Question about ViewSonic VG700 17" Flat Panel LCD Monitor
Relisys monitor keeps bringing up screen setting display.
The screen setting display comes up when the PC boots up and can only be removed by switching the monitor off then on again. It then comes on periodically and can only be removed by switching off and on again. When it comes up it is not working properly. It doesn't work properly at all when you want it too.
  • 126 Answers
Perform a manufacture reset. Please contact the manufactur if this is not in the manual
Posted on Dec 24, 2008
Relisys tl540 problem - NO SUPPORT
Sounds like fit for the bin. Can you slow the refresh rate to 70HX and a resolution of 800 x 600 might work.
Jun 06, 2017 | Relisys TL 540 (Blue, Graphite) 15" LCD...
Flickering and garbeled screen
Try to lower your screen display resolution: you might have to do it under 'Safe Mode' (eg. reboot your computer in 'Safe' mode normally done using the F8 key during the initial boot sequence) as your screen display appears to be unstable/unreadable.
Dec 29, 2009 | Relisys TL 766 Monitor
Horizontal black lines across the screen
you can try contacting Lumaco they are a British monitor repair specialist.
www.lumaco.co.uk
It might even be cheaper to buy a new one.
Jun 19, 2009 | Relisys TL 766 Monitor
Relisys Sound
CJ,
1. Check make sure the audio cable are plugged in from the monitor to the PC output audio jack (light green).
2. Open your on screen display and go to Volume settings. See if it set on mute or set to 0.
3. Turn of your monitor & PC and unplugged all the cables from your monitor and PC wait for 10 seconds and then replugged it all the cables and audio cable back. Then turned on you PC...
4. If it still doesn't work.. open the back cover see if the speaker cable are plugged in.
5. If that doesn't work...then your monitor AD board built-in speakers are defective.
6. Why not just used a external speakers, it give better sound quality.
Have a nice weekend!
Aug 17, 2008 | Relisys RLT1720 17" LCD Monitor
Blank Monitor
Start pressing F8 at boot
When the Windows Startup menu appears, select ENABLE VGA MODE
This will boot the system in 640 x 480 resolution but the video driver will be installed. Once at the desktop, either reset the display to the normal resolution settings or reinstall the video driver.
Aug 06, 2008 | Relisys RLT1720 17" LCD Monitor
Cannot turn off Auto Adjustment... message.
i has same problem and I have no idea how to disable. :(
Hope someone know how to help us out!
Dec 27, 2007 | Relisys TL565 15" LCD Monitor
INPUT SIGNAL OUT OF RANGE
some how your screen resolution has changed above or below what your monitor can display. you need to boot your computer using another monitor that can work with the resolution your computer has switched to(i used a spare crt monitor when it happened to me) change your resolution in display properties to a normal level like 1027x768, and while the computer is on swap the monitor cables to verify the lcd is working.
It is perfectly safe to unplug the video cable and plug it back in while the computer is turnned on.
Dec 26, 2007 | Relisys TL775 17" LCD Monitor
Relisys 17in tft monitor
hi everyone,
i have a relisys monitor and had this exact same problem where the menu screen comes on and then cycles through the various options until it gets stuck in a loop within the colours settings.
- the solution i found is to open the monitor itself. (make sure power supply is disconnected)
- opening the monitor should be fairly easy - i have 4 screws located at each corner of the monitor.
- i have 6 screws which locate and secure the stand.
- once the screws are removed you can prise open the monitor.
- to make this easier start where the monitor comes apart
the easiest and the use your fingers to slowly prise the
rest of the casing apart.
- now examine the circuit board which you will spot quickly as it is the only circuit board visible. The rest is hidden by a steel guard.
- the circuit board is secured with three screws before
removing them make sure your body is free of static
by touching something which is metal and grounded.
- once you have removed the board locate the white connecters which are inserted in to the board.
- the one i disconnected was the one which is concerned with the menu system, which is the small connecter.
- refit circuit board
- refit casing
- refit stand
and there you have it your monitor should now work but with no menu facility, however the monitor will still have the ability to auto reset the screen should it be misaligned.
notes
this is not a complete fix, even though it worked for me it may not work for you, however you could try removing other connections and reseating them. more connections are locating underneath the steel guard inside the monitor.
Mr Jag Singh
Nov 25, 2007 | Relisys TL 766 Monitor
Screens works for 5 mins then goes blank!!!!!
It could also be that the video card is not compatible with this monitor. After the pc boots up, can you get into windows? Does the monitor always go out at a specific time on boot? Say for example; you boot the pc, windows startup splash screen comes on; screen does a quick flash and goes blank. Then it maybe the BIOS setting for the video. Try changing the IRQ setting. You could also try putting the video card in another slot. Do you have the manual for the motherboard? Ray
Jun 20, 2007 | Relisys TL565 15" LCD Monitor
ViewSonic VG700 17" Flat Panel LCD Monitor Logo
60 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
