Question about VisionMan VisionVault 4TB Smart NAS Appliance - Gigabit LAN, Hardware RAID 0, 5, Span, 128MB DDR, 4x (SSTE-2NAS30)
Write and read spead slow; only 10MB/s
I have a SCM400 with 4 1TB disks. Disks are WD Caviar Black SATA II. I am connected with my Vista PC to the SCM400 on a 1GB network.
When transfering files between the SCM400 and my PC I find the speed rather slow. My Vista 'Moving File' window says that it transfers at 10MB/sec when it's fast, but mostly it's just 6 MB/sec.
I read somewhere else that people tested with a NAS reaching speeds of 90MB/sec.
What is a normal speed and what could be holding back the file transfer speed?
Thank you,
Pieter
    President:
  • 1,996 Answers
This has been a commonly reported concern. Here are a few links that may provide a solution to this problem:
Additionally, some Vista users report better file transfer rates using WinRAR & Teracopy.
For maximum file transfer, also check all elements in your network, i.e. switches & routers, etc. For discussion of max speeds cf. here
Please consult this article from Microsoft to take steps to improve your system's performance with Vista, by clicking here
For troubleshooting performance issues, please see these articles and the links within them: TroubleshootVistaPerformance and Troubleshoot Vista Startup and Vista Diagnostics
Finally, you may wish to consult this General Setup&Maintenance guide.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 17, 2009
Dead hd wd caviar 80 gb
Is the "dead" hard drive 80GB? or 500GB?
I presume you set up this hard drive as the second hard drive, or as an external drive. You can do these:
1. Disk Management (check the readablility):
Control Panel, Administrative Tools, Computer Management (please run as administrator; right click it), Disk Management. Is this hard drive info exist in this screen? If it is, then the hard drive is not dead.
Click on the hard drive info, right click, and you can do some actions (format, expand the volume, assign a drive letter, etc.)
2. If necessary, test and fix it using Norton Utilities (download and run it):
http://download.cnet.com/Norton-Utilities/3000-18512_4-10907620.html
Feb 20, 2014 | Western Digital WD Caviar Green WD5000AADS...
Firmware wd15ears corrupt
Go to WD's website and download a new firmware file.
Nov 30, 2013 | Western Digital WD Caviar Green WD15EARS -...
My WD caviar green keeps blinking and won't show up in any way on my windows pc or macbook pro
Your WD has probably gone belly up. If you can't get it to register on either computer and you've tried different computers then it has croaked.
Were you able to use it in the past on the windows computer and the mac? If so, that's strange because they are two different formats and most times when you plug the drive into one or the other it will want to reformat it to be able to access it.
Jun 05, 2012 | Western Digital WD Caviar Green WD5000AADS...
I bought a Western Digital Caviar 1TB SATAII 64MB Cache 3.5-inch Green Internal Hard Drive OEM and I am trying to get it to work on a SHARKOON QuickPort Combo for SATA HDD - but my vista laptop...
the problem is with compatibility with Quickport combo ,cache of this is upto 8mb while that of WD disk is 64mb power is not sufficient to handle it so try a quickport pro
Jul 02, 2011 | Western Digital WD Caviar Green WD10EARS...
Hello I just bought WD 1 terabyte and it is telling me that it is only 31 mb!!
Check for the unallocated disk space in the disk... right click on my computer, goto manage, select disk management... it will show the original disk space...
Apr 05, 2011 | Western Digital WD 1TB 35" CAVIAR GREEN...
Hi, I want to know how to install the WD10EARS-00Y5B1 drivers? Okay, the problem is, that my computer doesn't recognise my SATA Hard Disk. I have Windows 7 Home Premium, and another SATA Hard Drive. I...
there are no drivers required for a hard drive.
Windows 7 should automatically detect the new hard drive and it should show up in disk management to format or prompt you to format.
Check your cable connections again.
Otherwise your new hard drive may be DOA. Return it to the store that you purchased from.
Mar 26, 2011 | Western Digital WD Caviar Green WD10EARS -...
It is plugged in can,t find the drive i,m in
You must format the hard drive before it can be used.
  1. Click Start, click Run, type compmgmt.msc, and then click OK.
  2. In the console tree, click Disk Management. The Disk Management window appears. Your disks and volumes appear in a graphical view and list view. To customize how you view your disks and volumes in the upper and lower panes of the window, point to Top or Bottom on the View menu, and then click the view that you want to use.
Right-click on your external hard drive and format it as NTFS. After the hard drive should pop up under My Computer
Mar 07, 2011 | Western Digital WD Caviar Green WD10EARS...
Fatal i/o error
The hard disk has died, time for a new one.
Jan 19, 2011 | Western Digital WD Caviar Green WD20EARS -...
Motherboard : ASUS P5GV-TMX Which hard disks does this motherboard support? It came with sata-I hard disk. Recently i bought a sata-II hard disk bt it is giving some problems..to be specific on windows it...
Yes, it can be causing a problem. You have 2 hard drives that are working at 2 very different speeds. The computer is having to do a translation and adjust rates of transfer between them on top of having to do the read and writes between them. Will SATA II will be backwards compatible to SATA I it won't work the other way. If you have to keep these drives, I would make the SATA II Drive the primary and SATA I drive the secondary on a different channel if possible. The SATA II drive is teh faster drive and should be your main.
Oct 09, 2009 | ASUS P5GV-MX Motherboard
Presario Media Center new SATA 320GB WD
Check to make sure you used a SATA hdd & not a SATA II hdd for your replacement. Usually these are not backwards compatible. Hope this helps.
Jan 10, 2009 | Compaq Computers & Internet
VisionMan VisionVault 4TB Smart NAS Appliance - Gigabit LAN, Hardware RAID 0, 5, Span, 128MB DDR, 4x (SSTE-2NAS30) Logo
928 people viewed this question
Top VisionMan Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a VisionMan Computer and Internet Expert? Answer questions, earn points and help others
