Whining noise may be coming from the a/c compressor so how do I put oil in the a/c compressor
SOURCE: Where is the fuel filter located on a Land Rover
near the fuel pump. Listen for it. It is down low. In back, by the fuel tank.
SOURCE: differential noise/whine when of 1994 land rover discovery
Sounds Like Pinion Bearings , But Carrier Bearings Should Be Replaced (In My Opinion) as they Could Be Contaminated
SOURCE: 97 Land rover discovery 1 oil light comes on after approx. 15 mil
Tune-Up-Parts Link:
http://www.britishpacific.com/BPSite/LandRoverDiscovery/DiscoIService.html
Testimonial: "Great site for Land Rover parts. Thanks for the suggestion."
SOURCE: transfer case oil change- 1999 Land Rover Discovery II
No need for a diagram, to drain the oil, there's a drain plug on the bottom of the transfer box, under the handbrake drum. To fill, the fill plug is about in line with the centre of the handbrake drum and to the left. I think both plugs are 1/2" square. Fill to overflow with Texaco Multi-Gear 75W/90R. Takes about 2L or so.
SOURCE: 2001 land rover discovery II locate fuel filter and fuel pump
If you're standing looking at the rear of the vehicle, it's on the chassis rail on the right hand side rear wheel arch.
