Question about GE 30 in. JP340 Electric Cooktop
GE Profile cook top - four years old
All elements work, however the power light (RED) will not turn off after we turn off all elements.
this aM, wter was spilled on the top switch nobs, could this be a part of the problem? Is it safe to use?
Thanks for your comments!!
  • 640 Answers
Unplug unit allow to dry ..12 to 24 hours,,or cut breaker to stove,,,try again..if still lite..you ground out,,you have to take a look at light circuit for ground short
Posted on Dec 24, 2008
I don't want to state the obvious, but will anyway: one of the indicators that come on is a heat indicator, not a power indicator, so it will stay on until the top cools to room temperature.
Posted on Apr 01, 2009
How to replace a radiant burner element wb30t10062 on a cook top not a combo, oven and cooktop
Search for my solution for a replacing the element on a JP939/JP969. That should help for similar GE models.
Sep 10, 2011 | GE 30 in. Profile JP939 Electric Cooktop
How to un lock my GE Profile Induction cook top?
Try turning off the breaker for at least 10 min and re apply power. If this doesn't work, then there's an internal problem.
If after 10 minutes the cooktop is STILL locked:
Push the touch pad that looks like a padlock for at least 5 seconds. The lock light should go out.
Nov 15, 2010 | GE Profile JP930 Electric Cooktop
G.E Profile gas cook top #JGP640 ignitor.
It is sparking because the module does not sense the heat which would normally cause the sparking to stop.
It can be caused by a poor ground, make sure the ignitor at that burner is clean and free from any obstructions. If it is then it could either be a defective ignitor or spark module.
Mar 12, 2009 | GE Cooktops
Spark igniter discharging when turned off
Hi
It sounds like somebody clean up the stove and the electric sending unid is wet, try this: the knob that correspond to the ingniter that it's clicking nonestop, take the knob out and you will see the sending unit, pull it out unplug it and dry it out and then try it again, it should work properly after it's dry.
Eddie Rentas
Tupper Lake NY
Jan 11, 2009 | GE 30 in. JGP328 Gas Cooktop
All 4 burners stopped working - circuit breaker ok
How old is this cook top stove? Does it require replacement?
Jun 11, 2017 | GE 30 in. JP385 Electric Cooktop
Both burners turn on when only one is needed
I just had the same problem- when I replaced the whole cartridge.
I repalced the infinite switch- do the one that gets the hottest- or do both.
It is easy to do- just write down the wiring diagram - make sure all power is off- cost of new switch was about $37.00
This solved the problem- however make sure to check the sizng on the new switch shaft as my old knob would not fit properly on the shaft of the new switch.
good luck
Jun 20, 2008 | Jenn-Air JED8230 Electric Cooktop
Ge profile electric counter top stove
I did not receive instructions with my G E Profile cook top Model No. 80030750434). There is a build up on the elements which I am having problems removing. Should the top be scraped while the stove is hot or cold? What is the best cleaning product to use?
May 01, 2008 | GE Profile JP930 Electric Cooktop
One unit show fault code F153
Hi - I've been having the same problem. GE tech service in St. Louis, MO has been a joke. 1st tech call cancelled 30 minutes before appointment. 2nd tech call to diagnose the F153 code I had already provided when I scheduled service on-line cost $74.95 and the tech didn't have the part on his truck. 3rd tech call a new tech shows up, has no knowledge of previous call diagnosis, opens the box sent to my home by GE and announces that the previous guy ordered the wrong part! We're on the 4th call. My cook top right front burner has not worked for a month. I've contacted GE corporate. The part you need (at least I need) for the right front burner which is a large burner is: WB30T10062. If I knew how to, I'd repair this myself. I don't have the extended warranty. The part is covered because my cooktop is only two years old (parts warrantied for five years) but labor is estimated to cost almost $200....plus the $74.95 "diagnostic" visit. A total rip-off. My advice, if you've got this cooktop, it's still under warranty and you aren't using all of the burners on a regular basis: start using them! The tech guy said most people use that front right burner alot and it eventually malfunctions (code F153). His suggestion was to start using the other burners on a regular basis, too, so that when they go out, at least the part will fall under the five-year warranty! When this cook top is done, I'm going to get a gas stove with "old fashioned burners" and it won't be GE!
Sep 24, 2007 | GE 30 in. Profile JP938 Electric Cooktop
GE 30 in. JP340 Electric Cooktop Logo
433 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Dave Harrison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
