Question about Frigidaire FRS26H7 26 Cu. Ft. Side By Side Refrigerator Built in Water / Ice Dispenser
Water filter will not come out of Frigidiare
When i push the botton the filter will not pop out
Water filter pops out when dispenser pad is pushed
I assume you mean the water dispenser here. Most likely, the filter is not seated properly, and the change in line pressure when you push the dispenser pad is popping the filter out of place. You didn't specify the refrigerator, so there are a couple of generic things to try:
  1. There are a couple of water filter types - the push-in-and-click kind, and the push-in-and-turn kind. If it's the push-and-click kind, then there's probably a button next to it. Turn off the water to the line (probably under your sink), push the button to eject the filter, make sure that the o-rings are in place on the end that's inserted. If the filter has been in there for years, probably best to replace it, it's probably clogged but good. Anyhow, insert and eject the filter 4 or 5 times, make sure it feels like it's seating properly.
The push-and-turn ones often have some cap that blends in with the molding of the fridge. Make sure the cap in attached to the top of the filter , insert, and make sure you do the full quarter turn to lock it in place. You should not be able to pull it backwards at this point. Turn it back and forth a couple of times. it should be stiff, but not feel mechanically impeded or jammed. There could be dust bunnies or other floor debris that got pushed in at a previous filter swap jamming things up in there. A crevice tool on the vacuum might help clear debris if it's there (don't do this if water is actually flowing out of the filter spigot )
Try it now (remember to turn the water back on) , that should hopefully fix the issue.
If not, the next generic things to try are:
  1. Replace the filter.
  2. See if the dispenser works without the filter in place. Many fridges have a bypass so that a filter in mid-replacement won't flood the kitchen. If things run ok, try running a couple of gallons of water through. A lot of fridges give you cold water by having a big coil of tubing in the fridge compartment, probably under/behind the vegetable bins. There's the content of a couple of glasses of water in the line, so it's being chilled in the line. If they get clogged, or have some organic gack growing in them, then there'll be more back pressure on the filter when the wall pressure tries to push water through the coil. If things still flow, try running a few gallons of water through the line to see if things will start flowing better. That may clear it up.
If the new filter is still being ejected after running a lot of water through, probably time to get an appliance specialist involved.
Good Luck!
Nov 06, 2015 | Refrigerators
Keep getting error message of nb even though we cleaned the water line filters. What can we do to fix this problem? We have to continually press the start button to continue the cycle.
If the screens are clean and it takes several times of starting it for the machine to start washing the only option left is to replace the inlet valves.
Jan 24, 2015 | Samsung WF337AA Front Load Washer
How do I replace the water filter on my refrigerator?
The filter has either a screw on connector where you can screw the old filter off and screw the new one back in, or it has a push connector where you just push the old filter to pop out and push the new filter in. Here are filters that are compatible with your Kenmore refrigerator.
Aug 07, 2013 | Kenmore Side by Side Refrigerator
Frigidaire water filter keeps on popping out
Hello shebalaba - Thank you for your question and I am happy to assist you. Could you please provide me the model number of your refrigerator or the type of water filter that your unit requires? The serial tag is typically located inside the cabinet on the left side wall. With this information I can better address the issue at hand. Thank you and I look forward to your response.
Jul 02, 2013 | Frigidaire Refrigerators
Frigidiare frs26rlecs2 icemaker not working
Yes sounds like solenoid in valve for ice maker is not opening. Either the valve is bad or ice maker isn't sending voltage to valve.
Nov 18, 2017 | Refrigerators
Frigidaire water filter stuck
We had the same issue. My husband unscrewed the filter cover (1 screw on the left side of the filter under the light flap). Then he pushed the old filter in & lifted it up and it came right out.
Oct 02, 2012 | Frigidaire ULTRAWF Frigidaire PureSource...
Water Filter Cover broke. I cannot get the PUR water filter out. It has a push button but even though I push on it, it still does not pop out the water filter. Do you need the cover to turn then use the...
If there is something on the frost of the filter you can grab onto with plier you should be able to pull out the filter. Withthe broken can the button wont push in since the cap locks into the latch for the filter
These are the part's for the cap all are the same except letter at end indicates color
2260518W white
2260518B black
2260518AP grey
2260518T almond/tan
It could be purchased at your local appliance parts store or online at,
searspartsdirect.com
apdepot.com
apwagner.com
repairclinic.com
midwestapplianceparts.com
Good luck in getting the filter out,
Gene
Aug 17, 2011 | KitchenAid KSCS25IN Side by Side...
Does my refrigerator have a filter for the water??? If so where is it located and the part number for replacement?
you didnt stae how old it is. most of them for your make are in the lower kick plate on the lft. there is a botton to push to make is pop out. it should be changed every 6 to 8m
Jan 10, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
How do you replace the water filter on a Kitchenaid Superba refrigerator. I can find the filter.
under the freezer door there is a nob like thing. turn it and pull on it. instead of replacing it, rinse it out under runing tap water and put it back were you removed it from and push the fridge light botton 5X in a row
Oct 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
Frigidaire FRS26H7 26 Cu. Ft. Side By Side Refrigerator Built in Water / Ice Dispenser Logo
19 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
