Question about Dacor Preference RV36 Kitchen Hood
I have a dacor RV36. when i raise it on it goes to high i press medium , low or stop and it just stays on high. i think the buttons are malfunctionaing as the only way to turn it off is to press lower/rise really hard. once press stop , after 5-10 minutes it automatically starts working again, causing us to get up in the middle of the night. any ideas?
  • jeffdm36 Dec 30, 2008
    We have the same problem. Our 36RV goes to full on while raising and does not turn off until in the full down position. Has done this from the first month of purchase.
  • Anonymous May 08, 2009
    We have the same problems ( the slower speeds quit working). Disassembled the top and cleaned the contacts under the control buttons ( on the circuit board) - it worked for awhile then quit completely. Apparently you cannot clean the area around the control buttons with any liquid since it will get down on top of the circuit board and corrode the surface. Bad design-never worked right from the get-go. I would never buy another Dacor product.
    Habit-Forming:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 86 Answers
Need key board and buttons replaced
Posted on Nov 15, 2017
2 Suggested Answers
  • 3 Answers
SOURCE: Raised vent is Rising after being lowered
My RV30S was installed by a qualified service technician in approximately the year 2000. It finally developed a mind of its own. It would raise up and run for a bit and then stop....sometimes it wouldn't raise up or go down....it would switch from fast to slow to stop.....it became frustratingly unusable....
...today i finally took it upon myself to take it apart and I determined that the controller board had fried.
Before I go on -> Disclaimer: These units are hard-wired to live A.C. power. These units must be serviced by technically qualified service personnel. I do NOT recommend anyone to attempt this service. I've worked in the past as an electrical engineer by trade. But to save you time and money you can shop and buy the parts you need yourself and then hire an appliance service technician to safely install them for you. This way they can't rip you off by over charging for the parts and you can certainly count the hours for the install.
The controller board is shown here. In my case, this diode fried.
I found a replacement controller on E-Bay for only $82 bucks and change. At the time of this writing they had 14 in stock.
http://cgi.ebay.com/NEW-Dacor-Vent-Hood-Control-Board-DA-72881_W0QQitemZ120363680495QQcmdZViewItemQQptZRanges_Cooking_Appliances?hash=item120363680495&_trksid=p3286.m20.l1116
It sounds like you may be having the same problem. But please be sure to hire a qualified appliance service technician to do the work. If he quotes a price for the controller board anything over 82 bucks, you will indeed will be in a better position to negotiate a better deal.
Hope this helps anyone that is having or will have the same problem with an older RV30....
Posted on Mar 28, 2009
RV36 , only the highest blower works how do I make the medium and low blower work
Check for power at the mufti selector switch. If you have the correct power at both outputs the low and med windings in the fan are gone. Could also be a bad resistor, if it uses a resitor block to slow the motor instead of windings.
Aug 25, 2014 | Dacor Preference RV36 Kitchen Hood
I need to know how to clean a dacor raised vent
two Phillips screws under side of raised vent removes top complete then switch has plastic piece that slides out with control be careful wires are short and very small easy to break
you will most likely have to change keyboard and buttons
Oct 01, 2017 | Dacor 30" Slim Raised Vent, in Stainless...
Where can I buy parts for my DACOR 36S KITCHEN HOOD?
http://www.dacor.com/GeoLocalisation/Locate-A-Servicer/Default.aspx
Oct 09, 2009 | Dacor Preference RV36 Kitchen Hood
Dacor Pinnacle Raised Vent
Unfortunately i had found myself in this same situation. i have no idea how the grill came out when it was closed, but it was stuck in the fan enclosure underneath the counter. Unlike the poster above i did not have access to the side screws to take the unit apart. instead i was able to remove the front panel, and then unscrew the motor arm from the protective case, and unscrew the case from the unit. This created enough wiggle room that i could raise the right side of the vent cover up and extract the left side out the bottom opening. then it was just a matter of reconnecting the arm to the cover and the cover to the unit.
Good Luck,
-Mark
Jun 15, 2009 | Dacor Preference RV36 Kitchen Hood
I have a Dacor downdraft vent RVxx. I find that 2
I just unplugged it again and replugged it. Now it works. Thanks! Renee
Jun 13, 2009 | Dacor Preference RV36 Kitchen Hood
Hunter fan with remote control was 3 speed, now only 2 speed
It sounds like fan motor is okay. There are two motor windings -- one low speed, one medium speed. Low winding gives you low speed, medium winding gives you medium speed, both windings give you high speed -- so I would say if you get high speed, both windings are good.
The remote (the hand held transmitter) controls the speed by raising and lowering the frequency of the current which is 60 cycle coming to the fan ceiling box. If the fan speed -selector switch (usually a pull switch) is set to high, when the remote (transmitter) signals the receiver to change speeds, the frequency of the current is changed by the receiver (the receiver is usually in the fan housing).
Sounds like you'll need to replace the remote system -- these come in sets, both transmitter and receiver, and cost about $30. If you're not experienced with wiring fans, you should get an electrician to do the job.
Apr 21, 2009 | Hampton Bay 24002 Ceiling Fan
Dec 08, 2008 | Dacor Preference RV36 Kitchen Hood
Pinnacle Raised Vent System #RV36 or RV 46
Ours started doing the same thing. I got it to start working again by gently holding down the up/down button until it started to move. After doing this a few times it started working normally again. Also the keypad can be locked and unlocked by pressing the low and high buttons together for 1 second.
Dec 08, 2008 | Dacor Preference SGM365SS Gas Cooktop
Dacor Raised Vent Buttons reply, sc58@aol.com
There are two small screws on the bottom of the top lip. Remove them and pull out the endcap inserts. The top shoudl then pull up with maybe some light force. Then you can get to all the bottons.
Apr 20, 2008 | Dacor Preference RV36 Kitchen Hood
Dacor Preference RV36 Kitchen Hood Logo
117 people viewed this question
Top Dacor Kitchen Ranges Experts
Steve Allison
Steve Allison
Oloyede Monsuru
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
