Question about Sharp VL-Z5 Mini DV Digital Camcorder
Dont know why it is saying DEW
I have not been able to use this product because everytime I put a tape in or try t take pictures, it shuts off after DEW shows up on the screen. It has never been exposed to water or anything and it is frustraring. I have taken out the battery and the video and left it open incase it was moist inside for some reason, but still displays DEW. Please help
  • 2 more comments
  • abz64 Mar 05, 2008
    The (red letters) DEW keep on turning it off when i turned it on. What should i do? It has never been damaged.
  • Feymov Apr 10, 2008
    I have this exact same problem! Why would this show up out of the clear blue sky? Any way to fix without sending to repair service?
  • Anonymous Jul 14, 2008
  • Anonymous Feb 23, 2009
    camera shows dew all the time.
The DEW error is a known dry-joint manufacturing flaw on the camera's PCB. I solved my DEW problem by resoldering the electrical contacts on the dew sensor and my camera has been perfect since (was useless before). Soldering the sensor wires is quite tricky as you have to dismantle the camera to reach them but a decent hifi repair shop shoud be able to it for you. The dew sensor is in the lower right hand corner if you look inside the open tape compartment door.
Posted on Sep 06, 2008
A forum about the Dew Message problem is at:
http://sharpdew.ning.com/
Go to: http://ataplow.googlepages.com/sharp-dew-problem
Sharp DEW Problem
Many VL-Z series (1,3,5,7) cameras show a DEW message and shut down
even when there is no excess moisture - Sharp's recommendations don't
work and the camera is useless till repaired. Commercial repairs are
expensive and often more than a new camera would cost. There may be a
simpler and less expensive way.
After posting on a few evaluation sites, I have had hundreds of
requests for the message below.
A FIX FOR THE SHARP VL-Z DEW MESSAGE
Go to: http://ataplow.googlepages.com/sharpdew.jpg for a picture
from the perspective of the tape cover being at the top of the
picture and the rest of the camera at the bottom. The dew sensor will
be on your left.
(If clicking on the link doesn't work, just copy and paste it into
your browser)
Get a real slim soldering iron with a fine point. Open the tape cover
and take the tape out. Get a strong light to shine down into the mechanism.
If your camera is like mine was, you may see a brownish material on
or around the solder joint - if you do, this is flux used in
soldering which was applied too heavily, and not heated long enough
to burn off. Not all cameras have excess flux, but if you are
getting a DEW message when there is not excess humidity in the area,
the chances are that the solder joints don't quite connect the dew
sensor to the terminal post - depending upon heat/cold ambient
conditions, sometimes it makes contact and sometimes it doesn't .
Before you start, remove the two batteries - the main battery and the
little CR2016 battery located under a small plastic slide at the
upper right of the battery compartment.
If your eyes happen to be elderly like mine, I put on one of those
magnifying head-bands (not absolutely necessary if your eyes are
normal.) Heat up the soldering iron - make certain the point is
tinned (has a thin film of solder on it). Carefully just touch each
solder joint for a couple of seconds - just enough for it to
melt, and then quickly remove the soldering iron. You don't want to
leave the iron in contact with the solder too long or it may melt other
insulation around the terminal. You are just touching each joint
separately, don't solder them together. This all probably sounds more
complicated than it really is - but it's actually just a 5 minute operation.
The following useful soldering tip was posted on a review site (by
someone code named Deadsharp.) " Because the soldering job is a bit
tricky, even with a dedicated circuit board soldering iron I made a
temporary extension by wrapping a short length (about two inches) of
#12 copper wire around the tip. This tip extension can be inserted
past the tape carriage with no danger of hitting the delicate plastic
bits. Worked like a charm."
If you've not done much soldering, and feel uncomfortable about
trying it, you may want to take it to a radio, tv or computer repair
shop and ask them to do it for you. Of course, reinsert the batteries
when your done.
Here are a number of TEMPORARY fixes which have been reported:
1. A couple of people reported that they were not secure about taking
a soldering iron to their camera, so just poked the contacts with an
ice pick or screw driver, and it began working again. Try this when
you are away from home and suddenly the DEW Message comes on. Remove
the batteries, poke the contacts, & reinsert the batteries.
2. Sometimes just removing the small CR1216 battery which keeps the
time display, will get it working again, though most report it only
works for a little while. When you remove the main battery, this
little battery is located under a small plastic slide at the upper
right of the compartment.
3. One person reported that out of desperation he put the camera in
the refrigerator for 4 to 6 hours and that it began working again. My
experience is that there is a better connection when the camera is
cold than on hot days, however this too, is probably not a permanent fix.
4. Another said: I wrapped aluminum foil around the contacts in order
to lower the resistance and it worked. Accomplishing the same thing,
another person said, "Just run a bead of solder between the contacts
and essentially cut the dew sensor out. Worked on my camera." I
haven't tried either of these myself, so would appreciate feedback
from those who have found it successful.
5. Another person reported cleaning the contacts with a cotton swab
soaked with alcohol (mineral spirits) , got his camera working again.
6. Just recently on our new forum, someone had success placing a
small magnet near the dew sensor for a minute or so, and another
reported it worked for him as well.
You may want to try some of these other reported fixes, however
re-melting the solder joints is more likely 'the long term fix.'
What I've put above is just my experience and that of others.
A disclaimer - this worked for me & I have reports that it has worked
for many others. Like me you will be trying it at your own risk - I'm
certain I voided Sharp's warranty, if they have any. Of course your
camera isn't working now, so there isn't much to lose, is there?
Good luck and let me know how it worked out for you.
Peace,
Alan
ataplow@vtlink.net
Posted on Oct 26, 2008
    Sergeant:
    Champion:
  • 326 Answers
The reason for DEW problem can be that the sensor for DEW has changed its value. Please contact your nearest Sharp Service for the repair price estimate. If you need more info please advice.
Posted on Apr 13, 2007
Everytime I turn my camcorder on the screen shows Dew and then it turns off. I left the battery out for a few days but it still is shutting off
There is sensor inside the unit that will detect dew. Moisture inside will cause the tape to adhere to the heads, causing damage to both the tape and heads. With the unit open, try pointing a hair dryer at it from a distance of about 12"-18". The warm air should remove any moisture. Please be careful NOT to aim really hot air into the unit.
If that does not resolve the problem, then either the sensor is defective or the connections to it are broken. The camera will err on the side of not functioning in order to prevent damage.
Keep us posted,
Dan
May 23, 2011 | Sharp Viewcam VL-Z3U Mini DV Digital...
Dew detected
If you contact Panasonic, they will say to remove the tape, use a hair dryer (low setting) for about 5 minutes and then leave it opened overnight.
or you can try
to put the camera in a plastic bag with the tape door open and insert a silica gel bag (that you find in shoe boxes). Close the plastic bag and leave it overnight. The next morning, the video camera should start working! This is something that an owner tried that worked without the manufacturer's help.
Hope it works for you, too.
Let me know if you need anything else
Mar 31, 2008 | Video Cameras
It won't stay on
The solder joints to the DEW Sensor are "cold joints" which means that the solder joint is defective - is not a sound joint. This means that with temperature variation, the solder joint can intermittently separate and break the circuit, causing the DEW Indicator to come on and completely shut down the camera.
Here is a picture from the perspective of the tape cover being at the top of the picture and the rest of the camera at the bottom. The dew sensor will be on your left.
go to:
http://omlets.tripod.com/sharpdew.jpg
Get a real slim soldering iron with a fine point. Open the tape cover and take the tape out. Get a strong light to shine down into the mechanism.
You may see a brownish material on or around the solder joint - this is flux used in soldering which was applied too heavily, and not heated long enough to burn off. The joint therefore doesn't quite connect the dew sensor to the terminal post - depending upon heat/cold ambient conditions, sometimes it makes contact and sometimes it doesn't .
Heat up the soldering iron - make certain the point is tinned (has a thin film of solder on it). Carefully just touch each solder joint for a couple of seconds - just enough for it to melt, and then quickly remove the soldering iron. You don't want to leave the iron in contact with the solder too long or it may melt other insulation around the terminal. This all probably sounds more complicated than it really is - but it really is just a 5 minute operation. If you've not done much soldering, and feel uncomfortable about trying it, you may want to take it to a radio, tv or computer repair shop and ask them to do it for you.
Feb 20, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Bypassing dew sensor on a Sharp VL-Z7 mini DV
- the solder joints to the DEW Sensor were "cold joints" which means that the solder joint is defective - is not a sound joint. This means that with temperature variation, the solder joint can intermittently separate and break the circuit, causing the DEW Indicator to come on and completely shut down the camera. The first problem I had with the camera was on a cold day, so it seemed to make sense.
go to:
Then, get a real slim soldering iron with a fine point. Open the tape cover and take the tape out. Get a strong light to shine down into the mechanism.
If your camera is like mine was, you may see a brownish material on or around the solder joint - this is flux used in soldering which was applied too heavily, and not heated long enough to burn off. The joint therefore doesn't quite connect the dew sensor to the terminal post - depending upon heat/cold ambient conditions, sometimes it makes contact and sometimes it doesn't .
Jan 25, 2009 | Sharp Viewcam VL-Z7U Mini DV Digital...
Dew
Model: VL-Z800 Sharp ViewcamZ
I was in Shanghai in Dec 2008 over Christmas and I experienced the 'DEW' problem. The cassette tape door would not close either. I did not experience this before even after 2 years. I suppose the cold & the rain water causes the dew to accumulate in the CAM.
Solution.
I did the reset by taking out the small tiny battery situated just above the big battery. The small battery has a cover. Pull it up & Get the small battery out and the whole camera resets. Re-entering the date & time is the only inconvenience. After reseting, I could use it again, but not for long as the problem comes back. When I came back to Malaysia (Temp 32-34 degrees celsius), the DEW problem disappappers.
You could also try this method to get rid of the dew. Buy a small sack of rice. Yes rice, the uncooked ones. Cut open a small opening just big enough to put your CamCorder into the sack. If you do not want to get your CAM dirty, wrap the CAM with tissue paper. Close the opening with a musking tape and leave it a few days. The dew should disappear from the CAM. It works for mobile phones too when it is accidentally drop into water. Of cause you should not switch on the mobile when it is still wet. It will self distruct if you do. Try the rice solution for a week before you on your mobile.
Rgds/ T.S
Dec 17, 2007 | Sharp Viewcam VL-Z1U Mini DV Digital...
Dew detected eject tape
I have the same problem with my PV-DV103. Panasonic wants more to TRY and fix it than the camera cost new. MY advise can the camera and buy one without the DEW option.
Thats what I am searching for presently . If the manufacturer says the camera has a dew indicator in the circuit - buy elseware.
Nov 13, 2007 | Panasonic Palmcorder PV-DV203 Mini DV...
I get the DEW indication and cam shuts off
try to dry up your camera using electric hair blower drier, dew is present inside your camera, but dont overheat the unit, place your hand between drier and cam to make sure you are not overheating it. if the trouble is still there, the sensor is defective and you need pro fix.
Sep 28, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Where is the reset button on this camcorder, Panasonic PV-DV203 Mini Dv? I can't find it. Also what do it do about everytime i turn the camers on it says "DEW DETECTED EJECT TAPE" There is no...
I haven't used mine for over 2 years because of the mildew detected warning and not being able to find anyone to fix it for me. I just found this on the internet and am going to try it when my battery charges. Seems this is a common error for these palmcorders... good luck! "When you get the "Dew Detected" sign on the screen, remove the battery, give it a good palm hit on the bottom where the battery sits. Hit it a couple good times, put the battery back in and voila it will work guaranteed! I thought it was dumb at first, tried it and it works, hell it works everytime. The blow dryer, plastic bag trick dont work because its an electrical error, not actual dew."
Jan 05, 2007 | Panasonic Palmcorder PV-DV203 Mini DV...
Dew
the only thing I can suggest is resetting the camera by removing the tape and closing compartment... then remove batteries and let sit for 3 minutesturn on camera and insert tape, you should get it to work... my cam does the same thing, I use it and right when something important comes up I get hit with the dew warning.. apparently its a faulty sensor inside the camera usually I can override it by resetting the camera. I hope this helps in any way, i know the frustration with these damn camcorders, it will be the last dv cam I buy from sharp
Nov 14, 2006 | Sharp Viewcam VL-Z3U Mini DV Digital...
DEW indicator / battery
The solder joints to the DEW Sensor were "cold joints" which means that the solder joint is defective - is not a sound joint. This means that with temperature variation, the solder joint can intermittantly separate and break the circuit, causing the DEW Indicator to come on and completely shut down the camera. The first problem I had with the camera was on a cold day, so it seemed to make sense. Here is a picture from the perspective of the tape cover being at the top of the picture and the rest of the camera at the bottom. The dew sensor will be on your left. go to:http://omlets.tripod.com/sharpdew.jpg (if clicking on the link doesn't bring up the picture, copy and paste the link into your browser) Then, get a real slim soldering iron with a fine point. Open the tape cover and take the tape out. Get a strong light to shine down into the mechanism. If your camera is like mine was, you may see a brownish material on or around the solder joint - this is flux used in soldering which was applied too heavily, and not heated long enough to burn off. The joint therefore doesn't quite connect the dew sensor to the terminal post - depending upon heat/cold ambient conditions, sometimes it makes contact and sometimes it doesn't . If your eyes happen to be elderly like mine, I put on one of those magnifying head-bands. Heat up the soldering iron - make certain the point is tinned (has a thin film of solder on it). Carefully just touch each solder joint for a couple of seconds - just enough for it to melt, and then quickly remove the soldering iron. You don't want to leave the iron in contact with the solder too long or it may melt other insulation around the terminal. This all probably sounds more complicated than it really is - but it really is just a 5 minute operation. If you've not done much soldering, and feel uncomfortable about trying it, you may want to take it to a radio, tv or computer repair shop and ask them to do it for you. A couple of TEMPORARY fixes which have been reported: 1. Sometimes removing the small CR1216 battery which keeps the time display, and apparently also powers the dew sensor will get it working again, though most report it only works for a little while. When you remove the main battery, this little battery is located under a small plastic slide at the upper right of the compartment. 2. One person reported that out of desperation he put the camera in the refrigerator for 4 to 6 hours and that it began working again. 3. Another said: I wrapped aluminum foil around the contacts in order to lower the resistance and it worked. 4. And finally, another person reported cleaning the contacts with a cotton swab soaked with alcohol, got his camera working again. You may want to try some of these other reported fixes, however remelting the solder joints are more likely 'the long term fix.'
Oct 14, 2006 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sharp VL-Z5 Mini DV Digital Camcorder Logo
540 people viewed this question
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
