Question about Okia / 450-Watt / ATX / 80mm Fan / 20/24-Pin / Power Supply (OKIA450ATX) Power Supply
My computer turns on but wont turn hdd all the way on it starts then clicks and stops goes to a black screen. and there is a smell coming from the computer. i put the hdd in another tower and it worked.. so my question is i have a Okia ATX300 and need to replace it...but haveing trouble finding one. can i buy one with more watts as long as the plug fits
    President:
  • 1,179 Answers
If you have a standard atx case then any standard atx power supply should work. Yes you can upgrade to one with more wattage as long as it has all the connectors you need. Hope this helps.
Posted on Dec 24, 2008
HP pavilion ze4600 XP operating system safe mode etc. will not load CD restore does not work either? help
Firstly hdd's shouldn't click. Purchase a new hdd set your BIOS to boot from CD drive, install XP from your disc.
Dec 05, 2014 | HP Computers & Internet
Aspire 5349 Windows 7
harry not a joke but this happen many a times.
dont know d reasons. but try with win xp.
Format c drive properly.
then if you want upgrade with win7..
Dec 17, 2012 | Acer Computers & Internet
My laptop will not come on it makes loud noise them when I push esc key it stops. It will not bring me to the screen to login my password. When I turn it off launch starting up repair comes up,It won't...
As you said it is making loud noises, most probably your Hard Drive (HDD) have failed.
Mechanical HDD failure will result your HDD making noises, and your will not be able to repair your system using software. You have to replace the HDD.
As for your important data on your HDD seeking professional help will be an option to retrieve your valuble data, but it is quite expensive.
May 16, 2011 | Microsoft Windows Vista Ultimate Edition
Computer turns on but windows does not load after the page that says acer press f2 for setup screen goes black and lights stop flashing. Tried to start in safe mode still wont go just comes to screen that...
Well in the start up process this is really what happen the first couple second of the computer starting up...
the first couple seconds after hitting the power button it does a hardware check..
All hardware passed it proceeds to the software check the drivers and stuff...
if the computer comes to a black screen after start up, or any weird writings, then basically some hardware didn't pass the test and failed causing the start up to fail...
If thats the case i would recommend taking it into a local repair store or calling manufacturer if still under the standard 1 year warranty...
nothing to lose, but a welcome screen to gain, give it a shot...
Jul 29, 2010 | Acer Aspire One PC Notebook
HP pavillion dv2700 clicking noise, black screen
try to run the hdd test in the bios page and see what it says. if it says no ide device found, try to reseat the hdd.
Apr 26, 2010 | HP Computers & Internet
Computer wont recognize external hard drive
try to format the external HDD using command prompt..... type "cmd" in start & search box and hit enter... command prompt will be opened... Now type "format X:" where X=your external hdd drive letter.... if it does not format then right click on my computer icon> goto manage >select Disk management> select the external drive> right click and delete partition > again right click and select create partition > again right click and select Format drive.....
this will fix the issue....
Apr 20, 2010 | Western Digital My Book Essential Edition...
My webcam starts to work then the screen goes black how do i fix it?
Hope you had the webcam unplugged from your computer whilst you installed its drivers.?
Delete the cam & let system re-install it. Start- My computer- right click-properties-hardware-device manager. Find your webcam, right click & uninstall it.Turn your machine off & on(webcam unplugged) When system powered up, plug your cam in & follow wizard instructions.
Oct 01, 2009 | Linare Desktop, AMD Sempron 2200,40 GB HDD...
Wont turn on
www.crackberry.com will help, just search in the forums for "recover a dead blackberry"
Jul 30, 2009 | RIM BlackBerry Pearl 8100
Sampo Flat Screen Black unless unplug and plug back in
i had the same problem now my monitor wont even turn on if i do that the power light just keeps blinking maybe its a sign of a dying monitor
Jan 16, 2009 | Sampo PD-70 15" Flat Panel LCD Monitor
Okia / 450-Watt / ATX / 80mm Fan / 20/24-Pin / Power Supply (OKIA450ATX) Power Supply Logo
128 people viewed this question
Top Okia Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Okia Computer and Internet Expert? Answer questions, earn points and help others
