Question about Volfenhag ZX-8200 Car Audio Amplifier
Do you have instructions for wiring install on volfenhag GX8200??
  • 15,935 Answers
Amplifier Class AB
Number of Channels 2
RMS Power (4 ohms) 120 watts x 2 channels
RMS Power (2 ohms) 200 watts x 2 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 400 watts x 1 channel
Total RMS Power Output 400 watts
Peak Power Output 1000 watts watts x 1 channel
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.1%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
High-Pass Crossover Frequency 40 - 250 Hz
Low-Pass Crossover Frequency 40 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 20A x 2
Posted on Dec 24, 2008
  • blueextc3221
    blueextc3221 Dec 24, 2008
    what are you hooking up?
    More information is required to complete your request
I have a 2000 w volfenhag amp and a 15 in cadence 350/600 rms watt sub, what gauge wire should i use?
I would use a 4 gauge wire for the power supply to the amp and a 4 gauge neg of the amp
Jun 25, 2016 | Volfenhag Car Audio & Video
What size wire should i have for two 12 volfenhag subs
I would use 10 to 12 gauge wiring. As fare as your amp's fuse...Check to make sure you are using the correct amp fuse. Make sure your subs are wired to a ohm load your amp is stable with. Check your ground and positive connections. Check and make sure your amp's gain settings are correctly set. Your amp's gain should not be turned all the way up.
Sep 25, 2012 | Volfenhag ZX-4712 Car Subwoofer
Amp turns on but no green light and no sound
As a pro i have ran into this problem many times,what happens with volfenhag amps the solders on the RCA inputs aren't very good,and what happens is that you get to much current going threw them and they over heat and lose contact,volfenhag will fix it,you have to pay for shipping to them,and include a 12 dollar money order.Volfenhag audio 1-323-588-8571.
Jun 03, 2010 | Volfenhag ZX-8400 Car Audio Amplifier
Volfenhag 2050 staying on prtection mode
AUDIO OUTPUT ARE DAMAGED, CHECK THE SPEAKERS IF SHORTING, WIRES ARE CROSSED...
Oct 14, 2009 | Volfenhag ZX-5007 Car Audio Amplifier
Volfenhag ZX-7160 Car Audio Amplifier owners manual to adjust the frequency also wiring diagram diamartn64@gmail.com
its very easy to hook it up. your best bet is to join www.carstereo and ask your question there.but it is easy to set and hook up amp if you really need help email me
Mar 03, 2009 | Volfenhag ZX-7160 Car Audio Amplifier
12"volfenhag subwoofers
use a 9volt battery, touch both wires to the battery connections, if the speaker jumps upward and away from the magnet, the wire on the positive (+) terminal of the nine volt is positive (Red), if the speaker jumps inward towards the magnet, then the wire on the positive (+) terminal of the nine volt is negative (Black). CAUTION: only TAP the wires to the nine volt terminals briefly, if you hold them on there it may damage the speakers voice coils, (or other parts.) best of luck!
Oct 25, 2008 | Volfenhag ZX-4712 Car Subwoofer
How to wire a volfenhag dual coil sub
U HAVE TWO COILS ONE ONE EACH SIDE OF THE WOOFER, ALL U DO IS HOOK UP ONE COIL TO THE OTHER, THEM HOOK THEM UP TO THE TERMINALS IN THE BOX.
Oct 12, 2008 | Volfenhag ZX-4812 Car Subwoofer
Wiring
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
This should help you;rating please./
Jan 26, 2008 | Volfenhag ZX-4812 Car Subwoofer
Volfenhag ZX-8200 Car Audio Amplifier Logo
348 people viewed this question
Top Volfenhag Car Audio & Video Experts
Robert Rankin
hoyzee1
Morne Olivier
Are you a Volfenhag Car Audio and Video Expert? Answer questions, earn points and help others
