Question about Microwave Ovens
We used the microwave as a timer by mistake. It shut off by itself. Is it broken?
  • Microwave Ovens Master
  • 9,098 Answers
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
If it did not come back on, chances are the magnetron's thermostat (or thermal cutout, TCO, etc. as they are also known) has failed and will have to be replaced.
You can usually find helpful exploded view diagrams and order parts for many brands by entering your full model number here.
Many brands also have a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If the parts link does not cover your model, please reply back with your brand and model number so we can help you.
Posted on Dec 25, 2008
Microwave wont shut off
there is just a malfuction in the circute board go and get it fixed
Apr 01, 2015 | Danby Microwave Ovens
I locked the timer by mistake. How do I unlock
Unplugged the microwave, and plugged it in again, and the microwave reset itself.
Jan 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
By mistake I started the microwave instead of the timer. Nothing was in the oven. after about 15-20 minutes the microwave heated up and shut down. I changed the 20 amp fuse but it still does not work
I called my neighbor and explained what happened. the first sentance out of his mouth identified the problem and the part I needed to replace. It was a heat switch that I expected but could not find. I even told your incompetent tech that it was something like this but he was fixated on door swithces fwhich I am sure is a stock answere given to him to use for for all problems.
I am asking for and expecting a full refund from FixYa.
Jan 16, 2010 | Amana Radarange Microwave Oven
I THOUGHT I WAS TURNING ON THE TIMER AND WAS RUNNING THE MICROWAVE INSTEAD. IT GOT HOT AND SHUT ITSELF OFF. HELP
If it didn't come back on in 15-20 minutes you blew the cavity thermal fuse you'll have to have a technician replace it.
Aug 19, 2009 | Microwave Ovens
Our stovetop maytag microwave doesnt work anymore
You probably blew out the cavity thermal fuse you'll need a technician to replace it.
Aug 17, 2009 | Maytag Appliances Over-the-Range Microwave...
Microwave wont start but timer counts 3 secs and shuts off
Check the door latch mechanism the black nylon door catch may be broken.
Jun 19, 2009 | Panasonic NN-T993SF Microwave Oven
Microwave won't shut off
the timer is more than likely broken. There are no replacement parts and the mocrowave will need to be replaced...or keep the door open when not in use, and use a watch to keep track of cook times
May 05, 2009 | Sanyo EM-U1000W Microwave Oven
Need the code to reset programing on microwave
Try this first: Unplug the microwave from power source for about 15 minutes and rreplug and see. Make sure that the wall plug is viable. If not, try using a different outlet and see. If both fail, then you may need to get the microwave serviced.
Oct 30, 2008 | Microwave Ovens
Microwave totally shuts off by itself
My microwave is under warranty. I have this problem before and it was "fixed" one month ago by replacing a thermostat. This repaire is under warranty for 90 days.
I will have a service man to look into this problem.
Thanks MK
Jun 29, 2008 | Jenn-Air JMV8196 Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
