Question about Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW)
The compressor cycles on and off all the time.
The freezer is still working at the moment
  • Frigidaire Master
  • 4,655 Answers
Possible door seal leak, Temp. Control not working, so please answer these questions and I'm sure we can resolve the problem. Let me know, Thanks Sea Breeze
Click links below
http://www.applianceaid.com/refrigerator.html#freezing
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Posted on Feb 01, 2009
Why does my upright freezer runs then kicks off, runs then kicks off?
Good Afternoon Friend,
I understand your Frigidaire freezer runs for a short time and then kicks off. Then it turns on with a click and repeats its cycle. This is how your freezer functions. When it needs to cool, the compressor will kick on and cool until the temperature is reached. Then it will kick off until it needs to cool again. It's possibly due to the hot and humid summer that it is cycling on and of more. I hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire Freezers
Defrost cycles
Defrost cycle usually comes on after about 7 hours. If it is happening every 30 minutes or so, the defrost timer is not working properly and your internal temperature will never have a chance to go down to zero as SOP.
When defrost cycle comes on, the compressor is automatically shut off and internal freezer temps can go up by close to 25 degrees or more. It is for this reason that commercial freezers do not have auto defrost - the latter extols a price, convenience at the price of higher average temps and less time to properly store foodstuffs in freezer.
Nov 20, 2013 | Freezers
Compressor cycling
chattering relay can cause compressor to over heat. replace that first and see if that does not resolve your issue.
Jun 06, 2013 | Hoshizaki Freezers
Electrolux freezer ffu14fc6cw0 will not cycle compressor
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Electrolux 21.0 Cu. Ft. Upright Freezer -...
Amana freezer has run well for 40yrs. Had weather related power outage for 6 days. Now freezer won't run. Is using about 125 watts, compressor is hot, pressing ear to cabinet reveals "something" is going...
What often happens in an outage like that is you get a rapid on/off cycle about three times or so... This puts extra stress on the compressor because the pressures do not have time to equalize before the compressor tries ot restart. Considering th age of your compressor either that or a low voltage situation was the final straw for your compressor and it died...
The best you can do at this point would be to allow the compressor to completely cool, as in unplug it for 12 or more hours, then try to plug it back in to restart it, it sometimes works...
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 24, 2009 | Amana Freezers
Delfield Mdl.6151 freezer
If the thermostat will let you set that high of a temp, you probably could use it. Let me give you a few things to think about. At higher temps, the refrigerant pressures could cause the compressor to work harder which would shorten the life. The unit will also have shorter run cycles which could over work the compressor. Shorter run times will affect the humidity of the conditioned space. Bad thing if you have fruits and veggies in there. You will have to eliminate the defrost cycles. No need to have "Forced" defrost at cooler temps. I am not a big fan of using equipment for things other than what it was designed for. So, you can try it and keep an eye on how it performs. Good luck and hope this is of some help.
Jun 03, 2009 | Randell 47 cu. ft. / 1331 liter Commercial...
Can not get temp. below +10 f
what is your superheat and is defrost cycle working
Jun 19, 2008 | McCall Freezer 7-7045FT
Kenmore
when its running how hot are the sides the starting amps are too high and 1.5 running amps ain't bad now the the cut in cut out are too high if you look on the dial that the mid point settings that's where you should have it not on 1 1 is hot set it on the straight line that's where you should do all your testing colder settings go up not down you could be overheating the compressor by making it come on too quick the freezer should be about -10 or so do you see any gaps in the gasket
Mar 31, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
61 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
