Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
TV will not turn on.
My RCA d52w23 will not turn on. Every time I press the on button It just makes a high pitch zip sound three times (the sound is not very loud). The light blinks three times at the same time the zip sound is made. After that nothing! The picture never comes on, and there is no other sound. Any suggestions?
  • chrisdaw Apr 13, 2009
    My Mitsubishi rear projection tv will not turn on. The green power light illuminates for 2-3 seconds then goes off. Any suggestions
  • RCA Master
  • 5,138 Answers
On the Deflection board check capacitor cp150- 2200uf 16v if it is puffed up on top it is bad,replace 2 other caps in same circuit also cp114- cp120 -220uf 35v. they are green with gold writing on them.
Posted on Dec 25, 2008
When I press the power button the tv will make an attempt to come on, then go back off. it would do this about three times then stay off. each time it makes an attempt to come on, it would make a high...
The high pitched whine is indicating there is a deflection board issue which is preventing the set from powering up. Rplacing the deflection board should solve the problem. You can get the deflection board from www.tvrepairworld.com
Aug 09, 2011 | RCA HD52W140 52" Rear Projection...
My RCA d52w23 will not turn on. upon turning power on (either by front button or remote) the green light comes on 3 times and makes a mousey squeek. please help!!!!
there can be a few things that can cause this problem
take the back off and on the board on the left side look at the caps there ae 4 of interest three are radial pc mount and stand up the tops may look puffed up those will need to be replaced
locations i think are c140 c120 c114
the check solder ar the .082 200 box cap in the base circuit of the horizontal output transistor
that will most likely take care of your problem
Nov 09, 2009 | RCA D52W23 52" HDTV CRT TV
Tv turns on and off three times
sounds like the flyback which is a 259296 flyback. You can get the replacement flyback at the following link with free instructions
http://servicemanuals.vstore.ca/
May 13, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD61LPW42 - no picture
I haven't worked on an RCA DLP but have on Samsung DLP, based on your description it sounds like the color wheel is bad. Take the back off and turn on TV make sure its not a fan making the noise ,but most likely its the "wheel" it is inside the light engine probably right next to where the lamp is plugged in. If the whine comes from this area definitely the wheel.
Apr 26, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Won't power on
my d52w19 chassis itc222 as posted most of the time wont turn on and the green light flashes three times every time it makes a small noise. sometimes it does turn on and you hear a little pop and the tv fires up.  latley there is a really high pitch noise that will slightly change pitch if you move the tv or put slight pressure on the top or botttom rear part of the chassis. thanks for the help as I have seen that this has been posted before without mention of the high pitch noise.
Aug 23, 2008 | RCA D52W19 52" Rear Projection Television
56 inch RCA rear proj T.V.
Sounds like the capicator on the high voltage is swelled,removing the back cover,make sure to unplug the unit first,there is a u shaped heat sink about middle ways of the board,inside that heat sink is a cap,it will be swelled on top of it,its a 2200 35v cap.
Jan 05, 2008 | RCA D56W20 56" Rear Projection Television
Distorted picture on RCA LCD TV
if that's a dlp unit they are garbage ive had two and both died in same manner in less than a year one the bulb blew on in three months after purchase then went blank and started making a high pitched squealing sound had to argue with rca2.gif cust support after repair shop said they could not fix it rca finally sent me a new one but with less features after i argued with them for another three that one did the same thing after three months now rca wont even talk to me and ive got a 100lbs paperweight that does nothing i was told it was the light engine at a cost of around a grand for part so don't waste your money on a repair shop mine is still sitting there blank and i understand this is a common problem from checking the web just roll it in the back yard spend you money on one that will work im going lcd this time and i do houseld appliances not tvs so dont worry about rating me i like to pass this info on every chance i get just to help my friends at rca
Oct 28, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
318 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
