I have a 52 inch hitachi projection tv, I cant seem to set the closed captioned feature for digital channels, the remote will only slect analog? how do I set CC for cable/digiatal stations thanks
  • 126 Answers
This is the manufacturers. If it hasn't worked for you yet it proberbly wont. Once they come up with a TV that can do this it will be released for an additional £100 and will be an extra feature of the TV (this is unfortunately how the tech industry works)
Posted on Dec 24, 2008
How do I turn off the closed captioning?
Press the closed captioning button a second time.
Mar 20, 2016 | LG 47LS4500 47 Inch 1080p LED LCD HDTV -...
Can I turn the caption mode off with the remote?
CC (Closed Caption)
To select the options in the CC sub-menu, press the MENU button or the #
button. A new menu will be displayed showing the following CC settings:
CC
The CC feature is available when watching regular analog (NTSC) TV.
Select from CC1, CC2, CC3 or CC4. Closed Caption for regular TV is
usually CC1 or CC2.
Digital CC Style
The Digital CC Style feature is available when watching digital TV.
Select either As Broadcaster or Custom. If Custom is selected then
you can customize the way Closed Caption is displayed.
Feb 14, 2015 | Vizio VF550M 55 in. LCD HDTV
I haven't been able to put closed captioning on tv. I don't understand how and what code to use to get the closed captioning to work.
Enable Caption Using the Original Remote
  1. Press the [CCD] button to change the CCD mode.
  2. Using this button will set the Closed Caption mode when viewing a DTV or TV channel.
Enable Caption Using the TV Menu
  1. Open the Menu screen, select the third icon, in the middle, this is the Setup Menu.
  2. In the Setup Menu, choose the Caption option.
  3. Caption: There are three items in it - Analog Closed Caption, Digital Closed Caption and Digital Caption Style
  • Analog Closed Caption: CC1, CC2, CC3, CC4, TEXT1,TEXT2, TEXT3, TEXT4.
  • Digital Closed Caption: Service1, Service2, Service3, Service4, Service5, Service6.
  • Digital Caption Style: There are two Caption Styles. One is the automatic function set as the broadcaster, while the other is the custom style where you can adjust the font size, color, opacity, background color etc., accordingly.
Mar 10, 2011 | Element ELC-HS321 32 in. LCD TV
Black box on screen
Check your closed-captioning setting and make sure captioning is turned off (or set for captions if you really want them). You'll find it's set to "text" mode right now. The set is blanking out a portion of the screen to display text it never receives, and you'll only see this when you view a channel where captions are being broadcast. Most sets have a button on the remote for captions, and it's easy to switch modes without knowing it. Then you wind up with the mysterious black box.
If this helps you out, please take a moment to rate the solution. Thanks for asking here!
Feb 18, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Does my toshiba model have a digital tuner?
Negative. Here are the specs for your TV/DVD combo: I hope this solution is helpful. Please take a moment to rate this solution.
Toshiba MD13M1 Dvd Type: DVD player - built-in
Media Type: DVD, CD, Video CD
DVD Repeat Modes: A-B repeat, title, chapter
CD Playback Modes: Program play, random play / shuffle, all tracks repeat, one track repeat
Tv tuner Analog TV Tuner: NTSC
Reception System: NTSC-M
Analog Channel Qty: 181 channel(s)
Channel Coverage: VHF:2-13, UHF:14-69, Cable:1-125
MTS Stereo: Yes
Secondary Audio Program (SAP): Yes
Video features Closed Caption Capability: Yes
Closed Captioning on Mute: Yes
Remote control Type: Remote control - infrared
Features: Back-lit buttons
Connections Connector Type:
  • 1 x headphones ( mini-phone stereo 3.5 mm ) - front
  • 1 x composite video/audio input ( RCA phono x 3 ) - front
  • 1 x SPDIF output ( RCA phono ) - rear
  • Composite video/audio input ( RCA phono x 3 ) - rear
  • 1 x antenna ( F connector ) - rear
Jan 28, 2009 | Toshiba MD13M1 13 in. TV/DVD Combo
Black box covers most of screen some channels, plus gibberish.
it is the closed captions on the tv. it is set to closed caption text. turn it off
Nov 24, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Get closed captions on some channels, but not all, even though it is CC
RCA have choices for different methods of CC in user CC menu. Labelled T1, T2, etc. . Different selections are for different types of close caption. Tune to a signal (on your other TV) that has closed caption working.
Tune your RCA to the same signal. Change the T1,T2, etc settings until the closed caption for your signal appears.
If this doesn't work, try connecting analog video or VHF channel 3 (or other specified channel) to the TV. check CC. When TV stations, sat channels, sat receivers, cable boxes etc, convert analog video signals to HD, problems can result. Some equipment causes RCA TVs to do unexpected things with sound and closed caption.
If you use RF or video output, old analog video may look better on CH3 or video than on HD input and the CC will work more consistently. Watch HD signals on HD input, Analog signals on Video in or through the TV tuner . Many HD channels and programs are converted analog video and look poor on TV HD inputs.
easyab
Nov 03, 2008 | JVC AV-48WP30 48" Rear Projection...
Closed caption feature
When you enter the menu for setup, you have to go to another window in setup, use the remote to access next window.
Sep 28, 2008 | Hitachi 50UX57B 50" Rear Projection...
Rca 52 inch rear projection
This is a problem common with some RCA/GE TV's. The fix in the past was to install a capacitor between ground and pin 15 of the microprocessor which keeps a data signal riding on the video stream from muting the sound on most stations. By installing this capacitor, you would be disabling the closed caption feature so that feature would no longer work. An authorized RCA TV repair shop may be able to give you more information.
Apr 12, 2007 | RCA P52940 52" Rear Projection Television
String test
Possibly the closed caption feature on this set has been turned on. There is a button on the remote control that says Caption. Press it until you turn the caption off. This will not be on a universal remote, only the original remote. You can also turn this off through the caption section on your on-screen menu.
Jan 22, 2007 | Samsung PCJ522R 52" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
