Question about Cobra MicroTalk PR 1100 WX (15 Channels) 2-Way Radio
No Auto Squelch on Cobra PR4700WX
I have a pair of these radios and like them a lot. One is stuck with no squelch. The other works fine. I have turned on and off the Auto Squelch/Max Range function but the static is not squelched. Is there an internal adjustment to tweak the level?
  • 91 Answers
Yes sir, when u will open the set u can find two potentiometers , one is for tranmitter another for receiver . Try adjusting the same ( second radio should be transmitting ) do not switch one radio without antennae it may burn ..
Regards
raj/
Posted on Apr 12, 2009
Everything seems to be working but have no sound or squelch.
what kind of radio? It could be a number of things from a transistor to a transformer . Could also be a bad switch .Check your contacts on the squelch switch to make sure they are secure and if its a cobra or any other radio where the squelch and volume are on the same switch make sure those contacts are secure Could also be your final or driver in which I would change both.
Apr 28, 2016 | Cobra Radio Communications
How do i adjust the squelch?
Turn the squelch control clockwise just enough to cut the background noise, this should work well for local communication.
Jul 23, 2012 | Uniden Gmr2638-2ck 26 Mile 2way Radio With...
The squelch not working on a cobra 29 wxnw st sound tracker
there are 3 or 4 horse shoe presets inside the radio i suspect that the squelch preset is needing turned up. try turning one up at a time. remember to put it back to where it was if it is not the squelch. use a plastic screwdriver do not go putting metal screwdrivers into your radio in case of shocks. hope this helps you
Aug 29, 2009 | Cobra Radio Communications
Cobra PR4750WX - how do I adjust squelch?
You are right there is no adjustment. You can however turn the squelch off and this maybe what is happening to you.
To turn the squelch off you press and hold the button that is just below the push-to-talk button for at least 5 seconds.
To turn the squelch back on, you either press (less than 5 sec.) and the same button or change channels.
When talking with a specific party or group, you should use the tone coded squelch (CTCSS) and that will mitigate the noise if you are not already doing that.
Apr 18, 2009 | Cobra 22 CHANNEL 2-WAY RADIOS
Constant RX mode on Cobra Microtalk Walke Talke
I have the same walkie talkies and on mine I can hold down the mode/lock button and it will come off of the Rx mode. Also, you should be able to press the talk button and it will come off of the Rx mode.
Jul 06, 2008 | Cobra PR4100-2WXVP 2-Way Radio
Squelch doesnt work
Open the component / speaker side cover on the radio, adjust VR3, this is the alignment control for the squelch. Set your squelch control knob on the front of the radio to about 10 o'clock and slowly adjust VR3 until the signal from the speaker is mute.
When you turn the squelch back to the 0 position, you should have signal with no squelch as in normal operation.
Thanks!
Dodgem
http://dodgem250.angelfire.com
Apr 06, 2008 | Cobra 29 LTD CB Radio
Cobra MicroTalk PR 1100 WX (15 Channels) 2-Way Radio Logo
400 people viewed this question
Top Cobra Radio Communications Experts
Steve
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
