Question about Euro-Pro 9000 Mechanical Sewing Machine
I have euro pro 9106 sewing machine. When I try to sew the
Thread gets all in a wad inside the bobbin area and the machine freezes up. I have taken the bobbin out and cleaned everything good. do you have any suggestions?
Make sure your needle is in the down position in the material and hold on to the tails of the top and bobbin thread when you begin sewing.
Posted on Aug 20, 2012
    Problem Solver:
  • 18 Answers
There should be a tension adjustment on bobbin. adjust it until it runs smoothly
Posted on Dec 24, 2008
  • mmmaloney87
    mmmaloney87 Mar 02, 2012
    is that on the side of the machine?
I have a euro pro 9106 it was sewing fine then it started beeping
Here's a manual. The troubleshooting section will frequently provide clues to problems:
Try page 5:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwiuy_bnzbjRAhUKiFQKHZDmA1UQFggcMAA&url=http%3A%2F%2Fwww.sharkclean.com%2Fmanual%2F9106_REV_0104.pdf&usg=AFQjCNEHSJJ0tHPdtDrE1mDs_nWlVWc5dQ&cad=rja
Would suggest removing all the thread (upper & bobbin), cleaning the bobbin area thoroughly, then reloading the threads.
Verify it is threaded correctly.
Jan 10, 2017 | Sewing Machines
Husqvarna classica 105 - won't sew - thread wads up in bobbin area
this is a problem from the needle thread tension not tight enough
tighten the thread tension right up
Aug 08, 2016 | Husqvarna Sewing Machines
Help with Euro Pro 9000, the thread keeps getting tangled up in the bobbin area..
When I had this problem, even though I have been sewing for years, I was just not threading the needle properly. Make sure the presser foot is raised when you thread the needle. Another reason is that the thread is too old, the needle is not the correct size or type for the material, neither is the thread. Hope this helps. It's usually nothing to do with the bobbin, but the upper thread.
Jul 11, 2014 | Euro-Pro 9000 Mechanical Sewing Machine
Euro pro sewing machine 9106
try changing the needle--make sure it's the right type for the fabric being sewed
try rethreading the machine make sure to use every thread guide
make sure the power cord and the foot pedal are securely plugged into the machine
clean under the needle plate for lint and also in the bobbin area
also make sure the bobbin winder spindle is not pushed over to
wind a bobbin
if these suggestions don't help then it would be a good idea to have the machine checked..
Sep 11, 2013 | Sewing Machines
I can't get the bottom thread to come up with the needle on my euro-pro shark intelli-sew
try this
make sure there is a 3-5 inch tail on bobbin thread
make sure there is a 3-5 inch tail on top thread, then hold the top thread tail with your fingers (away from the needle) & with your other hand turn the hand wheel manually on the right side of the sewing machine,, slowly letting down the needle down into the bobbin area & see if the bobbin thread will pick up this way
Sep 25, 2010 | Euro-Pro 9105 Computerized Sewing Machine
I have a Euro Pro model 9106 sewing machine and I need a replacement bobbin cover for it, do you know where I order one
Ihave a Euro PrO 9106, I just ordered that part. They are in Canada yhe phone number is 1-800- 798- 7395 follow the prompt.
Gloria 5-25-10
Jan 25, 2010 | Sewing Machines
Euro pro 385w problems
if your machine is like mine the bobbin is not filling right. My bobbin thread is very loose when it should be tight. I am also looking for bobbin solutions. If I wind the thread around the thread tension guide 2 or three times it keeps the thread tight going to the bobbin winder. I hope this helps
Jun 25, 2008 | Euro-Pro Easy Sewlution 385 Mechanical...
Euro-Pro 9000 Mechanical Sewing Machine Logo
328 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Greg Cann
Greg Cann
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
