Question about Toshiba Satellite M45-S169 Notebook
Toshiba Satellite M45-S169 CPU Upgrade
I have been doing a lot of research after recently acquiring a M45 laptop (after repair of the once-dead motherboard, the C2 ceramic capacitor next to CPU was shorted and replaced, also replaced the Mosfet surface mount IC), and so far there is no documentation, no resource guide, nadda as far as hardware upgrade for the S169 model. Apparently wasn't an option for this model, may dissuade from their premium models at the time. The processor is a SL8MN Celeron 380 M 1.6Ghz 400FSB Dothan core with a 21watt power consumption rating.
Then given these numbers to go by, would it be illogical to assume that the SL8U6 with almost identical specs (except for cache, 200Mhz higher clock frequency and the expected VCC increase) would be able to run on this setup? In maybe a minor flaw would be the core speed remain at 1.6Ghz, however that would still not be enough to negate the performance of the system. TDP is still the same 21watt.
With that being said, has anyone had any experience with the M45-S169 or M45-S1691 with upgrading the CPU? Don't worry about my experience, if I can repair the motherboard on this laptop (which ran me a whole $9.50 shipped from Ebay) I think I can more than qualify for a CPU swap. :)
  • jsr0828 Dec 29, 2008
    Luckily it is a Micro-FCPGA (non-soldered) socket, however the chipset supporting the 533Mhz FSB is unknown, the higher end models used the Intel chipset compared to the ATI chipset on this laptop.
  • Arthur Dlugokenski Feb 19, 2009
    Curious if you swapped out for the pentium and ditched the celeron, I have upgraded acers and dells running amd chipsets, which m45 has ,but not seen any info with intel ,,or toshibas,
    My daughters m45 could use some pentium power in hers,
    Thanks
    Problem Solver:
  • 8 Answers
I have a M70 with Celeron 390M, I was able to replace it with a Pentium M740 1.73ghz/533fsb, the Bios is able to detect the new CPU but once Windows XP is loaded, it's running at 798mhz (133mhzx6) with multiplier set at 6 instead of 13. I heard so much about Speedstep suggestions, but I set the power seting at the highest, but all test resulted with CPU running at 798mhz at all time. Any more suggestion?
Posted on Apr 07, 2009
    Genius:
  • 1,066 Answers
The chipset will support pentium M processors and some pentium 4 notebook processors. the bios should recognize the processor's new speed and should be able to support a 533mhz fsb. as long as your celeron is not soldered to the socket, you should be fine with the upgrade.
Posted on Dec 24, 2008
Toshiba satellite m45-s169 will not boot windows
Windows is corrupted or the hard drive has issues, if you have a cd installation disc try a fresh install, if no change! the hardware needs to be checked for possible replacement.
Apr 14, 2012 | Toshiba Satellite M45-S169 Notebook
How do I change the CMOS battery in a toshiba Satellite M45-S169 laptop
open keyboard then check look bettery there
please click yes for vote
Jan 15, 2011 | Toshiba Satellite M45-S169 Notebook
Hi, I re-installed the hard drive on this laptop (Toshiba Satellite M45-S169), but the hard drive is unresponsive. Not sure if I installed correctly, or the hard drive is dead. The power light comes on,...
If drive not spinning, definitely dead. If spins and not recognized by laptop cmos, the logic board on drive is toast.
Afraid that you have a nice cute paperweight.
Sep 03, 2017 | Toshiba Satellite M45-S169 Notebook
I only had about 30 hours on a Toshiba Satellite M45-S169 laptop when I put it in it's bag about 5 months ago. Recently got it out to use and have no power. Doesn't seem to be the power cord though as...
take out the battery. plug the AC adapter w/o the battery in. make sure the power outlet is working. you should see a light indcator. test if you can boot it up.
Hope this helps...
Sep 08, 2010 | Toshiba Satellite M45-S169 Notebook
Hard drive crashed need replacement can you give me a part # for a compatible upgrade toshiba satellite m45-s169
Actually you can put just about any size in there. The only thing you need to do is match the connector style. (that takes care of anything else) There are two type SATA and EIDE SATA is the new style and you can get a 500gb drive (and bigger ) EIDE is the older style and has a block looking socket. SATA looks like a tab. On the label on your dead drive you should see a diagram and it should say sata or eide.
Now as long as you get the same connector as your old drive you can get what ever size of drive they have. So this is a good time to spend $10 more and get a 160 or a 320 instead of the 80. The brand does not matter as long as the conenctor and type are correct. I put a 160 in a old A70 I had as there was only a few dollars difference in the prices.
Aug 13, 2010 | Toshiba Satellite M45-S169 Notebook
I need the M45-S169 manual
Was just looking for that myself - found the Toshiba manual here. Toshiba's site is useless.
Mar 05, 2010 | Toshiba Satellite M45-S169 Notebook
Satellite M45-S169 - will not POST or power on. Power light comes ON for a few seconds then goes OFF. Power ight cycles ON/OFF six times then stops.
Hi rich caller i had this problem also with my laptop toshiba satellite M45-S169 and i find solution for this problem..
Just replaced ram memory and now my laptop works fine hope yours will work too
please respond if my msg helped you..
regards
Bess
Apr 03, 2009 | Toshiba Satellite M45-S169 Notebook
Memory upgrade
The M45-S169 only has one available memory slot.
(I'm confused about your post that states "M45-S265" in the head line).
  • Configured with 512MB DDR SDRAM (both memory slots may be occupied)
  • 512MB(min)/2048MB (max), 256MB on-board memory with 1 available memory slot for 256MB, 512MB, or 1024MB PC2700 DDR 333MHz SDRAM 2.5V SODIMM memory modules
You can find the complete specifications here.
Jan 05, 2009 | Toshiba Satellite M45-S265 Notebook
Need a driver for a toshiba m45 s169
here is a link to toshiba's Vista support page, you can search for the proper drivers by model number. http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/navShell.jsp?cf=su_windows_vista
Dec 15, 2008 | Toshiba Satellite M45-S169 Notebook
I need a mother board for a M45-S169
laptop mobo's are proprietary, you will have to go through toshiba or a liscensed toshiba repair shop.
Nov 04, 2008 | Toshiba Satellite M45-S169 Notebook
Toshiba Satellite M45-S169 Notebook Logo
901 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
