Question about HP Officejet 4110 All-In-One InkJet Printer
Scan/Copy does not work properly
Scan/Copy leaves half the page tinted yellow. I think the scan head (or what ever it is called) may be bad.
  • 100 Answers
Yes the posibility or cartridge head going bad is more also remove n check whether cartridge is not empty.
Posted on Dec 24, 2008
Equally spaced lines across page only on color copies
If not in the direction of the paper feed then in the direction of the scan head. Dirt on the scan head or bad scan head or scan head connection. Send it back.
Nov 15, 2013 | Konica Minolta Bizhub C284 Color Copier /...
Error message with canon mx410 "cannot scan from adf"
I fixed this by changing the Copy Intensity from Auto to Manual
I had the same paper jam (caused by pressing Stop during a page going into the ADF), but I had pressed OK as instructed and the page was auto fed back out again. Then I couldnt copy from ADF after that.
I tried everything, and then started to retrace my steps of all the things I might have tinkered with to try and get the copying working in the first place, before the paper jam.
Then I remembered I had set the Copy Intensity from Manual to Auto (thinking Auto is always best). With hindsight, it now makes sense for it to be manual with the ADF as otherwise how would it load a page, use it to set auto density, and then reload it again for the actual copy to occur. This happens okay on the flatbed scanner as it can scan a little, work out the settings, and then scan for real.
Copy Intensity is reached on my Canon MX from the Menu button at the bottom left of the front panel. - Then press the right arrow twice to get to Color Intensity. - Hit OK. - Then right arrow from "Auto" to "Manual Adjust"- Then pick a setting or leave it as half-way between light and dark- Press OK
Now every time my ADF copying works a treat. Thats what I get for tinkering in things I didn't need to change in the first place. I was just trying to get a quick copy going from ADF to paper without saving a file up on the computer and then printing.
Aug 09, 2012 | Canon Pixma MX410 All-In-One Printer
My HP laserjet 3050 when i copy a page the paper prints black
Symptom: Black or Blank image while copying or scanning.
Part suspect rating: Scan head..70%
Scan head cable...25%
Formatter...5%
For tech guys only: Remove ADF unit from the printer, remove both side covers of adf, remove & replace scan head, check...
Replace scan head
Jul 21, 2012 | HP LaserJet 3050 All-In-One Printer
When I press the black or colour copy button on the printer the page comes out blank. The printer works normally otherwise.
Check scan head movement while copying/scanning..if its not moving check scan head gear assm any breakage? replace it. If its moving properly and giving blank image scan head faulty(which is moving forward & revers wile scanning or copying) replace it..
Sep 07, 2011 | HP PSC 1215 All-In-One InkJet Printer
Konika Minolta Copier prints half dark pages
If it is only causing an image problem when you copy and not when you print, then there is something wrong with the optics under the glass. Check and see if you have any mirrors out of place or if the scanner looks crooked. If you have the machine set up to scan try and scan to SMB or email to see if it still has the problem. If everything looks correct under the glass and scans to SMB and email look bad like the copies, you may have a bad CCD assembly, or a bad board.
May 10, 2010 | Konica Minolta Office Equipment & Supplies
Lines on copies and scanned images
I would type it all out but hp has a great little document - complete with pictures!! The issue is that there is something on the small strip of glass that is used for the feeder and needs to be cleaned.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00671260&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Jan 15, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp scanjet2300c scans have a yellow tint and black patches.
The best way to check if the scanner is okay or not is by installing on another computer. First try B&W, then try color. IF it works may be your OS or driver (of the old comp) is corrupted.
S. Mohan
Dec 22, 2008 | HP ScanJet 2300C Flatbed Scanner
Copier problem
1. If it doesn it when you print and copy then you have toner on the laser **** glass.
2. If it does it only when you scan then you might want to check for dust buildup on the mirrors or your laser is going bad. I dont think it's the laser though.
3. A bad drum can also cause ghosting and so can a bad fuser.
Suggestion: give it a good cleaning, check the drum and fuser for wear. Make a copy and print off the counter page or something. Compare the two.
Mar 20, 2008 | Ricoh Aficio CL2000N Laser Printer
Hp 7310
If the color cartridge doesn't print the color bars on the alignment page (either, redish pink, yellow or blue) then the alignment process will not finish. Same for the black. If the black cartridge is printing ok, then replace the color cartridge and try this again...
Jan 08, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Scanning document leaves streak down right hand side
Even a single grain of dust or a single strand of hair on the scanning glass will cause the scan head to perceive ink/image where there is none. Deffinetly try cleaning the glass using a good window cleaner, and a cloth that is completely clean, or even a peice of newspaper. If the black line remains, I would suggest taking it into a service center to have the scan head itself cleaned.
Dec 05, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP Officejet 4110 All-In-One InkJet Printer Logo
50 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
