Question about Acer Aspire 5600 Series 5630-6951 Laptop
No request for help, just an 'ataboy.'
I saw your first solution (Aspire keyboard), very nicely done!
Steve
  • Steve Allison
    Steve Allison Dec 26, 2008
    Nice link collection!
    Thanks for passing it on!
Keyboard and touchpad mouse thing completely frozen. I put in a plug-in mouse and I can move mouse around but can't type any letters or space or any icons on keyboard. Help!!! I have a Acer Aspire...
Good day my friend. The only solution for that problem is for you to also buy a usb external keyboard. As of what we can see you have a defective built-in mouse and keyboard. If you want you could buy a silicon keyboard that not only can be folded but also can be weather proof. I was hoping that this would help you a little. Farewell friend I'm Naldz. Have a nice day.
Aug 17, 2011 | Acer Aspire 5536-5224 Notebook
Help me with aspire 4741Z video or display driver
Hello there.
You can download all needed drivers for your notebook here.
http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=2126
Chose your OS and download drivers.
Sincerely,
Steve TM
May 31, 2011 | Targus Computers & Internet
Keyboard issues
Press the "Number lock" key.
Apr 16, 2010 | Acer Aspire 5500 5570-2609 Laptop
Makita chainsaw DCS5000 overfueling?
As you requested Steve; but you say you have spark.
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
Is the choke open? You have enough fuel you should not need the choke. I think she is flooded. Do you have your OM handy? Might be a good time to review to flooded procedure. Probably similar to warm start with a lot of pulling.
Start Procedure
Cold:
  1. Ignition on/off to on.
  2. Set compression release – optional step even if saw is equipped with a compression release.
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts. (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull).
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 25, 2010 | Makita DCS51018 18" 45cc Chain Saw 2 Cycle
My Acer Aspire 5732Z has a problem wth the keyboard registering, it appears to be random, some keys require several presses before working, on top of that my touchpad has a mind of it's own. I have read...
This is undoubtably the keyboard matrix gone faulty.I replace them all the time, it is pretty easy.. and replacements are about $60 - $90, eBay has them.. You will also need a service manual, link below, to know how to pull the Laptop apart. http://printer1.blogspot.com/2008/03/acer-aspire-368055705580-service-manual.html
Mar 10, 2010 | Acer Aspire 3000 Notebook
Acer Aspire One A0A150 keyboard issue,
Sounds to be you just got a faulty keyboard from HongKong, if your old keyboard works except the the Z and the new keyboard works only with function keys, then it sounds to be that the new keyboard is not ment for your laptop. if anything you should of had the same problems as your old keyboard. try using a USB keyboard.
Aug 17, 2009 | Acer Aspire One AOA150-1983 Notebook PC
Acer aspire 5730z - Keyboard problem
no it will not happen ........but i think once u check it with ur dealer.if it is a brand new u will have warranty....so check it......if there is some problem after checking i can help u....u r requested to cantact me after the check........because this is the ist time i am hearing about this problem
Jul 12, 2009 | Acer Aspire 5720-6661 Notebook PC
Acer Aspire 6920: Broken Keyboard & Mouse Pad
open your laptop keys with nail cutter and see any problem is there
Apr 25, 2009 | Acer Aspire 1640Z Notebook
Scenic non start
Nice one, a lot cheaper than an ECU!
Well done.
Regards
Geordie
Jun 24, 2008 | Renault 181 Cars & Trucks
How to replace keyboard
1. Remove 3 screw from top of laptop. this screw hold power cover (cover which have power button).
2. Remove power cover.
3. remove 2 scews that hold keyboard.
4. that's all, you can take keyboard out from laptop.
i hope this will help
Mar 18, 2008 | Acer Aspire 5002WLMi Notebook
Acer Aspire 5600 Series 5630-6951 Laptop Logo
62 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
