Won't start back up
I ahve a presario F700 that quit I was on the internet and now I am unable to turn it on.
    President:
  • 1,179 Answers
Power supply may have went bad. You can try replacing psu unit and see if this fixes the problem. Hope this helps.
Posted on Dec 24, 2008
Compaq Presario F700 Won't Turn On
Assuming the unit is plugged in, this could be an issue with the power supply, or an issue where the cord connects to the laptop. If the power connector on the back of the laptop is secure / doesn't feel loose or damaged, you may want to simply get a replacement power supply from a local electronics store. Be sure to take the make and model information of the laptop and the power supply with you to the store.
Jun 08, 2013 | Compaq Presario Notebook
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
DEFRAG C:
CHKDSK C:
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like www.topmic.com
Dec 29, 2012 | ASUS K52n-a1 Notebook
Hp presario f700/f750us, cd/dvd player, won't boot from start up but is listed first in boot order, not recognized by windows either, won't read, write or play. tray opens and light blinks. tom...
Check the jumper settings in the back of the drive, by the power cable. Make sure your cd/dvd drive is set to SLAVE, with your primary harddrive as MASTER. Check BIOS settings, specifically your boot order, choose which drive you want to load first (usually HD 0), save and exit.
That's just the basics, though.
Another possibility is that you might just have a paperweight ;)
If so, try another drive.
Hope that helps
Cheers from NZ
May 17, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
Compact presario f700 laptop will not turn on. It
Was there any power outage in your area and was the laptop plugged in at that time, if so your Motherboard has been fried, your need a new Motherboard.
Jul 19, 2010 | HP Compaq Presario F500 F700 and G6000...
I Have Compaq Presario F700 Note Book I have downgraded it to wondows XP. I am unable to find and install its ethernet & sound card drivers.
This could happen because the drivers for sound and other are not their with Win XP.You require Win Vista for the sound and ethernet drivers.
Regards
Jun 26, 2009 | Computers & Internet
My compaq presario F700 won't boot up.It keeps
seems that same System Files have been damaged. Try starting in Safe Mode or use the Recovery Console from the windows disk to repair the OS.
Jun 05, 2009 | HP Compaq Presario F730US Notebook
Installed McAfee on Compaq Presario F700. IE7 frozed up.
If you have McAfee Internet Security, there could be some settings that have disabled connection. I had this issue with McAfee once myself.
Open the McAfee security center and try to tone down any firewall settings, antiphishing, etc. For me, I turned off antiphishing and firewall altogether and it worked, but maybe not recommended.
Apr 20, 2009 | Sybase PowerDesigner DataArchitect 9.0...
Well, you should be logged on as Administartor, or your profile should have admin rights to install software on this machine...
May 11, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
67 people viewed this question
Alun Cox
David Payne
David Payne
