Question about Maytag Atlantis MDE7400AY Electric Dryer
I need to know how to check if the fuse is bad in my Maytag MDE7400AYW dryer
  • 979 Answers
Check the breaker first in your breaker panel. I am sure you have and also the wiring in the back. The thermal fuse or hi limit fuse is fairly easy to check. It is probably located under the top of the dryer. You can ohm it out or if you don't have a tester, simply bypass the fuse (probably short barrel shape) and then try to turn it on. If it does, then the fuse is bad.
Posted on Jan 21, 2009
My maytag atlantis MDE7400AYW keeps tripping my breaker. Trying to hook up a 3 wire cord.
best call an electrician then only a person with hands on ability can fix it .
Jan 07, 2017 | Maytag Dryers
My Maytag Atlantis MDE7400AYW does not start when I pull the knob and I cleaned the sensor and connection and pulled the panel and checked the connection on the board the damp indicator light comes on but...
There are a few different scenarios which would cause the dryer not to start. First, make sure you door switch is functional. Second, the white thermal fuse, located on the exhaust housing may be open. Worst case scenario would be a defective timer or motor. Either of these may not be cost-effective to replace.
Mar 06, 2014 | Maytag Atlantis MDG7400AW Gas Dryer
I need service manual for maytag dryer mde7400ayw?
Thats a older model and service manuals for it are no longer published. Thier is generic service manuals available at Lowe's HomeDepot and your local public library. However they only cover basics of all dryers and dont get into paticulars of any one brand. What kind of problems are you having we here can guide you through since some of us have extensive knowledge on the Maytag and other brand dryers having been in the field and serviced them for decades
Aug 16, 2011 | Maytag Dryers
Can not locate the thermal fuse on my dryer, maytag atlantis mde7400ayw
Hi khartley317
You will have to remove the back of your dryer andiIt will be located on the air tube.
I will send you to this webpage to see where it is located and you can purchase your part there Please take time to rate me
http://www.partselect.com/ModelFrames.aspx?ModelID=149441&ModelNum=mde7400ayw&mfgModelNum=&ManufactureID=1&Selected=51031&Position=4&mfg=Maytag&Type=Appliance&Mark=4
Jul 02, 2011 | Dryers
Mde7400ayw wont heat up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 18, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE7400AYW timer has been replaced but the dryer won't stop drying on it's own. What is the reason? I have the same problem... the timer on mine doesn't seem to work. Any ideas?
The wire connections to the timer may have not been made correctly when it was replaced bypassing the OFF contact in the control circuit.  There should be a wiring diagram inside the front or back panel that you can check.
Jun 02, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag MDE7400AYW taking 2 or 3 cycles to dry
it's probably your sensor assembly. go to www.repairclinic.com/Appliance-Parts?s=t-MDE7400AY-%3d%3d&z=100 . That is the best possible solution and not too expensive. Good luck.
Apr 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
I pull the knob on dryer Maytag MDE7400AYW and it won't start.
yeathe start switch is bultdirrectly into the timer assembly youll need to replace the timer.
Feb 17, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis dryer mde7400ayw won't run
I believe this last one has it right. the timer may be bad or worse, the board could be bad.
Jan 15, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Removing Timer Knob on Maytag MDE7400AYW dryer
Can anyone help me? I have a Maytag Atlantis that my parents just gave me and my wife. Unfortunately, they accidently removed the model number sticker in the door area. I need to buy a new timer but no one can find which timer to get without the model number. Via the internet, I think I narrowed it down to either the MDE7400AYQ or the MDE7400AYW....but they both look identical to me. Can anyone tell me what the difference between the two is so I can go get the part?
Mar 03, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
151 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
