Question about Honeywell Programmable Thermostat Heater
Honeywell heater works only on 1st start
I have a Honeywell heater i'll set my thermostat to 76 and ill turn on the heater and it would turn on... but when it get to 76 it turns off so when the temperature drops down and the heater clicks back on all i get is cold air .. it only works on the 1st time what to do ?
  • 700 Answers
You have a heat pump is not worjking right probebdue to the heat pump is not working. Go outdside and look at yopur unit. if it has a red button that shouldbe outside go ahead and push it and then go inside and check to see if your filter is clean. try this suggestion and if it does not work go ahead and get ahold of me . Thanks for using FixYa. Merry Christmas
Posted on Dec 25, 2008
Honeywell thermostat "In Recovery" Message?
In recovery only shows on programmable stats. It refers to the adaptive recovery when using the programming. Over time the stat will learn how long it takes to cool or heat to the programmed set point. For example, if during the day the programming is set to 80?, and at 4:30 the programming drops to 76?, if it takes 2 hours for the temperature to reach 76?, it will learn that it takes 2 hours and eventually it will start turning on at 2:30 so that at 4:30 the temperature is satisfied instead of at 6:30, at which point it is no longer in recovery
Aug 05, 2014 | Honeywell Heating & Cooling
At what temperature do I program the thermostat for a comfortable cooling(at how much do set the cool and h ow much should I set the heat). Thanks for your help
Normal settings are heat 70 and cooling 74 to 76 I like 76 if your not active its fine. They say the every degree above 70 heat cost additional 5%.
Jul 02, 2011 | Honeywell Programmable Thermostat Heater
My thermostat is set to 73 degrees when i get home at six it is set at 75 during the day when im not home the past couple of days it wont get to 73 it actually goes up to 76 77 it is working cool is on why...
may need charged a out of adjustment can cost lots is it old unit is outdoor temp. very hot may have trouble catching up to setpoint.on a 95 degree day good luck.
Jul 07, 2010 | Honeywell Electronic Programmable...
A/C not turning off
may need to check frean in unit it may be low if it runs to lone it will freez up
Sep 20, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
I have a 2 year old paloma tankles heater i get a c4 76
Make sure the wire connecting the thermostat to the unit is 18 gauge solid copper thermostat wire
Aug 16, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Honeywell Thermostat RTH7400D
The thermostat will not cut off the A/C until the thermometer reading gets to 76.
If there is not a heat source near/behind the thermostat which is causing the thermometer to read higher than actual room temperature, it sounds like the thermostat thermometer is out of calibration.
There are ways to calibrate it, but much to involved to go into here.
One solution is to just set the thermostat at 80, knowing that it's really set on 76.
Another solution is to replace the thermostat.
Charlie
Aug 14, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Does this thermostat have a delayed start setting?
You will have to have the installer manual and go into the con fig settings to change Honeywell.com
Jun 16, 2009 | Honeywell Electronic Programmable...
Heat pump that just blows cool air
is the condenser operating? what is the outdoor temperature? A heat pump is a cooling system with a reverse gear, most reversing valves which make this possible fail to the heat mode so it is not likely to be the problem. You should have either gas or electric back-up heat. If you switch to emergency heat do you get warm air? Really need to find out more to make an informed guess at your problem, the simple stupid would be is the circuit breaker to the condensing unit possibly tripped or shut off?
Dec 18, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
91 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
