Question about Freezers
Freezer outer & inner liniers separated
The outer liner is molded to roll around the front & fit/adhere over the inner lining on the freezer front. For about 6" - 8" (vertical) the liners have pulled apart. What type of adhesive should I use to repair/glue the liners together? There is a clear sticky adhesive that is original - reminds me of silicone caulk. Sears Parts Direct does not carry the adhesive and their technicians are told they cannot answer questions on such a matter - I would have to make a service call.
I would greatly appreciate help.
Thank you.
  • 2 more comments
  • sjhigh1 Dec 29, 2008
    I appreciated the quick response; however, I have a couple questions...
    1. It is my understanding that different epoxys are made for specific surfaces/materials (such as concrete, glass, metal, etc.). What type of epoxy do I need?
    2, I don't think I would know a "good" epoxy from a not-so-good. Would you please give me a few brands to look for.
    I await your response. Thank you!
  • sjhigh1 Dec 31, 2008
    I appreciated the quick help. It will help me get a task off my list. Now I just need someone who has time to do it for me :-)!
    Genius:
  • 1,239 Answers
Hi
Liners are not able to be replaced. Will need to buy a new unit if the liner is a problem.
Posted on Dec 27, 2008
  • ABHISHEK.C
    ABHISHEK.C Dec 27, 2008
    .You would be better served to remove the doors, ready fridge to move,( empty, un-plug ) . Remove front grille, un-plug wiring to door dispenser, follow water line and un-couple at water valve, then two people remove phillips screws from top of unit have second open door and lift off bottom hinge. you can then remove lower hinge if necessary for clearance.It took me longer to type than this process takes. And to remove handles involves removing door liners, don't go there.
    Sergeant:
    Novelist:
  • 327 Answers
  • 837 Answers
A good 2 part epoxy is all you need
  • Jay Glendenning
    Jay Glendenning Dec 31, 2008
    3m scotch-weld plastic adhesive
How do I get information on existing chest 659083
Chest freezer not very hard to fix. I would remove the relay from the compressor and check for bugs or rattles and clean the prongs. If that was ok i would bypass the control hot wire it straight and see if the compressor comes on. If it runs and not cooling chances are it lost freon and isnt worth repairing because lines are inside the molding between cabinet and liner.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 22, 2016 | Freezers
HOW DO I REPACE D00R SEAL
To replace your seal you'll have to remove the screws around the perimeter of the door's inner panel. Once all the screws are off separate the inner panel from the old seal and peel the seal away. It should peel away easily- if not use a Putty Knife to remove it.
Now take your new seal and "soften" it up a little by placing it in hot water for 10 minutes or so. It'll make it easier to place back in the correct position around the door since the seal was probably all twisted up and sharply folded doing shipping/storage.
Now simply lay it back in the same position the old seal was making sure there are no folds, creases or cuts in the seal. It must lay flat or it will leak all over again. Note: there is a sealant that you may want to get that's specially made for these seals to guaranty the seal gaps are filled and the seal stays in place. I use "Kitchen and Tub" Caulk when I don't have any refrigerator caulk available.
Now reassemble the door inner panel, your new seal, and the outer door all together with the screws you previously removed and you're all done.
If you need more info an excellent source is "Appliance Parts Pro". http://www.appliancepartspros.com/parts-for-frigidaire-ffu14k0dw0.html
Click on your Seal (item #1) and see the comments below that other customers asked.
Hope this helps.
Jun 27, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
Philco Freezer - replace/repair seal & plastic around top
Good day,
Unlikely you would be able to repair if the inner liner is coming apart.
A local appliance parts house may be able to supply universal gasket to fit to the machine but again, if the inner liner is bad it could prove to be fruitless.
Oddly enough, if you visit supermarkets you will see chest type freezers with no top at all.
Seems like a terrible loss, but it's not.
Cold air falls, hot air rises. When the freezer generates cold air it doesn't spill out the top. It settles into the bottom of the freezer, and stays there. Likewise, warm air rises and has no interest in going into the freezer cavity.
Bottom line. Very little loss.
If appearance doesn't matter, and you can get it close, you should be able to continue to use it.
Your choice, but I thought you would like to know the physics involved here and how it does or doesn't affect you.
Mar 28, 2010 | Kenmore 12.8 cu. ft. / 362 liter Chest...
I have an upright freezer and replaced the rubber gasket around the door. It is not sealing correctly and ice is building up and also, water is leaking from the bottom of the door. It is a Fridigaire...
ice on top of freezer door they came out with a fix but does not work two vent holes on bottom of door seal mthem off with silicone moisture getting in if that don't work you need to take liner off and spray foam the liner cavities
Jun 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Door doesn't close properly, leaks water
If the door seals are still pliable and intact there are two possible causes.
1/ The upper door hinge on the top of freezer unit has two adjusting screws under a plastic cover/cap which allows the upper hinge to be set forward or back altering/adjusting the spacing of the door seal to the freezer body. Moving the hinge outward at the top will cause the door to seal tighter at the bottom and lessen escaping cold air and condensation to form (water droplets). Adjust carefully so as not to create a weak seal (air gap) along other sealing edges of the door frame.
2/ Many United Refrigeration Commercial Freezers are manual defrosting. Moisture from inside the freezer can condense between the inner molded door panel (door shelves) and the exterior metal door. Usually ice buildup will occur in this space, but when defrosting or during high ambient temps the ice will melt and drip out along the bottom door edge/seal. Screws alomg the door frame (hidden by the door seal) hold the seal in place and also the inner molded door panel. The inner panel can be removed to replace the seal or to remove the ice buildup.
Jun 04, 2009 | Freezers
Chest freezer lid repair
if your freezer has the sping etc in each of the hinges, then yes take them off. If your freezer has a torshon bar type spring, DO NOT take the hinges off, as you will not get it back together
i have always replaced liners with the door attached. The lid of the freezer is going to bow out of shape when you remove all the screws and take the old lining off, so you need to replace the lining and leave the screws loose so you can realine the door bit by bit.
it is a bastard of a job, and i wish you all the best.
May 01, 2009 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Chest freezer ices up quicker than it should
if the box has mold between the seal and liner the the seal isn't the main problem, the main problem is the liner is bad and by time you got both parts if you can it would cost more than to replace the freezer.
Larry
Nov 25, 2008 | GE 5 cu. ft. / 142 liter Chest Freezer...
Loose handle
yes , on most freezers the door inner panel liner needs to be removed , that will sometimes require the removal of the door gasket that may be old to the point where it to needs replacing. then finally you can get to the back side of the door and snug up the screws that hold the handle from the back. usually fine thread screws. be sure to apply loc tite and snug up good , we don't want to do this again any time soon. you can take a chance and try pulling out the handle and cutting the screws and then drill the hole in the handle out to where you see a hole in the side of the handle from the front, then counter sink the hole and use a drill screw or a small toggle bolt to resecure the handle . no real wires or refigeration tubes in the door, so its an option. good luck
Nov 24, 2008 | Freezers
Thermostat differential on a Bev air ef48-1as
Having to manually defrost an automatic defrost system tells me there is a problem with your defrost timer. Most Beverage-air freezers have a Paragon timer. There are two dials on these timers. An inner and outer dial. On the inner dial is an arrow to indicate the direction of rotation as counter clock wise. On the inner dial is a copper pointer indicating duration of the defrost cycle.
Observe the copper pointer, no movement indicates that the timer is bad.
Jun 24, 2008 | Beverage-Air 44.9 cu. ft. / 1271 liter...
Up right Amana Deep Freezer
Try taking a small piece of solid copper wire strand, loop over defrost heater and extend into drain hole, this is a trick we use to help with this issue by bringing a little heat around the hole. The freezer may be manufactured by Woods Inc, a canadian appliance builder. These did have lots of problems with the water building up between the inner and outer liners, Not much you can do with these either to totally resolve this issue. Make sure the water is going into the drain pan when you pour the hot water.
Jan 01, 2008 | Freezers
Freezers Logo
41 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
