Question about Logitech Harmony 525 LCD Remote Control
Wont usb connect!
USB is showing connected on remote screen but the dialog bog on the computer screen is showing connect USB. I have tried repeatedly to connect the ******. I am using an Apple Mac Book laptop.
  • 126 Answers
Go into device manager and update the drivers on the newly found hardware. If they are already installed used the disc to re-install from device manager.
Then add the application on whilst the item is discomnnected
Re-connect and launch application. Should work.
Posted on Dec 24, 2008
How do I down load photo's from my Samsung 2 phone please
First make sure you have the correct USB drivers for your phone installed on your pc. Go to device manager and see if your phone or mass storage device is listed. If not, download the drivers here, http://www.samsung.com/us/support/downloads. Make sure debugging on your phone is enabled. Please refer to the following:
  1. To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > Applications > Development" and enable "USB debugging".
  2. Then drag the status bar down and tap on "USB connected".
  3. The "USB connected" screen with the large green Android icon will appear. Tap on "Connect USB storage".
A confirmation dialog box will appear. Tap "OK". The green Android icon will turn orange, indicating that the phone is now in USB Mass Storage mode and should now appear as USB disk drives in "Devices with Removable Storage" and be assigned drive letters.
Samsung Galaxy S2 (Android 4.0)
  1. To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > More... > USB utilities" and tap on "Connect Storage to PC".
  2. Then plug the USB cable into the device and connect to your computer.
  4. A confirmation dialog box will appear. Tap "OK". The green Android icon will turn orange, indicating that the phone is now in USB Mass Storage mode and should now appear as USB disk drives in "Devices with Removable Storage" and be assigned drive letters.
Samsung Galaxy S2 (Android 2.3)
Jan 09, 2015 | Samsung Cell Phones
Tip
My hp pavillion g6 wont boot
By pressing f11 repeatedly during start up will pop up dialog box to access system recovery image. But if the system image has been deleted accidentally, check if you have a friend with the same model copy the recovery file from his computer. You will locate the recovery file when you open my computer. Then connect the usb device and try restart your system using 11. If it fails enter setup and change the first boot device to usb and still press f11 for the system to see the system image file. Otherwise look for original os cd for your computer. Nnamdi
on Jun 25, 2014 | HP Pavilion dv6000z Notebook
When i connect a pen drive to the usb port of my G31D M7 mainboard,a dialog box pops up,showing, ' This device can perform faster on connecting to a high speed usb port'. So i downloaded the usb...
If you're comfortable having a look at your BIOS screens, then have a look for an entry mentioning USB 2.0. See if it is enabled. If it isn't, enable it, save changes, and reboot.
You can usually get into BIOS by tapping the Delete key on your keyboard during bootup, but some motherboard manufacturers have different ones. Just read on the screen during boot up what button to look for.
Hope that helps.
Cheers from NZ
May 09, 2011 | Biostar Computers & Internet
WE HAVE A READY 2 DOWNLOAD MESSAGE ON OUR SCREEN AND WE CANNOT GET RID OF IT. WE TRIED SHUTTING IT OFF .
This is the current solution posted by HP. Sounds like your firmware is corrupt and these are the steps you need to take. This may or may not work.
  1. Close the firmware update tool on the computer if it is still active on the screen, and then turn off the product.
  2. If the product is on a network, connect a USB cable (2 meters or less) from the product to an open port on the computer. HP recommends that this be a direct connection instead of through a hub.
  3. Turn on the product, and then wait for the message ready 2 Download to appear.
  4. On the computer, cancel any alerts about a new device being connected.
  5. On the computer, open the Printers and Faxes control panel.
  6. Right-click the printer driver for the product model that is being updated, and then click Properties .
  7. In the Properties dialog box, click the Ports tab.
  8. Note the name of the port that the product is currently connected to for use later when reconnecting at the end of this process.
  9. Click the check box next to USB001 . If USB001 is already connected to another USB device, click USBXXX where "XXX" is the highest-numbered USB device that has a description of Virtual printer port for USB . Using the scroll bars on the right side of the window might be necessary, depending on the number of devices installed.
  10. Click OK to accept the change and apply the settings.
  11. Restart the firmware update tool on the computer, and then select the same product that was just created.
  12. Start the firmware download.
  13. Verify that the control panel display shows Erasing and then Programming , indicating that the update process has begun. Do not interrupt the firmware update process.
  14. The product should momentarily show the message Complete . Turn the product off and then back on. The product will not automatically reboot.
  15. When the product reboots, on the computer, cancel any alerts about a new device being connected.
  16. Print a configuration page to verify that the update occurred.
  17. Return to the Printers and Faxes dialog box, right-click the printer driver for the product model that is being updated, and then click Properties .
  18. In the Properties dialog box, click the Ports tab.
  19. Click the check box next to the previous port to which the product was connected before the update began.
  20. Click OK to accept the change and apply the settings.
  21. If the product was previously connected via USB, the process is complete. If the product was network-connected, disconnect the USB cable, and then reconnect the product to the network cable.
Apr 19, 2011 | HP Laserjet CM2320nf All-In-One Color...
I am running the harmony software 7.7.0, but it cannot communicate with the remote. It just sits in the "Check Connection" page where it says "Communicatin with your Harmony Remote. This may take a few...
Try dkelly2671's suggestions first to ensure that you don't have an issue with your USB connection or current software installation. Also, make sure that your USB cable is ok (use another one, or if you have a digital camera, try downloading some pictures to your computer - they generally use the same kind of cable). If you still are not getting anywhere, you can try putting the remote in "Safe Mode" and doing a Firmware Update. To do this, launch the Logitech Remote software on your computer and click on "Downloads" (on the top menu bar). Then, take the battery out of your remote and at the same time you connect the USB cable to your remote (it should be already connected on the computer end)press and hold down the Off button at the top of the remote. This will put the remote in "safe mode". Continue to hold down the Off button until you see the message "safe mode requested" on the remote's screen and the screen starts blinking. Once you see this, you can release the Off button. Now, go back to your computer and click on "Firmware". If the software is able to communicate with the remote, an update to the remote's firmware should be executed. Good luck!
Mar 03, 2010 | Logitech Harmony 880 LCD Remote Control
How can i use jasjam as a modem
Thank you for visiting Fixya Forums
Using a Jazjam as a modem:
Notes
• Before activating Wireless Modem, make sure your device has a
SIM card installed, and you have set up a GPRS or phone dial-up
modem connection on your device. For more information about
setting up a GPRS connection, see "To set up a GPRS connection to
the Internet". For more information about setting up a phone dial-up
connection, see "To set up a dial-up connection to your ISP".
Also make sure you have connected your device to a computer (via
infrared, USB or Bluetooth).
• When you activate Wireless Modem, ActiveSync will be disabled
automatically.
To set up your device as an infrared or USB modem
1. On your device, tap Start > Programs > Wireless Modem.
2. In the Connection Type list, select how your device is connected
to the computer: IrDA if via infrared, or USB if through USB cable
connection.
3. To use your device as a GPRS modem, set the GPRS Access
point name. To do so, tap Menu > APN Setting and enter the
access point name.
4. Point your device at the infrared port of your notebook, or plug in
the USB cable adapter between your device and the notebook.
5. Tap Menu > Start.
6. The next thing to do is to add your device as an infrared or USB
modem onto your notebook.
To add your device as an infrared modem to your notebook
1. After you tap Menu > Start on the Wireless Modem screen
of your device, the Found New Hardware dialog box will then
appear on your notebook and will show that your device has been
detected as an infrared modem. In this dialog box, make sure that
Install the software automatically (Recommended) is selected
then click Next.
2. Wait for Windows to finish installing the infrared modem, then
click Finish.
3. You can now connect your computer to the Internet. Follow the
steps in “To dial up and connect to the Internet.”
To add your device as a USB modem to your computer
1. After you tap Menu > Start on the Wireless Modem screen of
your device, your computer will automatically detect that your
device has been connected. The Found New Hardware dialog
box will then appear on your computer.
2. In the Found New Hardware dialog box, select Install from a list
or specific location (Advanced) and click Next.
3. Select Search for the best drivers in these locations.
4. Insert the Getting Started Disc into your CD drive. Select the
Include this location in the search check box. Click Browse
and choose the CD drive and root folder where the modem driver
is located, then click Next.
5. Wait for the installation to complete, then click Finish.
6. Click Start > Settings > Control Panel.
7. Double-click Phone and Modem Options.
8. Click the Modems tab. Select the new modem from the Modem
list, then click OK.
Getting Connected
9. You can now connect your computer to the Internet. Follow the
Once the computer recognizes your device as a modem, you can now
use the computer to dial up and connect to the Internet.
1. On your computer, click Start > Settings > Control Panel.
2. Double-click Network Connections.
3. Click File > New Connection.
4. In the New Connection Wizard, click Next.
5. Click Connect to the Internet then click Next.
6. Select Set up my connection manually then click Next.
7. Select Connect using a dial-up modem then click Next.
8. Select the infrared, USB or Bluetooth modem that you previously
installed, then click Next.
9. Enter a descriptive name for this connection, then click Next.
10. If you are connecting to the Internet via GPRS, enter the
telephone number as *99#. Otherwise, enter your ISP‘s dial-up
phone number, then click Next.
11. Under Internet Account Information, you may not need to
enter a user name and password when using GPRS. Just click
Next to proceed.
12. Click Finish to exit the wizard.
13. The Connect dialog box then opens. Click Dial to dial up and
To end the modem session
• On the Wireless Modem screen, tap Done or tap Menu > Stop.
(Please give me a big thumbs up when you rate my answer, thanks.)
Jan 28, 2010 | i-mate JasJam Smartphone
Remote can't connect to Software on Vista
Try a different cable, any standard mini usb cable will work. When it asks to press a button on the remote unplug the remote and plug it back in and it should pick it up right away.
I have had similar quirks with harmony remotes be never had one I couldn't connect too.
Failing that harmony has an excellent tech support service, it could be a remote problem.
Cheers
Oct 28, 2009 | Logitech Harmony 890 LCD Remote Control
Harmony 880 remote wont conect with computer
A communication problem can be caused by a variety of issues, both hardware and software related, so this can be difficult to debug. First, make sure that you have the latest software installed and that the installation is successful. Next, make sure that the USB cable and the USB port on your computer are good. Try to upload some pictures from a digital camera, etc. They generally use the same kind of cable. If the software is ok and the USB cable/port is ok, it's time to turn off any virus software, firewalls, etc. Now you should try to connect. If the software still does not detect the remote, you can try putting the remote into 'safe mode' and then try establishing a connection to upgrade the remote's firmware. Here's how you do that:
Launch the Logitech Remote software on your computer and click on "Downloads" (on the top menu bar). Then, take the battery out of your remote and at the same time you connect the USB cable to your remote (it should be already connected on the computer end) press and hold down the Off button at the top of the remote. This will put the remote in "safe mode". Continue to hold down the Off button until you see the message "safe mode requested" on the remote's screen and the screen starts blinking. Release the Off button. Now, go back to your computer and click on "Firmware". If the software is able to communicate with the remote, an update to the remote's firmware should be executed. If this step is successful, you will be prompted to update your remote with your personal configuration (your device and activity profile). I hope this works out for you!
Oct 04, 2009 | Logitech Harmony 880 LCD Remote Control
7" sunpak frame wont recognize usb connection
How do I get my computer to recoginze the connection of my USB?
Dec 31, 2008 | Sunpak (SDPF-070AW-0US) Digital Picture...
Lexmark 3100 printer
hi
U first install the printer software which is given by the printers and install it. after that u connect the usb port it will automatically ask you whether u connect and let u install the driver for it
Feb 21, 2008 | Office Equipment & Supplies
Logitech Harmony 525 LCD Remote Control Logo
402 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
ray gallant
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
