Question about Nintendo Wii Console
Black and white picture
Just set up wii and the picture is in black and white please help!!!
  • janway39 Dec 26, 2008
    Same problem here. New TV also, and now PS2 and Wii are both playing in B/W only. We have ours run through a Philips ConnexHD system that connects multiple sets to the TV. HELP! What did we do wrong in the connections?
  • Anonymous Dec 26, 2008
    I have the same problem. All I can find out is that you need a different connector for HD TV it's called a HDTV Wii Component/Composite AV Cable. Trying to find one I can buy today but not much luck. You'd think it would be written on the front of the box considering how many people are likely to get new tellys over Christmas.
    Not sure it's the answer but seems the only possibility, it works OK on the other telly that isn't HD.
    Hope it helps.
Had the same problem, went to Currys and bought a switchable scart adapter, on the receipt it's called a BELKIN 3 RCASCART ADAPTER £14.67. Plugged it in, sorted. Hope this helps, happy playing.
Posted on Dec 26, 2008
Wii in black and white
Picture Is Black and White or Does Not Appear Situation:
  • The console powers on and shows a black and white image on the television screen
  • The console powers on and there is no image on the television
What to do:
  • Determine whether the Standard AV Cables (packaged with the system) or the Component Cables (sold separately) are being used.
  • AV Cables
    • Ensure the yellow, red, and white cables are connected to the correct corresponding inputs on the TV. (How To)
    • Try another set of inputs on the TV, or hooking the Wii console up to another TV.
    • If the TV does not have the yellow, red and white inputs, it will most likely have component inputs which allow standard AV cable use. Try these AV hookup steps. (How To)
  • Component Cables
    • Ensure the red, blue and green video cables are connected to the correct corresponding inputs on the TV. (How To)
Still Not Resolved:
  • If the television is continues to show a black and white image when powering on the Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further.
Apr 17, 2012 | Nintendo Wii Console
Why cant i get my wii console to work in color
Well it might either be the tv or the av cables that is causing the wii system to be in black grey and white then.
What to do:
  • AV Cables
  • Component Cables
Still Not Resolved:
Mar 06, 2012 | Nintendo Wii Console
Why is my Samsung tv only showing black and white picture?
If the normal TV channels are OK then the wrong input has been selected. Probably set to component instead of composite.
Oct 14, 2017 | Samsung SyncMaster Televison & Video
I have just purchased a used Wii system and every thing works fine except that it is in black and white help.
Hi Anne,
It could be due to the wii's current video settings, the previous owner would have had a TV that ran on different viewing options. The black and white picture is caused by having the Wii settings output at PAL 60Hz and the TV input at PAL 50Hz or vice versa (or NTSC). Try going to the wii settings menu and try a couple of different video settings until the colour comes :). If this does not work can you please post what connection you are using for ex. AV or composite.
Regards,
Omeil
Jan 30, 2011 | Nintendo Wii Console
Just setting it up. the picture is rolling and it
It occurs if the system colour on your tv is set to PAL, and your Wii is NTSC.. To Fix.. Adjust the system color on the tv to NTSC.
Hopefully this help..
Jan 18, 2010 | Nintendo Wii Console
Black & White Picture in different input modes
Can you describe the connections please? I suspect that the DVD +/or WII is outputing component video and you have it connnected to composite video. Please diagram the conenctions.
Thanks,
Dan
Aug 21, 2009 | Televison & Video
How to set up a UK Wii for use in the US
This is because UK wii's use a PAL signal for video display. If your TV does not support the signal, it's always going to be black and white. You might need to try a different TV.
Aug 11, 2009 | Nintendo Wii Console
Problems setting up DvD Play and Wii
TRY DIFFERENT CABLES OR USE DIFFERENT INPUTS. AND BY THE WAY, YOU CAN PLAY DVD'S IN YOUR WII
Apr 05, 2009 | Samsung Televison & Video
Yeh, Ok.
What you need is called a component cable if your TV has 6 ports.
If it has 3, the one your wii came with.
Hope this helped
Dec 24, 2008 | Nintendo Wii Console
Black and white screen
is the TV's color settings set to black and white maybe???
Jun 20, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
150 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
