Memtest86 that you can run to determine if this is the case. It will scan all your memory and look for bad sectors. You can download it here: http://www.memtest86.com/ and burn it to a CD. What it does is create a bootable CD that will execute the program as the computer turns on to scan all the memory. There are full instructions on their website. The process can take an hour or two depending on how much memory your computer has, and if it turns up any bad sectors then you know what your problem is.
A computer can run with bad sectors in the memory, but it makes it unstable that it will keep bluescreening, so if you have bad sectors in your memory it might be better just to replace the RAM. Luckily, this isn't too expensive. For instance, if your computer has 4GB of memory, it probably has 2 2GB RAM cards installed. You can get a 2GB replacement notebook memory for, I'd say $30 or $40. Installing RAM is very simple, and if you're willing to install it yourself, it won't cost you more than that.
Dec 06, 2012 | Acer Aspire One Netbook 8.9" Notebook
My computer wont always turn and it shuts down on its own it desplays a blue screen an also it keeps tellin me to reseat the memorey
Here are the instructions for re-seating the memory:
http://support.dell.com/support/edocs/systems/ins1525/en/SM/memory.htm#wp1181008
make sure that power and battery are disconnected and hold power button for 10 seconds to discharge any stored power before opening system to re-seat the memory.
If you have 2 memory modules, you might try re-seating 1st if issues still occur, then try the modules one at a time. You will also get bios notifications of amount of memory changing, just press F2 to enter BIOS then exit to clear the error any time the amount of RAM in the system is reduced or inscreased.
Jul 17, 2011 | Dell Inspiron 1525 Notebook
Laptop shuts down 15 seconds after power up
Try taking the battery out during power up.
Are you seeing any messages on screen?
If is still does not work with just the power cable, take out the memory and see if you get a beep error code. Then put one memory back in (if it has two just use one).
Apr 12, 2011 | Dell Inspiron 6000 Notebook
Laptop shut down error
The DDR2 RAM memory has failed and must be replaced.
You can get a new one from here
http://www.edgetechcorp.com/memory/upgrade.asp?cid=28784
Jul 09, 2010 | Dell Latitude D410 Notebook
Error message when shutting down
bring it to best buy geek squad ask them
Sep 24, 2009 | Dell Dimension E310 PC Desktop
Error message
I would suspect you have some bad memory. The error message says it can't write to some location, and that normally means the memory there is faulty. It might also mean a problem with the motherboard, but that's unlikely. Try removing the memory modules, clean their contacts by gently rubbing with a pencil eraser, and then reseat them in their sockets so they latch in place. If the problem continues, switch the modules if you have more than one installed. If the memory is the trouble, you will probably have other errors. But if you still get the same error message on shutdown, the motherboard is the culprit.
May 15, 2009 | Toshiba Satellite A100-S8111TD Notebook
The instruction at 0x6cb2ele0 reference memory at 0x6cb2ele0.
$Swap you RAM to another slot, move stick one to the second slot and stick 2 to the first slot, They try the same secenairo. If you do NOT get the SAME message, swap it back, see if you get the message. IF SO, ONE of the chips on one of the RAM sticks if bad and you need to replace the one RAM that is bad. Reply to this post to find out how to isolate the Stick with the BAD CHIP!!!
Mar 27, 2009 | Microsoft Windows Vista Ultimate Edition
Error messages on Vista Home Premium
uninstall the old Zone Alarm and install the latest version.
Mar 18, 2009 | HP Pavilion dv2000t Notebook
HP Compaq nx9010 Logo
42 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
