Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Burned out projection lamp
How-where to you start to replace the bulb. Just bought bulb.
  • 320 Answers
The best instructions for replacing your lamp can be found in the owner's manual. You can get a free copy by copying the following web address into your browser:
http://www.docs.sony.com/release/KF50WE610.pdf
Posted on Dec 27, 2008
How to change bulbs in a safescan 65
read your owner manual section troubleshooting or how to replace it.
God bless you
Rear-Projection TVs have a lamp, which picks up the picture and projects it on the TV screen. A burned-out or connected lamps are two of the most common problems for Rear-Projection TVs. First, you will want to confirm the bulb is still good. If the bulb is bad then then replace it immediately. Second consult your user manual and verify the lamp and lamp cover are installed properly. Most Rear-Projection TVs have warning light which notify you when there are lamp problems. Again consult the user's manual to see what each light means.
Nov 03, 2013 | Televison & Video
Bulb or Ballast?
If your old lamp is still working fine and the new lamp is not, then you bought a defective lamp. Get your money back or exchange the lamp.
May 17, 2012 | Panasonic PT-52LCX66 Projection Television
Burning smell after i replaced lamp
have a expert examine the set to make sure there is no safety issue here and if not the set may have got some plastic so hot that is what you are smelling.
Apr 04, 2012 | Samsung HLP6163W 61" Rear Projection...
I have a JVC-HD projection TV model 56G786 and all of a sudden it will not power on. When you try to turn it on the blue light on the power button goes on but after a few seconds it starts flashing and...
The JVC 56G786 users manual will not give you a clear or specific answer about confirming bulb failure with the LED lamp or power indicators located on the front of the TV.
If the TV was operating normally for an extended period of time (months or years) and will not start, the problem is almost always bulb failure. If the "Lamp Replacement" warning previously appeared "On-Screen" and the TV will not start, bulb has failed.
The first step in a "no picture" situation with a JVC LCD Rear Projection TV is bulb replacement. There is no way to measure the bulb. Sometimes the bulb is visibly broken or damaged when it fails. Remove the lamp cage and have a look.
The JVC Lamp Gallery has all the JVC models and lamp numbers listed. There is also a link to DIY JVC bulb and lamp installation.
If a good bulb is installed correctly and the TV still does not start, you need a technician. There are no user serviceable parts other than the bulb. Failure of ballasts, power supply boards or controller boards is rare in these TVs.
easyab
May 05, 2011 | JVC HD-56G786 56" Rear Projection HDTV
Sony wega kdf-55e200,
If you get just lamp without housing be very carefull you do not put your fringers on Lamp it will leave print and burn into lamp wear plastic gloves to replace this way
Sep 06, 2009 | Sony Grand WEGA KDF55E2000 55" Projection...
Bulb keeps burning out
There are several reasons for short lamp life. Inadequate ventilation or clogged cooling fans, a bad lamp driver or lamp ballast (they are the same) and the use of non-original Sony lamps, as the aftermarket replacements are known problem causers. Remember too that the number of times the lamp is turned on and off is a BIG factor in how long the lamp will last.
Nov 13, 2008 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Just replaced dlp lamp
From what I remember, when you turn on the tv, use the remote and when it asks if you replaced lamp say yes.
Jul 26, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
61 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
