Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Does infrequent use of the flash drive cause it to lose data? And if so, how often must it be plugged into the usb in order for this not to happen, or how long can I go without using it and losing it? Will it work again if the files and folders are copied back into it?
  • 126 Answers
You should not be loosing data from a memory card in your lifetime.
Before disconnecting there is a correct removal way. You go to the bottom right corner of the screen and click disconnect on the drive icon.
If you are loosing data get a new stick or check the port on the system you are using as this can cause corruptions.
You can also run a clean on the stick by right clicking on the drive and going into properties
Posted on Dec 24, 2008
Hi , My san disk 4gb cruzer micro flash drive has the LED on when i plug it to any computer but doesn't show up on My Computer , Disk management or Device manager . I have tried 3 different desktop...
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive to working order you need to format the flash drive,BUT you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm www.CardRecovery.com
May 30, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
USB transcend malfunctioned
May 29, 2011 | Computers & Internet
I have a Transcend JetFlash here which the Windows XP CANNOT possibly recognize. Base on my suspicion, it could be I have removed the said JetFlash from my USB drive.
May 17, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My sandisk memory card of 4gb shows 0 bytes how do i format
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
Apr 25, 2011 | SanDisk 4GB microSDHC Memory Card
I have my jetflash usb 4gb, it doesnt work when i inserted in my pc
Mar 26, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Cannot retrieve my files
Mar 20, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Usb flash drive not working properly
Feb 26, 2011 | Sony Electronics - Others
I have a kingston data traveler 2gb DTI. i was copying movie files to my data traveler and it removed the volume label and i am not able to change it back. now I am not able to access any files. it does...
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you need to format the flash drive, but you will lose the data stored on the flash drive.
Feb 23, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Computer is not reading USB hard drive
Check out this blog post by these flash drive professionals:
http://www.flashdrivepros.com/_blog/USB_Flash_Drive_Data_Recovery_Blog/post/Help!_Windows_No_Longer_Recognizes_My_Flash_Drive!/
...and if that doesn't help, you can always order their cheap service. Its great that they have a guarantee, that if they can't recover your files for you, then they'll give you a full REFUND.
Feb 08, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I plugged in my flash drive and nothing happened. Why is it not recognized
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
Nov 25, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
21 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
k24674
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
