Question about Sony DAV-SC8 System
Sony Compact AV System DAV-SC8
I have loaded a music CD into the above unit but I am now unable to reject it. I have experienced this problem before and did manage to release the CD after a lot of button pressing. This time I cannot get it to reject. Can anyone suggest how I can release the CD from the drive. I have tried everything in the manual including powering down and up but it still refuses to reject. The drive has only been used once before as I have an alternative DVD player which I tend to use most of the time
5 Suggested Answers
  • 13 Answers
SOURCE: SONY DAV - S880 compact AV system
Sony.com may have a pdf downloadable manual available on line.
The standard way to connect Audio from a Receiver to a TV is to send a signal from the Tape outputs (RED & WHITE) on receiver via RCA cable to a Aux input (RED & WHITE) on the TV. Likewise, sending a Video signal from a receiver to a TV, is via a Co-Axial RCA cable , using a Video Out (YELLOW) on the receiver to a Aux Video Input (YELLOW) on the TV. An S-Video cable can also be used (in leu of yellow RCA cable) if available on both Receiver & TV.
Posted on Jun 11, 2008
  • 6 Answers
SOURCE: Can Anyone Help me!
Hi there
you can connect this system to your computer in multiple ways. But how you do so depends on what your computer has. If your PC has RCA connections on it then that would be the simplest way but this would leave you with stereo sound. If you have a digital decoder in your computer and a optical out then i would suggest using that. A Optical cable is quite inexpensive and can be bought from pretty much any decent A/V shop.
If you can let me know the model of you PC i can give you exact directions but dont be afraid to play around yourself. I only suggest that you do so carefully.
hope this helps.
Posted on Mar 22, 2009
SuperTech-11
  • 1591 Answers
SOURCE: hi, I have a sony dav-sc8 dvd home theatre system
These are the commands for the DAV-300 but hopefully they are the same for yours...hope it helps.
Region 0 is what you want, but here's all the commands for the 300 which hopefully work on the sc8 as well.
Put your player into "Standby" Mode and enter one of the following commands if
necessary,
: Remote control command Function
: [0] [RETURN] Default Default region code on the player
: [1] [RETURN] Region 1
: [2] [RETURN] Region 2
: [3] [RETURN] Region 3
: [4] [RETURN] Region 4
: [5] [RETURN] Region 5
: [6] [RETURN] Region 6
: [P. MODE] [RETURN] Only play DVD's with the selected region; auto switching
OFF
: [AUDIO] [RETURN] Default Auto switching ON
: [ANGLE] [RETURN] Enable video interference impulses (Macrovision ON)
: [SUBTITLE] [RETURN] Default Disable video interference impulses (Macrovision
OFF)
: [PREV] [RETURN] Enable user operation prohibitions* and access restrictions
: [NEXT] [RETURN] Default Disable user operation prohibitions* and access
restrictions.
Posted on Mar 17, 2011
dunnbiker
  • 8546 Answers
SOURCE: my sony compact av system,model dav-c770 is stuck
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown
Posted on Aug 12, 2011
Out of the blue I turn on my DAV-SC8 and after about 4 seconds the entire unit turns off ... even the red standby button goes out ... it is as though the unit dies. I switch off the wall plug and switch...
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Apr 28, 2011 | Sony DAV-SC8 System
Hi, I have a sony dav-sc8 dvd home theatre system and would likt to know if there is a way to make it multi region
necessary,
OFF
OFF)
restrictions.
Mar 17, 2011 | Sony DAV-SC8 System
I have an error on the display screen which say's protect then the system shuts down it's a Sony DAV-SC8 System
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Feb 15, 2011 | Sony DAV-SC8 System
My powersupply was not power can you get diagram?
Is this any good? http://www.scribd.com/doc/31727539/Sony-Hcd-sc5-Sc6-Sc8-v1-4
Nov 24, 2010 | Sony DAV-SC8 System
Sony DAV-SC8. I'm suddenly getting distortion
It sounds like the speakers themselves are the problem rather than the amp.
Although, it would be rare to have overdriven/blown the surrounds.
My suggestion would be to isolate which speakers or channels (on Amp) are at fault.
Swap left and right to see if the problem transfers across.
Sep 13, 2009 | Sony DAV-SC8 System
Sony DAV-C770 Red Light Flashing but nothing is on!
power supply or power amplifire unit problem.give it to repair proffesional.
nuwan.
Jan 19, 2009 | Sony DAV-C770 System
Installation instructions
Hi
here is a link to download user manual from sony...
http://support.sony-europe.com/hav/ha/hta/dav/dav.aspx?site=odw_en_GB&m=DAV-S400
click on user manual tab and you will see english plus other language versions.
Hope that helps?
Dec 20, 2008 | Sony DAV-S400 System
Picture distortion. Sound fine
Dont worry andysenny, Just give your dvd player for general service, these small problems will be rectified.
Feb 10, 2008 | Sony DAV-SC8 System
Disk Stuck In DVD Machine.
Hi, You need to open the machine or at least the top cover and manually extract the CD. Under the cover and on top of the loading tray is a retaining bar held by 2-4 screws. Removing these would allow you to lift the bar and remove the CD easily. In some models/version, there might be an electronic board partially covering the tray assembly. This type of problem happens when the CD is defective, was not loaded properly, or more than 1 is inside. In some cases, it is the loading mechanism that is at fault. Still in some other models/version there is an access/pin hole below the try at the faceplate where you need to insert a straightened metal paper clip to manually push out the tray. Of course the standard precautions apply, power down, remove from the mains. If you are not comfortable on do-it-yourself, maybe you should seek the services of a qualified professional. good luck and kind regards.
Aug 26, 2007 | Sony DAV-SC8 System
Sony DAV-SC8 System Logo
282 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
