Question about Archos 605 WiFi Digital Media Player
Archos 605 wi /fi only puts music on hard drive
After sync with w m player archos will only put music on hard drive files why any clues any one !!!
A couple things to note. First.
Make sure the files are the right format.
second, make sure they are in the music folder.
third... sometimes it won't read them. you can still play them here's how:
Go on your archos go to music, than at the bottom click on hard drive.... you can play everything there.... i recommend not synching it... but dragging and dropping them in by hand... i like doing things basic...
Posted on Dec 24, 2008
I cant access my files when I plug my Archos 605 into a computer!
i had the same problem what i did was i downgraded my 605 to
Archos 605 Wifi (20GB-160GB) OS v 2.0.10
then i upgraded to Archos 605 Wifi (20GB-160GB) OS v 2.1.04
heres the link for 2.0.10 http://update.archos.com/5/a605/a605_r2.0.10/firmware_a605.aos
and heres the link for 2.1.04 http://update.archos.com/5/a605/a605_r2.1.04/firmware_a605.aos
Jan 01, 2009 | Archos 605 WiFi Digital Media Player
Archos 605 doesn't recognize my music files
from another forum on this site
Thanks and credit to eyez12 - the 2nd option below worked for me
try going to menu, settings, system, and then clicking the update ARCLibrary button, that was all it took for me.
if that doesn't work then go to repair and formatting tools and click "clear temp system files and cache"
Nov 13, 2008 | Archos 605 WiFi Digital Media Player
Music from Windows Media Player does not show on Archos list
I had a similar problem and ended up using Real Player to put music on my Archos.
Nov 12, 2008 | Archos 605 Digital Media Player
Problems when i sync my archos with media player
Sounds familiar, I did that a few years ago, then it seemed that it formatted my whole mp3, then copied what i wanted. So if I wanted to sync 1 song, that was all on my mp3 after the sync...
That's the last time I used sync, bad memories.
I now copy manually from the PC to my Archos. Then you can control the order of the mapsand the maps you add. If you sych, WMP puts every map in the library in the Arhos music folder.
I just don't get the point of synchronising...
Jul 04, 2008 | Archos 605 WiFi Digital Media Player
Loosing Albums
Also here, try to Manually put the files in the music folder.
So dont sync, but copy and paste. You need the option USB set to 'PC Hard Drive' in settings -> system. Let me know if it worked, because I have bad memories if it comes to sync, so I don't use that anymore. On my way it works fine, don't know if that's the case on yours.
Jul 03, 2008 | Archos 605 WiFi Digital Media Player
Archos 604, frustrating problem.
Ribbon on hard drive came loose, take out battery. remove 2 screws on inside of battery compartment (not the ones mounting the plastic frame) remove 2 screws on side of unit(not all four, tough to get back together if you do. take ribbon and reset it into hard drive first, then unit. slide battery back on and backcover, turn on, problem sould be sovled. If not, try again the ribbon is not seated. it took me 3 or 4 times, about half an hour, with jewlers phillips-head screwdriver. my Archoes was a 604 wi-fi but it shoud work pretty much the same on 404, 504, 604, 605, 705 605 wi-fi, and 705 wi-fi.
Mar 24, 2008 | Archos 604 Digital Media Player
Archos 605 wi fi fault
have you tried resetting the machine on the bottom their is a tiny hole put a reasonable sized safety pin through that you use for a babys nappy.I found this reset my archos!!!!
Nov 20, 2007 | Archos 605 Digital Media Player
Archos 605 WiFi Digital Media Player Logo
79 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
