My left mouse button isn't working right. Whenever I double click something on the desktop or on the taskbar icons, they don't open. I have to right click and click open to open programs. It also doesn't work in web browsers. When I click on a link it opens a new tab with that link and also loads the link in the same window. When I click on a tab, it closes it instead of switching to it.
  • Anonymous Mar 11, 2009
    same left mouse botton :(
  • Anonymous Apr 29, 2009
    right works but not the left ..if u switch them them then left works and not the right
My right mouse is not working
Posted on Jan 18, 2009
2 Suggested Answers
sharad84
  • 67 Answers
SOURCE: mouse problem
Restart machine > press f8 after machine logo > goto in safe mode >check it .
after that restart machine and connect from internet and scan your machine
you can down load spy warecleaner like
Posted on Jun 24, 2008
How to move icons from left side to bottom of screen
On all windows apart from Windows 8, you drag them from the desktop (left hand side) to the bottom (taskbar) with the mouse.
If the taskbar gets full up the icons might disappear.
The double bar at the end of the taskbar must be moved to the right for more of the taskbar to appear.
Mar 14, 2015 | Lenovo Computers & Internet
How do i open my recyle bin
Double left click on it with the left mouse button. You can also right click on it once and choose "open" from the menu.
Nov 05, 2014 | Computers & Internet
I would like to display the date also at the right bottom corner of my computer. The time is already displayed there.
Which operating system do you have ?
The Window's taskbar organizes open and running programs, provides a quick way to access application shortcuts, and gives easy to access to important computer functions and utilities via the system tray. Most users of Windows center their workflow around the Window's task bar for its convenience and ease of use. With the clock function automatically enabled, users can add the date to their task bar while increasing the space for more application shortcuts.
Add The Date To The Taskbar In Windows XP/Vista Right-click on your Window's taskbar and click "Lock the taskbar" option to remove the check mark next to it and unlock your taskbar. If there is no check mark next to it, do not click it as your taskbar is already unlocked. Move your cursor to the top edge of the Start menu and wait for it to change into a double arrow. Click and hold the left mouse button and drag your mouse upwards until the taskbar physically changes in . When it does, it will add the day and the date under the time. Add The Date To The Taskbar In Windows 7 Right-click on the Window's taskbar and select "Properties" from the resulting menu. Click the check box next to "Use Small Icons" to disable the option. The icons will get slightly larger and the date will appear under the time. Click "Apply" followed by "Ok" to save your changes and exit the window.
Mar 15, 2013 | Dell Computers & Internet
To adjust rotating display of laptop ,taskbar with all icons moves on different(bottom to top)
Step 1:
Has your Windows taskbar suddenly moved to the side of your desktop screen or even to the top? This can be very disruptive to your daily computing, which may mean a loss of productivity at work. Your taskbar could have moved because of a glitch in programming or an inadvertent mouse click while you were focused on something else. The latter is more common and is usually the result of an unlocked taskbar.
Older Windows Operating Systems Windows 98, Windows ME, Windows XP and Windows Vista all utilize similar solutions for this problem. For the quickest route to returning the taskbar to the bottom of the screen, first place your mouse pointer over empty space on your taskbar (space not occupied by an icon or a button indicating an open program) and right-click. Look near the bottom of the menu that appears for the "Lock the Taskbar" listing, and make sure there is no check mark next to the listing. If there is a check mark, it means the taskbar is locked and cannot be moved, so click on the listing to deselect (and unlock) it. With your mouse pointer again over an empty space on the taskbar, click and hold the left mouse button and then move the mouse pointer to the bottom of the screen. When you release the left mouse button, your taskbar should have moved. As long as the taskbar is unlocked, you can also vary its height. Hold the mouse pointer over the upper edge of the taskbar until it becomes a double arrow (pointing up and down). Then click and hold while you drag the upper edge of the taskbar to the you desire. Once you have the taskbar where you want it, remember to lock it again by selecting the listing on the right-click taskbar menu.
Another option is to visit the Microsoft Windows website and download and run an automatic "Fix it" program, which should take care of programming issues. Windows 7
There are three options for moving the taskbar in the Windows 7 operating system. The first option involves right-clicking on an empty space in the taskbar and then navigating to the "Properties" menu (look near the center of the menu) to set the location of your taskbar on your screen. This menu also allows you to change or establish a number of other default settings relating to your Start menu and taskbar. The second option is exactly the same as the first process given for the Windows operating systems previously mentioned. And again, to prevent the format you have established from changing, lock the taskbar by right-clicking on an empty space of the taskbar and selecting "Lock the Taskbar" from the menu. The third option is a bit more involved and requires downloading registry files (files ending in ".reg"), saving them to your desktop and then double-clicking on them to merge them with your operating system. The files can be deleted after use.
Microsoft online support
http://support.microsoft.com/kb/253679
Feb 17, 2013 | Dell Inspiron Mini 10 Notebook
Can not connect to internet using my acer notebook and have no icon to click on to
Hi richard g le...
Left click on Start and look at the top of the pop open window, you should see "Internet Explorer, you can double left click on that and connect to the internet.
Also if you left click on it and hold the mouse button down you can "Drag and Drop" the internet icon on your desktop where it will be an icon on your desktop and you can connect to the internet whenever you click on it.
Please take time to rate me
Aug 16, 2011 | Aspire Computers & Internet
I can't hold the left button down and drag pictures or icons on the desktop.
Check if the mouse has been aligned for to be used by Left-Handed or RIght Handed people. If the settings are correct try reinstalling the drivers for the mouse. If that doesnt help either, try replacin the mouse and see if that helps.
Apr 07, 2010 | HP Wireless Optical Mouse
My desktop Taskbar is gone!
Bring up the task manager. Click [File] then "New Task(Run)". Type "cmd" into the text field and press Enter. This will open the command prompt.
Dec 08, 2009 | Computers & Internet
Laptop does not finish booting up
i recommend you need to re-installed the OS
Mar 12, 2009 | Computers & Internet
Microsoft Mouse Model 1058 - can't undo magnifier!
Hi, I have the same problem. I resolved it. The steps are - 1.Go to control panel 2. click on mouse and it will take you to mouse properties . It will display you the Microsoft mouse 3.Go to "buttons" Tab 4.Change the option in the "small thumb button" box to "click" from "Magnifier"..the default is "Magnifier"..that is why if u accidentally push this button..it opens up an annoying magnifier.. 5. then click apply..It works
Sep 30, 2008 | Microsoft Wireless Laser Desktop 4000...
Computers & Internet Logo
1,873 people viewed this question
Alun Cox
David Payne
David Payne
