Question about Dishwashers
I have an electronic operating Kitcheaid Dishwasher. It has a tendency to stop in the middle of a cycle without warning. This can happen at different times of the day and at different stages of washing. We open the door, make sure the racks are pushed in tight and close and hold the door tight for a few moments. The dishwaser comes back on, but this can repeat in the course of one wash.
    Sergeant:
    Champion:
  • 338 Answers
I would try adjusting the strike which is a little metal piece coming off of the tub that goes into the door when you close it. the strike may not me latching properly
Posted on Dec 25, 2008
Dishwasher stopping mid-cycle, water left in bottom, sometimes detergent dispenser does not open.
Man I love posts like yours. Makes answering easier.
In short, yes. You probably are right that the dishwasher is aborting mid-cycle, but the why is a tricky question. There are wet parts inside as well as moving parts and high temperature. It is possible your control electronics are being exposed to moisture mid-cycle, causing the dishwasher to cut out. This would have been easy to spot by the technician though. An alternate theory could be that the dishwasher's door sensor is stating that the dishwasher gets opened mid cycle due to all the shaking around. This wouldn't have been picked up by your technician and would cause the dishwasher to effectively "pause" itself without draining or using soap. Check and make sure the door is latched securely and see if it's easy to trigger the door sensor (pull gently on the door while the dishwasher is running).
Unfortunately, the best answer I have for investigation is to "babysit." Grab your laptop, pop in a movie, get a nice drink, and plop yourself down next to the dishwasher once you set it to run. The moment it stops working properly, take a look at everything you can.
Oct 01, 2015 | KitchenAid Dishwashers
Blanco bfdwc61ss dishwasher wont finish washing in any cycle...its doesnt stop, just keeps going and going...it went all night without stopping and the dial didnt move...can you advise what to do??
please see the causes and fix it: God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. Check the tutorial and the video for checking this part.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer / electronic control.
Jul 21, 2012 | Dishwashers
My MDB8951 dishwasher stopped working after interrupted the cycle
Go to your electrical panel and, disconnect the power to your dishwasher for about 1/2 hours when you repower it your DW should be reset
Jun 12, 2009 | Maytag 24 in. MDB9150A Built-in Dishwasher
Bosch SHU3300 dishwasher stuck on hot water intake (w/ no power)
It sounds like the fill vlave is stuck open. This can happen if your pressure is low or if the machine is old. I would start by replacing the vlave.
May 12, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishwasher stops before the cycle is complete
Hi Lou.
Sorry to hear of the problem you area facing, please allow me to try to help you.
There is no singular reason as to why your dishwasher stops before the cycle is complete. There are many reasons why this problem could arise. Below you will find a number of reasons as to why your Dishwasher stops before the cycle is complete and the answers to these problems...
https://www.searspartsdirect.com/dishwasher-repair/symptom/DISH008.html
https://www.shopyourway.com/questions/1096666
I have attached a video that might help shed some light on this issue.
Hope that helps.
Best wishes. Regards.
Nov 06, 2017 | Maytag MDB7100AWB Dishwasher
ASKO 1595
yes have you tried what i suggested yet
Mar 29, 2008 | Asko D1776 Stainless Steel Built-in...
No power
check the thermal fuse located on electronic control 2 inch square fuse problalby no continuity through it, Replacemant comes with wires attached and instructions for installation
Feb 20, 2008 | KitchenAid KUDR01TJ Dishwasher
Dishwashers Logo
59 people viewed this question
Top Dishwashers Experts
