I need 2 know how to ajust the color after the green color chip has been changed
  • 126 Answers
Manufactures re-set.
Then in the menu you will see the option to adjust the color/ hue etc
Posted on Dec 24, 2008
Have Panasonic plasma mod TH-58PZ850U . Have picture but, has a lot of green. What could be the problem?
Your cable box or satellite receiver could be causing the green screen. We recommend you ensure the box's 4:3 Override has been changed to Stretch or Off and Color Space has been change to RGB.
May 06, 2014 | Panasonic Televison & Video
How do u change bulds an where they at
bulbs do not get changed as it has picture tubes--sounds like a convergence problem--replace the two STK-392-110 or 150 chips it has.
Jun 14, 2012 | Hitachi 51F510 51" Rear Projection...
I can't seem to correct a tint problem. The tv turns on and the tint doesn't change. A friend says it could be a vidoe card?
Go to menue on controller, then Picture, then adjust Color and Tint to you taste. The color ajusts Blue and Green move left more blue move the slider right more green. The Tint controlls red. More red move right less left. Also chech Color temp setting.
Nov 08, 2009 | Akai PDP4225M 42 in. Plasma Television
Adjust color, need service manual
On controlls the foucus...the other the brightness. I would not mess with them. 99% of the time the problems is one of the two listed below...
You have one of two problems. Sometimes both.
Problem #1) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #1
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Problem #2)
Your TV may have a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSolution # 2
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 05, 2009 | Philips 9P5544C 55" Rear Projection...
My Philips 43PP9202
Problem #2)
  • Screen looks 3D
Jun 03, 2009 | Philips 43PP9202 43" Rear Projection...
Color not right
HI
you have defective RGB Circuit The Red, Green, Blue, You have shorted Green Circuit in Crt circuit this needs to diagnose to locate the shorted parts...
Thanks!
Apr 12, 2009 | Zenith B27A11Z 27" TV
The pitcher is blury and need to be ajusted , how do i do that
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution
Feb 11, 2009 | Philips Magnavox 9P6034C 60" Rear...
Sharp 32sf560 TV
Good day
You an adjust the screen brightness on the rear portion of your units flyback. Then the intensity of the color will change.
chris
Feb 02, 2008 | Sharp 32C241 TV
Ic chips?? light engine??
the color wheel has gone out. good luck finding a new one. I just had to have my whole unit replaced because parts could not be located.
Jan 31, 2008 | LG 52SX4D 52" HDTV
Hitachi 46
Your TV most likely has one or more possible problems.
  • Screen looks 3D
2c07611.pngSolution #2
Dec 06, 2007 | Philips 60PP9753 60" Rear Projection...
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
