What the heck is the pink wire for? Or the brown one? In my car...'97 Toyota Camry LE Sedan....Or the blue w/ yellow stripe, or the plain blue....or any of them? I just want to hook this thing up....i've gone a month w/o music and its making me crazy. please help.
Go to future shop and buy the 14.99 wire hookup and it will take prolly 5 seconds i frigged around prolly took me a half hour and now when i wanna hook up another cd player later on it will b a pain in the arse again so just spend the 14.99 and save urself the time
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink/Blue
Car Stereo Amplifier Location: Located to the right of the glovebox behind the passenger side of the dash.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Left Front Tweeter: Powered by the same wires as the left front speaker.
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Right Front Tweeter: Powered by the same wires as the right front speaker.
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
here to your 1997 Toyota Camry.
Radio Constant 12V+ Wire: Blue/Yellow Radio Switched 12V+ Wire: Gray Radio Ground Wire: Brown Radio Illumination Wire: Dark Green Dimmer Wire: White/Green Antenna Trigger Wire: None Front Speaker Size: 6 1/2′ Front Speaker Location: Doors Left Front Speaker Wire (+): Pink Left Front Speaker Wire (-): Purple Right Front Speaker Wire (+): Green Right Front Speaker Wire (-): Blue Rear Speaker Size: 6′ x 9′ Rear Speaker Location: Rear Deck Left Rear Speaker Wire (+): Black Left Rear Speaker Wire (-): Yellow Right Rear Speaker Wire (+): Red Right Rear Speaker Wire (-): White
1990 Toyota Camry Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/Yellow Radio Switched 12V+ Wire: Gray Radio Ground Wire: Brown Radio Illumination Wire: Green Radio Dimmer Wire: N/A Radio Power Antenna Trigger Wire: Black/Red Radio Amplifier Turn On Trigger Wire: N/A Front Speakers Size: 3 1/2? Front Speakers Location: Dash Left Front Speaker Wire (+): Pink Left Front Speaker Wire (-): Purple Right Front Speaker Wire (+): Light Green Right Front Speaker Wire (-): Blue Rear Speakers Size: 5 1/4? Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): Black Left Rear Speaker Wire (-): Yellow Right Rear Speaker Wire (+): Red Right Rear Speaker Wire (-): White
1995 Toyota Camry Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/Yellow Radio Switched 12V+ Wire: Gray Radio Ground Wire: Brown Radio Illumination Wire: Green Radio Dimmer Wire: N/A Radio Antenna Trigger Wire: Black/Red Radio Amp Trigger Wire: None Front Speakers Size: 5 1/4′ Front Speakers Location: Doors Left Front Speaker Wire (+): Pink Left Front Speaker Wire (-): Purple Right Front Speaker Wire (+): Light Green Right Front Speaker Wire (-): Blue Rear Speakers Size: 6′ x 9′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): Black Left Rear Speaker Wire (-): Yellow Right Rear Speaker Wire (+): Red Right Rear Speaker Wire (-): White
Larger harness: Green: front right speaker (+)
Pink: front left speaker (+)
Grey: +12V only when ignition switch is at ON or ACC
Blue with yellow stripe: +12V, always on
Blue: front right speaker (-)
Violet: front left speaker (-)
Brown: ground
Smaller harness:
Red: rear right speaker (+)
Black: rear left speaker (+)
White: rear right speaker (-)
Yellow: rear left speaker (-)
Constant 12V+
Blue/Yellow
Switched 12V+
Gray
Ground
Brown
Illumination
+ Green
Dimmer
n/a
Antenna Trigger
Black/Red
Antenna
Driver's Pillar
Front Speakers
3 1/2" Dash
Left Front (+)
Pink
Left Front (-)
Purple
Right Front (+)
Light Green
Right Front (-)
Blue
Rear Speakers
5 1/4" Rear Deck
Left Rear (+)
Black
Left Rear (-)
Yellow
Right Rear (+)
Red
Right Rear (-)
White
Here are the correct factory radio wire colors with definitions.
Car Radio Battery Constant 12v+ Wire: Blue/Yellow Car Radio Accessory Switched 12v+ Wire: Gray Car Radio Ground Wire: Brown Car Radio Illumination Wire: Green Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: Black/Red Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: 6 1/2′ Car Audio Front Speakers Location: Doors Left Front Speaker Positive Wire (+): Pink Left Front Speaker Negative Wire (-): Purple Right Front Speaker Positive Wire (+): Green Right Front Speaker Negative Wire (-): Blue Car Audio Rear Speakers Size: 6 1/2′ Car Audio Rear Speakers Location: Side Panels Left Rear Speaker Positive Wire (+): Black Left Rear Speaker Negative Wire (-): Yellow Right Rear Speaker Positive Wire (+): Red Right Rear Speaker Negative Wire (-): White
