Question about Amana Dryers
Amana electric dryer model LEA30Aw will not heat
My Amana elctrice dryer stopped heating up. The unit runs fine, but not heat. We cleaned out the filter and the dryer hose, but to no avail. I was wondering if it could be the heating element, or thermostat?
  • Anonymous Mar 16, 2014
    NO HEAT
The heating element measures 10 Ohms at 68 degrees farenheit. Usually if the element is bad, it will measure infinity.
Posted on Dec 29, 2008
  • Annette Warren
    Annette Warren Dec 04, 2013
    WHAT'S A HEATING ELEMENT? AND WHERE IS IT'S LOCATION, CAN I FIX MYSELF
Amana LEA30AW makes loud racket
either a bad blower wheel or you need to change out the rollers and belt pulley
Nov 08, 2013 | Amana NDG6800AWW Gas Dryer
Amana model 2330aww....runs but does not heat up....just started happening, dried one load then it stopped heating up
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 15, 2010 | Amana NDE2330AY Electric Dryer
I have an similar problem with my Amana Dryer LEA30AW.
First Clean out your filter, Assuming the element is okay and cut-out are fine it should run okay, you could also try running it on low heat will take a bit longer but hey if it works great..Good luck
Oct 01, 2009 | Dryers
Amana Dryer model # LEA60AW. Dryer runs but no heat.
check the heating element and the high limit fuse
Jul 10, 2009 | Amana ALE643RB Electric Dryer
My Amana dryer LEA30AW makes a loud knocking noise while running and then shuts down. There is heat. It seems to be worse with a larger load. Any ideas??? Thx
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fo
Jun 08, 2009 | Amana NDE2330AY Electric Dryer
Not drying my cloths . runs but there is no heat
Since the unit will run but won't heat...
The following are things that could stop an electric dryer from heating:
bad heating element(s)
loose, corroded or burnt wire(s)
thermostat(s)
thermal fuse ( not all models )
motor heat switch
timer
selector switch
The older the unit the more likely it's heating elements or thermostats
Sorry....this can take some time to diagnose
Apr 10, 2009 | Amana ALE866SB Electric Dryer
Blowing high limit fuses
Check the blower wheel attached to your motor.
It may be free-wheeling causing too high a temp thet is blowing the fuses.
Feb 22, 2009 | Amana ALE230RAW Electric Dryer
Amana Electric Dryer runs but does not heat up - model ndw2330ayw -
I HAVE AN AMANA DRYER MODEL LE8217W2 ITWILL COME ON FOR A SHORT TIME AND THEN CUT OFF. I CHANGE THE BELT, THE MOTOR AND THE THERMOSTAT. THE DRYER STAYS ON , BUT WILL NOT HEAT UP. WHAT'S NEXT ???? PLEASE HELP!
Nov 05, 2007 | Amana NDE2330AY Electric Dryer
Dryers Logo
806 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Marvin
Marvin
Are you an Amana Dryer Expert? Answer questions, earn points and help others
