Question about Frigidaire FGF326AS Gas Kitchen Range
I need to know how long the self cleaner stays on and if it can be turned off, and how to do so if it can be.
  • Frigidaire Master
  • 3,328 Answers
A couple of hours once its in its cleaning cycle some can be turned off by pressing cancel
Posted on Jan 04, 2009
Ge electric range. Can’t find paperwork. Need to know how to run the self clean for the oven
Don't run it. We see far too many horror stories on FIXYA from people that do. Generally doors that stay locked and elements burned out, plus in electronic units, error codes.
If you really want to do it, Google
make model manual
Most are online
Put a pan of boiling water in the middle of the oven and spray the shelves, walls and base with ammonia cleaner leave overnight. Spray the cleaner again and leave for an hour. Everything will rinse off.
Mar 20, 2018 | GE Kitchen Ranges
All i know about my self cleaning oven is that it is a frigidaire. it was here when i moved in. i want to use the self cleaner but i have no idea how. nothing on it is digital. its all knobs. i have no...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Aug 09, 2011 | Frigidaire Microwave Ovens
All I want o know is how to clean it. I think it's a basic question that should be on line with out having to type a thesis to you. I have a day where I can clean it Now I have to wait for your...
Instructions Things You'll Need:
  • Oven Cleaner
  • Soft Rags
  • Sponges
  • Oven Cleaner
  • Sponges
    Self Cleaning
  1. Remove oven racks and soak them in soapy water.
  2. Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  3. Let the oven do its work; it will heat for several hours, charring off baked-on foods.
  4. Fast Cleaning
  5. Remove oven racks and place them in soapy water to soak.
  6. Preheat oven to 200 degrees.
  7. Turn the oven off and spray the inside with oven cleaner.
  8. Allow to sit for 10 minutes.
  9. Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  10. Dry with a soft cloth.
Feb 02, 2011 | Ovens
The vacuum won't turn on. plugged in, all lights flashing. no power
When switched on the vacuum goes through a self diagnosis test. Lights will come on for a while, then go out. If everything is okay, then the blue "Optimum" light will come on and stay on. If it turns of, a red indicator light should come on providing information on what's needed; i.e., filter or bag change needed.
Aug 22, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
My range is actually the RGB746 self cleaning gas
oven don't stay on and it takes a long time to heat up
Nov 21, 2009 | Hotpoint RGB745 Gas Kitchen Range
My poulan mower will turn on, but will not stay on. i have even tried to put carburator cleaner in it
your more likely need your carb over hauled and your sys flushed out. you may want to check your spark but i don't think this is your problem. We see this every day in our shop. bad fuel. fresh fuel at all times 24-7 stabilized all the time. Gas can't clean Gas
Oct 13, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Hotpoint oven self cleaner mode; cant unlock the door
Hello. I want to help you. I can understand why you did what you did. Now though I want you to forget about the open cleaner and just set the self cleaner again and let it run its course. get back to me if it won't let you do that as there are other things you can do then.
May 20, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Power will not stay on shuts off by self
Probably an output transistor issue, it will need to be serviced by a professional, especially if it turns off immediatly after you turn it on
Feb 28, 2009 | Onkyo TX-SR605 Receiver
Figidaire oven light will not turn off
sounds like you do indeed have a bad door/light switch 316209900, replace it though dont remove it. also just give a check along the top of control panel some models actually have a oven light switch along the top.
Feb 11, 2008 | Frigidaire FEF366 Electric Kitchen Range
Hotpoint self-cleaning oven
  I believe they make an oven cleaner for self clean ovens.  Don't try regular oven cleaner.  Ruins finish.
Oct 24, 2007 | Hotpoint RB757 Electric Kitchen Range
Frigidaire FGF326AS Gas Kitchen Range Logo
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
