Question about Disney 13" TV
Parental lock my daughter got a hold of the remote and set the parental lock and i cant watch dvds without entering the code. how can i change the code?
  • Sion Buckler
    Sion Buckler May 11, 2010
    what is the model number off the back & the manufacturer ?
The default password is 1111. or try 5963
Posted on Dec 25, 2008
Need to know how to remove the red key on tv and code
When a red key appears in the lower left corner of your Apex television screen, the set's V-chip is engaged, preventing you from watching restricted content. You can override parental controls and reset your television's pass code with your remote.
Parental Lock
  1. The Apex prompts you to enter a 4-digit code when you set up parental controls. You can block programs according to their MPAA ratings or their content designations, such as V for violence or S for ****** situations.
Disabling the Lock
  1. You can override parental controls on most Apex models by simultaneously pressing the F and mute buttons on the remote control. If you own Apex models GT2011J or GT2011S, hold the remote's display button for ten seconds. The red key will vanish and the V-chip will unblock your program.
Override Codes Apex's default parental lock control code is 6688, so if you haven't set a new code, entering 6688 will remove the red key and unblock your program. If you've set a new password and forgotten it, entering 3308 will reset the code and unblock your program.
Sep 25, 2012 | Apex Digital Televison & Video
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
Parental lock code has been lost how can i unlock and reset code
Without a model number I'll have to list several solutions.
Push Vol Down and Chan Up on the set at the same time, Then go to password screen and enter 0000.
Reduce Vol to minimum and hold Vol Down on set and Vol Down on remote.
Hold Vol Down on TV while pushing "TV" button on remote for 3 seconds.
With TV OFF, press and hold Vol Down on TV and "Clear" on remote for five (5) seconds.
Press "Menu" button on TV and "TV" button on remote for 3 seconds.
Some models use the Vol Down button on remote instead of "TV" button on remote.
With Remote go to Parental Menu and enter 2211 for code.
Go to parental Menu and press Mute, Display, Clear, Reset in sequence on the Remote.
Press "Menu" button on the set and Vol Down on Remote for 3 to 5 seconds.
With remote go to parental screen and press Chan Up and Vol Up on the front of set for 3 to 5 seconds.
Jun 05, 2010 | RCA DRD485RG DirecTV DTV Receiver
I apparently put on a parental lock, don't know the code and want to be able to watch dvds. Is there a universal override code?
When you get to the password input screen, press the select button. The text should change from Enter Password to Delete Password. Then enter the code 7-4-4-4 . From there you can set a new level and password for yourself.
Dec 15, 2009 | Sony PlayStation 2 (PS2) Console
Parental console control 2 watch dvds
ok when it asks for the password enter 7444 that should reset it if that dosent work hold select well you enter it
Mar 27, 2009 | Sony PlayStation 2 (PS2) Console
My niece set the lock code and forgot it. How do I unlock it so i can watch my regular rated R movies
On your remote enter 73856525000100X (replace the X with your region code then press info key. These instructions come from www.dvddemystifiziert.de/codefree or you can google on "unlock rca dvd players and you'll see the site to click on that shows all the different models and instructions for each one and the ones that cannot be unlock.
Nov 17, 2008 | RCA RC5220P DVD Player
Ps 3 cant show dvd's
If the DVD or Blu-ray Disc™ (BD) cannot be played, or the picture is distorted: Back to top
  • When outputting DVD content or PLAYSTATION®3 system format software in SD resolution, only discs recorded in the NTSC standard can be played.
  • If the PLAYSTATION®3 is connected to a VCR or a combination TV/VCR unit, copy protection encoding on some DVDs and BDs may cause image distortion, or may cause the image to become lighter or darker. In such cases, connect the system to the TV directly.
  • If the DVD or BD does not match the region code set in the PLAYSTATION®3, it cannot be played.
  • Some DVDs are preset with parental control restrictions. Enter the password that was set in "Security Settings" to temporarily increase the viewer age restriction level.
  • Some BDs are preset with parental control restrictions. Enter the password that was set in "Security Settings" to change the parental control level.
  • The BD may be disc-locked. Enter the password that was set when the disc was created.
if that does not work then call Sony at
1-800-345-7669 (SONY)
Mon - Sat 6:00AM - 8:00PM PST
Sun 7:00AM - 6:30PM PST
Good Luck,
-Rel
Apr 19, 2008 | Sony Playstation 3 (PS3) Console
Parental control code>>>>>
load without disk in drive when browser pops up choose version setting
look in there
Mar 20, 2008 | Sony PlayStation 2 (PS2) Console
PLEASE HELP, PARENTAL LOCK CODE ESA DVD/VCR COMBO UNIT
this is a new thing on dvds. must reset.
Feb 25, 2008 | Televison & Video
Most of the stations are blocked!
Welcome to the wonderful world of the vchip. Making better babysitters through tecnology. From what I understand the control if placed in a ram and cannot be reset without the password. I would call RCA and talk with a tech there might be a generic unlock code like on the old playstations. You may have to prove you are the rightful owner and over the age of 18.
Jul 30, 2006 | RCA E13319 13" TV
Disney 13" TV Logo
Top Disney Televison & Video Experts
Jaime Hernandez
Chris Goulet
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
