Question about HP Compaq 6710b Notebook
No power at 19.5 VDC jack
Was on battery power. Switched to off. Got to airport to recharge...nothing. Power supply is good. Computer does not recognize that power is available.
  • antwarby Jan 09, 2009
    power supply is good but no power going through at all.
  • Anonymous Feb 17, 2009
    Exact Same problem. had BEst Buy check the power cable, and all is good. The DC input is faulty. It took about 15 minutes of reseating the power supply for it to be recognized.
  • 126 Answers
You will need to call our technical support line on 0845 20 20 118. Click Here for help
Posted on Dec 24, 2008
How do i turn on a compaq ps-7231 power supply?
Pin Name Color
Description 1 3.3V Orange +3.3 VDC 2 3.3V Orange +3.3 VDC 3 COM Black Ground 4 5V Red +5 VDC 5 COM Black Ground 6 5V Red +5 VDC 7 COM Black Ground 8 PWR_OK Gray Power Ok is a status signal generated by the power supply to notify the computer that the DC operating voltages are within the ranges required for proper computer operation (+5 VDC when power is Ok) 9 5VSB Purple +5 VDC Standby Voltage (max 10mA, max 2A in ATX 2.2 spec) 10 12V Yellow +12 VDC 11 12V Yellow +12 VDC 12 3.3V Orange +3.3 VDC 13 3.3V Orange +3.3 VDC. ATX V2.3 / EPS12V V2.92 both define that the PSU has to use remote sensing to compensate cable drops on the 3.3V line. Because of this there is an additional brown cable crimped together with the orange cable either to pin 13 (ATX) or pin 1 (EPS12V). 14 -12V Blue -12 VDC 15 COM Black Ground 16 /PS_ON Green Power Supply On (active low). Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF. 17 COM Black Ground 18 COM Black Ground 19 COM Black Ground 20 -5V White -5 VDC (this is optional on newer ATX-2 supplies, it is for use with older AT class expansion cards and can be omitted on newer units) 21 +5V Red +5 VDC 22 +5V Red +5 VDC 23 +5V Red +5 VDC 24 COM Black Ground /PSON activated by pressing and releasing the power button while the power supply is in standby mode. Activating /PSON connects the power supply's /PSON input to ground, thereby switching the power supply to full-on condition.
Feb 26, 2015 | Compaq Computers & Internet
My aceraspire4330 wont power on
you can try the power system check by doing the following:
To verify the symptom of the problem, power on the computer using each of the following power sources:
1. Remove the battery pack.
2. Connect the power adapter and check that power is supplied.
3. Disconnect the power adapter and install the charged battery pack; then check that power is supplied by
the battery pack.
If you suspect a power problem, see the appropriate power supply check in the following list:
"Check the Power Adapter"
"Check the Battery Pack"
Unplug the power adapter cable from the computer and measure the output voltage at the plug of the power
adapter cable. See the following figure
1. If the voltage is not correct, replace the power adapter.
2. If the voltage is within the range, do the following:
* Replace the System board.
* If the voltage is not correct, go to the next step.
NOTE: An audible noise from the power adapter does not always indicate a defect.
3. If the power-on indicator does not light up, check the power cord of the power adapter for correct
continuity and installation.
4. If the operational charge does not work, see "Check the Battery Pack"
Pin 1: +19 to +20.5V (Centre pin)
Pin 2: 0V, Ground (Shielding / Surround)
To check the battery pack, do the following:
From Software:
1. Check out the Power Management in control Panel
2. In Power Meter, confirm that if the parameters shown in the screen for Current Power Source and Total Battery Power Remaining are correct.
3. Repeat the steps 1 and 2, for both battery and adapter.
4. This helps you identify first the problem is on recharging or discharging.
From Hardware:
1. Power off the computer.
2. Remove the battery pack and measure the voltage between battery terminals 1(+) and 6(ground).
(Terminal 1 is closest to the edge, Terminal 6 is closest to centre)
3. If the voltage is still less than 7.5 Vdc after recharging, replace the battery.
To check the battery charge operation, use a discharged battery pack or a battery pack that has less than 50% of the total power remaining when installed in the computer. If the battery status indicator does not light up, remove the battery pack and let it return to room temperature.
Re-install the battery pack.
If the charge indicator still does not light up, replace the battery pack. If the charge indicator still does not light up, replace the DC/DC charger board.
Jan 20, 2015 | Acer Aspire One PC Notebook
Compaq CQ1-1225 AIO Wont Start at all. Removed all components
Suggestions;
Anti-Static wrist strap connected to ground source, and your wrist;
1) The jack your AC adapter plugs into on the motherboard, is the DC Power Jack.
Motherboard out of case, power to motherboard, take your multimeter and see if you are getting 19 VDC at the DC Power Jack's positive solder joint, on motherboard.
The center pin of the jack is Positive. (The inner cylindrical shell is Negative)
Follow the DC Power Jack's positive pin from the Center of the jack, to the motherboard.
You probably won't be able to touch your meter's Positive (Red) probe, to the DC Power Jack's positive pin under the jack; so touch it's solder joint on the opposite side of the motherboard.
(DC Power Jack should be soldered close to the motherboard, is why)
Of course also touch the Negative lead, (Black probe), of your meter, to the Negative, (Ground) solder joint for the DC Power Jack.
Getting 19 volts DC?
See if there is a cracked solder joint, for any of the DC Power Jack's pin connections to the motherboard.
ANY perceptible movement of the DC Power Jack on the motherboard, indicates a bad power jack, and may indicate a broken/cracked solder joint.
Center pin of DC Power Jack is loose? Bad DC Power Jack. Replace.
2) DC Power Jack is determined to be in good repair? No cracked/broken solder joints?
The next components in the power circuit on the motherboard, leading From the power jack, are P. MOSFET's.
Power MOSFET.
Power MOSFET Wikipedia the free encyclopedia
More information using a prior solution,
Dv6000 power light does not come on any more
Check the links given.
3) The last thing that concerns me, although I probably should have listed it first; is the AC adapter you are using.
Concern is that it doesn't have the 'intelligent chipset' that matches the Compaq CQ1-1225 All-In-One desktop PC's circuitry.
AC Adapter For Compaq Presario All in One CQ1 1225 Desktop PC Charger...
Just my thoughts..........
Regards,
joecoolvette
Jan 15, 2015 | HP Computers & Internet
I want to convert this power supply for use with a battery charger for model aircraft. I need to know the color codes for the wires and also the pinout and which wire is the power on.
Pin Name Color Description
3 COM Black Ground
4 5V Red +5 VDC
5 COM Black Ground
6 5V Red +5 VDC
7 COM Black Ground
8 PWR_OK Gray Power Ok (is a status signal generated by the power supply to notify the computer that the DC operating voltages are within the ranges required for proper computer operation)
9 5VSB Purple +5 VDC Standby Voltage (max 10mA)
11 3.3V Orange +3.3 VDC
12 -12V Blue -12 VDC
13 COM Black Ground
14 /PS_ON Green Power Supply On (active low). Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF.
15 COM Black Ground
16 COM Black Ground
17 COM Black Ground
18 -5V White -5 VDC
19 5V Red +5 VDC
20 5V Red +5 VDC
18 AWG is recommended for all wires except pin 11, which should be 22 AWG. For 300W configurations 16 AWG is recommended.
There are several ATX variants.
Hope this helps.
If this helps you resolve your problem, please
consider giving me a rating of 4.It will help me as well. Thank you.
Nov 26, 2010 | Compaq (243890-001) 250-Watt Power Supply
My charger won't charge. Computer detects plugged in but no charge
This is usually caused by an old or defective battery or possibly the power supply is a few volts too low to activate the charge indicator. It might be charging but not letting you know.
Try to run it off battery for a while (look at the battery life) and then plug it back to for a while then unplug it again to see if the battery life if higher than before.
To check the power supply you will need a volt meter that can read at least 20 vdc (most power supplies are 19 vdc). Put one lead of the meter on the inside of the plug that goes into the computer and the other pin on the outer silver part while the power supply is plugged into the wall outlet. You should read close to what the Output Voltage on the power supply says which should be on the sticker on the back or side of the black box part of the power supply.
Mar 10, 2010 | Dell Inspiron 1545 Notebook
Acer Aspire 3690 Laptop is dead
You may have a broken power jack in the laptop. Inspect the power jack and see if the center pin moves at all. It should be fairly solid. If you find a bad jack your local repair shop may be able to repair it or you can get a jack from Ebay and solder it yourself.
I hope this helps,
Buddy
www.ccl-la.com
Corporate Computer
Jun 20, 2009 | Computers & Internet
Yes this is a good list of the voltages to be expected from a newer power supply on just the main header
Apr 01, 2009 | HP Compaq dc7100 PC Desktop
Toshiba Satellite no power
replace only the power jack and clean the power supply board with some alcohol...you can find the jack in some electronic shop..
Jan 04, 2009 | Toshiba Satellite M45-S169 Notebook
1212hr power supply
The device runs on 5 VDC. There was an optional adapter available that used the keyboard output, that simply tapped the GND & +5 VDC. On the jack, the interior is +5, the outer contact is GND. The easiest way to power the device is to tap into a free line from your computer power supply. Alternatively, a transformer with 5 VDC 100 mA output should do the trick.
Apr 03, 2007 | Genius NewSketch 1212HR (K9436401)
HP Compaq 6710b Notebook Logo
90 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
