Question about Nokia E66 Smartphone
How to save contacts number to mobile phone.
When i am saving the number when i go back to look to see it has saved it is not there. how would i sort this out?
  • Anonymous Feb 09, 2009
    I met a girl on Sat and got her number, but i didn't save it
    is there a way i can look into a key pad memory?
    or is it gone?
Abe jingur, when u use to save the contact number, press done key. ok dear.
Posted on Mar 11, 2009
Dear Sir, I am using Samsung SJ700 mobile phone.And sometimes I get incoming call with no number displayed on the screen. It just shows incoming call. Can you pls help me in sorting out this...
This happens when two or more similar (saving one number with different names) contacts is saved on your phonebook, i.e. if you've saved my number on the sim card with a name and at the same time you have my number (same number) on your phone's memory, the caller id will not be displayed, you'll only see the "Incoming Call" or "Call". So I would suggest you to please check the phonebook and delete (keep only one per number) if there are multiple similar contacts saved on your phonebook.
You can also reset the phone to Factory default, in case there's no problem with your phonebook/contacts.
Good luck.
Thanks for using FixYa.
Aug 14, 2010 | Samsung Cell Phones
Saved game not saving
hello, are you sure there is a enough memory on your hard drive
if yes take the hard drive off give it a clean and clean the surrounding xbox 360, this may sound stupid but this is what i did as i had the same problem and mine was sorted straight after i did this, after you cleaned it with a damp cloth (not wet as this will break xbox 360) and then out the hard drive back on the side of the xbox
hope this helps, good luck and if you need more help send me a message back
Apr 22, 2010 | LucasArts Entertainment Company Lego...
My xbox360 wont save my profile i make one an when i turn off my system an i turn it back on its not there i don't get it ..
Are you using a hard drive or memory unit? From the sounds of things you're missing some sort of memory to save the profile to.
Jan 09, 2010 | Microsoft Xbox 360 Console
All of the buttons on the front of my C6280 all in one won't work. I have to go on the computer and go to the HP solution center to use it??
If the buttons will not work, this is either a physical problem with the printer, or an NVRAM problem.
If it is a physical problem, hopefully you have some sort of warranty because most printers like this are just not worth repairing.
If the issue is with the NVRAM, you can reset most HP printers with the following:
WARNING THIS WILL ERASE ANY DATA SAVED IN THE UNIT INCLUDING SAVED FAX NUMBERS!!!
1.) Power the printer completely off. If the power button will not respond at all you may have to unplug the unit. DO NOT UNPLUG THE UNIT WITH IT ON UNLESS ABSOLUTELY NECESSARY! If you do have to unplug it, be careful!
2.) Once the unit is powered off, then unplug it.
3.) With the unit powered off and unplugged, press and hold the # and 9 keys on the numeric keypad.
4.) While holding the keys down, plug the unit back in.
5.) Release the # and 9 keys and power the unit back on.
6.) This should cause the unit to display the message: FULL NVRAM RESET. The unit will then need to be setup again.
Oct 10, 2009 | HP Photosmart C6280 Printer
Nocontrol of tv with sky handset.
please follow the steps below:
TV
RED + SELECT
TV
0056
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
Please leave a thumbs up when this sorts you out cheers
Little Dish Fitter
Aug 14, 2009 | LG 32LG30 32 in. LCD HDTV
Playstation 2 will not save game "corrupt file"
the data probably got corruptted if you turn off the game while it is saving. unfortunatley there is no way to fix this except to start over. i know... that sucks. it happened to me with guitar hero 3
Jul 19, 2009 | Sony PlayStation 2 (PS2) Console
Saved game gets deleted
Most of the save game issues have to do with the onboard battery dieing. If this happens, your save game will persist for a few hours and then vanish.
May 31, 2009 | Nintendo Pokemon Ruby for Game Boy Advance
How to recalling my files before i saved
just try to check where you saved your file.... if you dont know it then try to search the file using the file name in windows search.... it might be hidden at times.. if so then try to enable hidden files in folder options.... suppose you have not saved the file as and when you made changes then also the file can appear to be mistaken
Sep 26, 2008 | Microsoft Windows XP Professional for PC
How to create an album
I can't help you with those software packages, but I can point you to a much simpler, nicer, and faster one (that's free with no adware or spyware)... www.preclick.com.
Feb 17, 2007 | Panasonic Lumix DMC-FZ20 Digital Camera
Nokia E66 Smartphone Logo
41 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
