Question about Jacuzzi 8450-959 Tara Whirlpool Bath 5'- White
No access panel and need to reconnect the vacuum hose
How do you remove the Magic Touch panel on the top of the tub<
  • waynesmpsn Dec 26, 2008
    The Magic Touch panel has tree knobs that turn on the jets and adjust the air flow to the jets.
  • Anonymous Mar 21, 2014
    removing panels to replacing faucet
The trip lever is an over flow for the tub to prevent you from over filling the tub capasity and flooding your home.
Mark
Posted on Dec 26, 2008
I have a Espree 536 and need to replace the magic air switch. The tub is enclosed with a tile mosaic front which I do not want to have to remove if at all possible to replace the switch.
it is possible that the switch is held in place by a nut from underneath
see if you put your hand up under the panel to see if there is a nut there
Oct 11, 2015 | Jacuzzi Home
Maytag top load washer. the water does not shut off prior to the spin cycle and continues to overflow onto the floor. suggestions? thanks
It sounds like the pressure dome switch could be out or its in the hose for the dome it could be clogged or hose may be punctured.
To troubleshoot this you will have to access your washer.
Without model number it will be hard but im going to try. If you have an access panel at the bottom in front than take a flathead screwdriver inbetween the access panel and the front panel there are two tab metal that you have to push down to pry the access panel off. If you have a full front panel than at the bottom you need to remove two screws. Once you have the entire front panel off you need to lift up the top on each side there is a usually 3/8 nut holding the top to the sides. Lift up the top and you will see a hose going from a cylinder shape on the side of the outer tub near the bottom. follow the hose up to control counsel. Take hose off the top and check for kinks. Than blow into the hose from the top to make air bubbles in the tub. Its easier if there is some water in the tub. reconnect the hose to your pressure dome. Set top back down dont put front back on yet. try a cycle small load and see if it shuts off. Look for leaks along than hose. If you cant see any leaks and it does not stop. Spin the water out and take hose from bottom where tub is. Start another load on small wait for a few seconds than blow into the hose from bottom to activate the pressure dome. If the washer keeps filling with the pressure dome activated than its your pressure dome switch. If it stops like its suppose to replace pressure dome hose. Any further assistance please feel free to contact me.
Jun 02, 2011 | Maytag Washing Machines
The water level shut off on my washer has all raised. The small load is about the middle now. the large load is near the top and the jumbo load floods. What do I do?
Pump out water. Remove front panel by pushing in retaining clips (2) at the very top seam, where the front panel meets the washer top. Pull thin "clear" hose off left front side of outer tub. Clean the gunk out of the thin hose. Re-assemble. To prevent this from re-occuring, use a washer cleaner, such as Affresh, Waher Magic, or Whirlaway hot tub cleaner every 3 or 4 months.
May 06, 2010 | GE WJSR2070B Top Load Washer
Jacuzzi Espree 7242 pump/motor will not shutoff. Manual says to reconnect tube to Magic Touch switch or to air switch pumpmotor. Do I have to pull the tub out? It sits in a tiled skirt.
There should be a removable panel either around the skirt or in the ceiling below the tub to access electronics and plumbing to repair.
Jan 09, 2010 | Tools & Hardware - Others
Washing machine will not drain
Hi
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
Thanks for contacting Fixya.com
Oct 11, 2009 | GE Spacemaker Washer and Dryer Electric...
I get F35 error code on my duet washer
Both of these fault codes point to a pressure switch issue. If you remove the top panel, three screws in the back, you will have access to the pressure switch. With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions. If the fault codes return after diong this, you will likely need to replace the pressure switch.
Aug 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer has a very musty smell. Trying to raise the top to clean inner tank but it will not budge. Does the top raise on the WJSR2070B model. Do not want to break it
Yes, but I would advise to try a washer cleaner before going through all the work to dissassemble your machine.
Use the longest, hottest cycle. You may have to run the cycle with a cleaner twice to remove all the built up soap scum inside the washer.
You could check out http://www.smellywasher.com/ for one possiblity. Others are " Washer Magic " or these: 73b1c2a.jpg fb3071a.jpg
If you still want to tackel the dissassembly: The washer front comes off by using a putty knife to push in the two retaining clips on the very top edge, where it meets the washer top. Now you will be able to access the screws which hold the top down. Of course to remove the inner tub, you still have to remove the lid switch, the agitator, agitator drive, the left hand threaded nut below that, the wire connection to the motor, the four tub retaining straps, the tub to pump hose, the four suspension rods, the tub cover and the water level hose. Then you would be able to remove the inner tub and pressure wash out the outside of the inner tub and the inside of the outer tub, if you bring the tub assemble outside. TRY THE CLEANER FIRST !!!!
Aug 16, 2009 | GE WBSR3140DW Top Load Washer
We washed a small rug and we got an E-20 code. what should we do, its having problems draining!
Drain pump screen is clogged. If its makeing a bad grinding sound the pump will need to be replaced. Otherwise disasembly of the machine is required to access pump area to clean out screen. Dextrous people can probaly do this from the back or underneath unit. Its difficult and I don't recomend it to beginers or people who arn't handy. Easiest/prefered method: (This is the one I use.)
Method A units that have a bottom access panel. ie: front panel not one seamless peice.
-unplug unit
-lean back against wall for easy access.
-remove two #2 square screws form access panel.
-Loosen clamp holding hose to tub. (Big black one around 2" in diameter.)
-remove and clean screen.
-reassemble machine and test pump operation.
Method B units the have seamless front panel.
-unplug unit
-remove top. 3 screws @ back, slide top away from machine to remove.
-remove 2 screws holding console onto chasis.
-remove disp
-remove 3 screws @ and behind disp area.
-Remove console. ( tab may be holding to front panel @ middle bottom use putty knife to pry up.)
-remove 4 screws holding front pannel @ top to chasis.
-remove 2 screws holding frong pannel to chasis inside machine. Acess from top. (some models only.)
-remove bottom screws either 4 or 2 usally 4.
-remove two screws holding door lock to front panel
-remove spring from around bellow.
-remove bellow from front pannel
-remove front pannel. Tilts forward and lifts up off supports. (some models only.) or pannel ifs up and off from white tabs in side of chasis.
-unhook wires to door lock from front pannel. (plastic molex tab)
-may now access pump like in method A.
Pump Replacement
-access pump area
-remove drain hose to pump by looseing clamp and pulling off.
-remove hose to tub by losseing clamp and pulling off.
-remove power connection at back left of pump.
-unscrew two philips screws holding pump too base plate. (only one is really required.)
-replace pump
-clean pump screen or add one if not present.
-reconnect hoses.
-replug in power
-reassemble machine
-test pump operation
Jul 12, 2009 | Frigidaire GLTF2940ES Front Load Washer
Machine not spinning properly
The top of the washer lifts up like a car hood after two clips between the top and the front panel are pushed with a putty knife. Once the top is flipped open, the screws that hold the front panel in place at the top can be removed and the panel lifted off. The belt may be bad or something may be stopping the belt like a bad pump. Or the transmission drive pulley and bearing may be going bad. If the bearings above the transmission drive pulley fail the brake will not release correctly in the spin cycle causing weak, slow or no spin. The belt & pulley system can be accessed by tipping the washer back. The belt is routed around all three pulleys under the washer and is fairly loose until the motor starts. It is the torque of the motor that gives the belt tension. Leaking or loud "jet engine" sound in spin indicates a bad main tub seal at the outer tub which has caused the spin bearing to fail. This is a complicated repair as the inner and outer tubs need to be removed from the washer to access and replace the seal and bearing components. Enter your model number into the PartDetective on the Find & Order Parts page to see all the parts available for the unit.
Go here for Magic Chef Washer Parts: http://www.repairclinic.com/Magic-Chef-Washing-Machine-Parts
www.RepairClinic.com
Jan 25, 2009 | Magic Chef CAV2000 Top Load Washer
Dryer vanes came loose... can't figure out how to remove front or top panel to access the outside of the drum in order to tighten the bolts/screws that hold the vane in place.
use a putty knife and about 4 inches inside on each side insert the putty knife between the frount panel and the top and lift up on both sides, the tub will be visable to the screw holes in the tub to reinstall the vanes
May 27, 2008 | Magic Chef Dryers
Jacuzzi 8450-959 Tara Whirlpool Bath 5'- White Logo
489 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
