Question about Kitchen Ranges
I have a GE Electric Range, Model:JSP69. The bake temperature is not holding at the level is it being set at. We set it to 380 degrees and it drops to a lower temperature and does not go back to the temperature it was set at originally. The oven is not heating up for baking. Could please advise.
    Problem Solver:
  • 18 Answers
Bad thermostat change it out
Posted on Dec 24, 2008
GE JSP69 Electric Kitchen Range Controller Problem
Yes replace the EOC (electronic oven control) after you verify that the board is getting power (no burned wires, no loose connectors) there usually is not a loose wire and the clock has failed. www3.sears.com for parts i can help with parts lookup and sourcing if needed will need complete model #
Oct 07, 2007 | GE JSP69 Electric Kitchen Range
Bake does not work
you need to call a repair service we do not recommend DIY with gas appliances.Safety reasons
Nov 02, 2017 | GE JGSP23 Gas Kitchen Range
Xl44 spectra oven temp very low
Fixya does not sell parts and cannot recommend sources.
Jul 18, 2017 | GE Spectra JGBP35 Gas Kitchen Range
Amana oven will not hold temperature
First check the temperature probe if that checks out good the problem is the bake element is failing. Here is a couple links on checking and replacing these parts
http://appliancehelponline.com/oventempprobe.html
http://appliancehelponline.com/ovenelementvideo.html
Jun 28, 2010 | Amana AER5712AAS Electric Kitchen Range
Older Frigidaire electyri-clean range Model REG 533 * HD
I wish I had a solution for you...unfortunately I don't. However, if you know anywhere I might find a thermostat knob for this model I would be eternally grateful. I've been searching for 2 years for my mother. It's the knob with 5 settings (off, bake, broil, time-bake and clean).
Jun 08, 2010 | Frigidaire Ovens
WHen I start to bake I get an F3 error
We have a GE slide in oven JSP34. F3 came up while baking. I called the 1 800 number for GE and was told I needed a new over sensor. I ordered it and it arrived and had a local appliance person install it. Seems to work fine.
May 15, 2010 | GE JSP69 Electric Kitchen Range
Not heating properly
There are two possibilities, both of which I think you will need a technician to diagnose. There is an electronic sensor on the later model ovens that sends info to the Electronic Oven Control (If you have a touch panel yours is electronic), or the older ovens use a hydraulic thermostat. The sensor on the electronic model can mess up temperature or it can be the EOC. On the older models, usually there is only the thermostat where you adjust temperatue that can cause this problem. Because you elements get red, they are OK, your problem is in the regulation of them. good luck, AJ
May 22, 2009 | GE JSP69 Electric Kitchen Range
Range will not hold a consistent temperature
Good chance your bake element is out. Could be the element or a terminal burned off.
When you set to bake, normally it preheats which uses the bake and broil element.
When it reaches "near" temp, the broil goes off and the bake takes over.
If the bake element, (the one in the bottom), is not working, the temp will decline.
Check:
Turn to 450 deg.
Watch the elements, assuming you have a door with a glass, and see if both elements, top and bottom, glow red.
MrBoo aka Gary
Nov 11, 2008 | KitchenAid KERC507 Electric Kitchen Range
Adjust temp level of the oven .. model 34ja-5tkxw
Press the bake key.
Adjust temperature to 550 degress.
Press the bake key again and hold it for 3 seconds.
The temperature +/- should appear.
You can then adjust temp +/- 35 degrees.
Mar 24, 2008 | Magic Chef CER3725AA Electric Kitchen...
Kitchen Ranges Logo
150 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
