Question about JVC MX-KB30 CD Shelf System
Protect Everything seems to work but the sound. The speakers make no sound at all and the display says protect. if i get close to the system i can hear the cd player wiz and make noise when it changes cds and everything else seems to be working too...except the sound =(
  • Anonymous Jun 02, 2008
    i can't hear anything out of my speakers and the screen just says protect
How hard do u need to press with the small screwdriver? I tried this and the white piece didn't feel like it pressed in at all. The system still shows protect also.
Posted on Feb 05, 2010
This solution worked perfectly. Thanks for posting
Posted on Mar 21, 2008
I had the same problem as steve. the protection was on and I did exactly what he posted and it worked thanks steve.
Posted on Jan 02, 2008
  • VictoriaB68 Mar 08, 2011
    I just did this and it worked perfectly!!! I am so excited! THANKS!
I know I'm finding lots of old posts about this JVC model MX-KB30 "PROTECT" problem but - I FIXED IT!!!! 8-) Daugter had the same difficulty after a series of power outages. Figured it had something to do with the speaker circuit board. Decided to look for a reset on the board itself. Not sure that I found one, basically becuase there was not a perception of a button pressing down, but the "PROTECT" cleared and the sound is coming through the speakers again. The sterio works fine. First - as when working on all electronics - unplug the unit and make sure all static electricity has been discharged before working on it. You will need a small jewlers philips screw driver as well as a mirror for looking down on top of the electrical components. Remove the cover of the sterio surrounding the sides and top of the unit - there are screws on the sides, top and around the edges of the back fo the unit related to this piece. You do not have to remove any other pieces. There will be a circuit board attached to the back center of the unit that has a black cable running to the headphone plug and the speaker connections are also running through this board. If you face the front of the unit, looking at the sound circuit board from the right side, there will be a small black - square looking - voltage regulator (I think that's what it is anyway) that you will see some voltage information and some switch setting pictographs (along with the numbers 1, 2, 3). On top of this black unit (here is where you need the mirror) there is a square hole that looks down inside this unit as well as a round hole that you will see white plastic inside. Using the jewlers screwdriver, carefully press on the white plastic once or twice (I couldn't tell that it had pushed down) particularly becuase I have no clue how sturdy this piece is. With the cover still off the unit, plug it in and make sure the "PROTECT" message has disappeared and the speakers are working again. That's exactly what I did and the darn thing started working again. Maybe I just got lucky, but this is a nice sounding unit and it would be a shame to see folks toss it away for such a simple fix if that is indeed what did it. Enjoy!
Posted on Apr 23, 2007
  • Vikram Oct 01, 2011
    Excellent suggestion - worked like a charm. This is a like a 'circuit-breaker' to protect the system against high voltage fluctuations. So press firmly but gently and the white piece goes in and stays in. Thats all. DO NOT push too hard. Important thing is to use the right tool to push the white piece. Again - thanks for this - saved me some $$$.
The display is showing "PROTECT" and nothing (no sound) seems to work. What might be the problem?
It's possible that some of your speaker wring has either become loose, damaged, or is shorting. Perhaps even a faulty speaker. Check everything before you turn it on again.
May 29, 2016 | Onkyo TX-SV414Pro Receiver
Nad av 716 protect
If your NAD amplifier is in protect mode with no speakers connected, it will be necessary to open it up and check for internal component failure.
Jan 05, 2015 | NAD Audio Players & Recorders
Protect comes on why
Hello
Protection display will come over this type of set, when it is overloaded or system confused condition. Just unplug the device from AC mains socket and replug it after 4 to 5 minutes, and see whether it shows any protect display. If it shows it again, just disconnect the output loads, ie, connected speakers, and check. Again it displays 'protect', the internal circuit, especially the output amplifier circuits has the trouble, and the system need service. if it does not show protect display, after disconnecting the speakers from it, check the speakers or its connecting wires for damage. OK.
Jan 20, 2012 | Sharp Audio Players & Recorders
Amp pulses from power to protect
check it without the speakers if they go to protection,and if not check the speakers
May 27, 2010 | Power Acoustik PS4-800 Car Audio Amplifier
"PROTECT" appears on my DENON DHT-500SD
Sounds like a speaker wire is shorting against either another speaker wire or something metallic. Check your speaker wires to make sure they're not shorting (touching). If that doesn't work, I'd take it to a repair facility. Good luck!
Feb 16, 2010 | Denon DHT500SD System
"Protect" and "Push Power"
i have a sony component push power protect, i have already replace IC but still protect push power
May 02, 2009 | Sony Audio Players & Recorders
I have a pioneer 5.1 channel surround sound system and it powers up and everything seems to go fine but you go to turn it up and no sound comes out of the speakers already checked speaker wire connections...
Does the protection relay click 3 to 5 seconds after initial power on??? If not, your unit is staying in "protect" mode to save your speakers because the output transistors or output IC is shorted and sending 40 to 60 volts at your speakers. Not a good thing, but at least it saves your speakers.
Good Luck!
barneyluc
Oct 03, 2008 | Pioneer Audio Players & Recorders
Protect
The protect message indicates that a problem was found in the output stage of the amplifier. Unless this gets repaired, nothing will work. As a verification that the speakers or the wires are not the problem, unplug all of the speakers and try again. If protect still is displayed, the problem is inside the unit.
Dan
Apr 09, 2008 | Sony DAV-S400 System
JVC HX-D77 PROTECT!!!
MAKE SURE YOUR SPEAKER WIRES R CORRECTLY COLOR MOUNTED INTO OR CROSSED INTO THE STEREO
Dec 25, 2007 | JVC HX-D77 Shelf System
System keeps sayin protect
The word PROTECT appears because there is a short. It can be in your speakers, try running it without the speakers plugged, or look if the wires arent shorting. If it stil ldoes that, its cause there is a short in it, from the output section. The system does that to prevent from damaging the electronic components inside.
Nov 17, 2006 | JVC MX-K30 CD Shelf System
JVC MX-KB30 CD Shelf System Logo
390 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
