Question about Sharp LC52SB55U LCD TV
How do we block a certain channel?
Now that we have a new tv, we get a very bad channel. we just want to block that one specific channel, and not everything, say PG-13 for example. is that an option?
thank you!
  • Anonymous Apr 02, 2009
    I want to block a certain channel. How do I do this?
  • 126 Answers
You will need to call our technical support line on 0845 20 20 118. Click Here for help
Posted on Dec 24, 2008
  • Sion Buckler
    Sion Buckler Dec 24, 2008
42 inch flat screen shows v-chip block tv-14 lsv what does that mean? tv fades tremendously turns blue then shuts off
V-chip Block
TV- 14 - this is a rating for movies and TV programs. Basically means PG-13 like the old movie theater rating.
lsv- means, language, ***, violence.
You TV can be set to block these programs.
In you menu look for a catagory called "locks" or "ratings"
there you will find the options of what can be veiwed and what will be blocked.
if you everything to be available, just disable all settings.
if you want to choose different things to be allowed, just click on the icons and they become blocked.
Apr 12, 2011 | Olevia LT42HVi 42 in. LCD Television
The tv is connected to Dish Network as TV2. I accidentally changed the channel & now I can't get it back to channel 90 - it only goes to 13 now. How do I fix this?
In the menu screen, you must find antenna connections. For example " TV Air "(over the air channels 2 through 13) or cable TV. You must tell the menu to select cable TV (with the original remote). This will allow you access to channel 90. Thanks for asking and show a few hands of support.
Nov 07, 2010 | Orion STV2763 27" TV
I can't program my tv to regular antenna channels
You can program to regular (analog) antenna channels. To do so you must use the original remote which has a TV/DTV switch in the top right corner of the remote. Choose the appropriate mode for the type of channel you want to see or scan for. Here is a link to the owners manual and a picture of the remote swithc. The info on the signal switching is on pg.13.
http://tv.manualsonline.com/manuals/mfg/funai/cr130dr8.html?idRes=707655
Oct 27, 2010 | Durabrand DWT1304 13" TV
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
Program Blocked errors
I was having the same problem with the constant blue screen appearing with different error codes. Here is how I fixed the problem on my Elements 19": I did a channel search. I found there were 68 analog channels and 274 digital channels. On a hunch, I went into Skip Channels and checked off all the digital channels since I have basic cable. Although the tv is HD and did pick up the basic HD channels, I choose to skip those two since I do not have a cable box on that tv and only the basic channels were in HD (about 8). I watched my tv for two hours and blue screen appeared once every 30 minutes, but the next day it did not appear at all.
I concluded that those error messages are because those channels are blocked and we have not checked them off to be skipped. When checking the Skip Channels, as you highlight each channel it will either come in or it will not. You will find the "Blocked Program" errors are coming from channels that do not come in and you will need to skip those channels.
I hope you can understand how I solved my blue screen problem on my Elements tv. Good luck!
Nov 14, 2009 | Element Electronics FLX-1910 19 in. LCD...
I have a konka television from a previous owner with the channels blocked. is there an override code to unlock the channels 0000 does not work. i really wanna be able to watch my tv as soon as possible
Codes is almost impossible to break,tries reset everythings in the menu setting,unplug for couple hours,just see if it reset itself,that all could do more than three years old tv not possible find reset codes.
Oct 10, 2009 | Konka DT138U 13 in. TV/DVD Combo
I DO NOT HAVE THE ORIGINAL REMOTE. THE TV IS CONNECTED TO A SATELITE FEED. AFTER A FEW SECONDS ON SOME CHANNELS THE SCREEN GOES BLANK AND A MESSAGE COMES ON "PROTECTED TV PG-14" IS AN EXAMPLE. HOW DO I...
walmart sells a ge universal remote in the check out it is a three in one remote. for five bucks. it does everything i own. except a twenty five year old tv. it will even access the menus on my ac unit.
check it out. you may have to use the manual program mode on the thing but it will probaly work
Mar 12, 2009 | Symphonic Televison & Video
My tv has a message on it that will not allow me to watch adult shows
some one had entered a code in the tv for parental lock causing the tv not to show adults channel.take it to a tech to lift up the eeprom from out of the set and resolder it back,that will reset the tv.ask your family if any one of them had entered the code in the tv.if none of them remember then you will have to call the tech.good luck
Apr 11, 2007 | Emerson EWC1304 13 in. TV/VCR Combo
Sharp LC52SB55U LCD TV Logo
154 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
