Question about Toshiba Satellite 2435-S255 Notebook
Toshiba 2435 remove top to check buttons
How to open the top to check buttons that are sticking next to touch pad
  • yatesfa Feb 17, 2009
    the key Bord on my Toshiba 2435-s255 is not working properly. some of the keys work but some do not. for example, the "m, d,k " keys takes me out from the software I am working in to the desktop,
    I have tried to attach an external keyboard to it and have the same problem. Any help will be apprecited
    yt
  • 382 Answers
Here is the site I use for Toshiba Laptop Repair. Hope It helps and Have a good day.
http://www.irisvista.com/tech/
Posted on Feb 02, 2009
I need softer toshiba satillite 2435-5255
Posted on Mar 01, 2009
Toshiba satellite 2435-s255 keyboard & touch pad not working, reconnected keyboard cable. reinstalled drives. Still not working. what else to check?
Laptops are a bit trickier to work with. If the keyboard *and* touchpad aren't working, you may have to contact Toshiba for assistance, assuming the product is in warranty.
You may also want to see if an external (USB) keyboard and mouse work.
Aug 01, 2016 | Toshiba Satellite Computers & Internet
Touch pad stopped working on laptop toshiba C855 M29 SATALLITE
Try Shutting down, unplug, remove battery, plug in reboot. Have you done ALL your Windows and Toshiba Updates? You can find a user manual here: http://www.toshiba.co.uk/innovation/download_manuals.jsp
Mar 31, 2013 | Computers & Internet
Touchpad click buttons sticking
Did you waste some sticky soda on the touchpad. Before you try taking the laptop apart just shut the laptop off and repeatedly hit the buttons to try and work them loose from sticking.
If you want to take the touch pad off, you will have to remove the whole palmrest. Get some cups and label them so you will know where the screws you removed go. Also a digital camera might help you. You will start by turning the power off, removing the power cord and battery. The remove the screws from the bottom of the laptop. Remove the memory, the hard drive, the dvd drive. Look inside each one of them and there might be screws to remove especially in the battery compartment. Make sure you look for screws that might have the icon of a keyboard next to it. They secure the keyboard. Then open the lid and remove the strip that is above the keyboard. Be careful because there might be a cable attached to the strip. One the strip above the keyboard is removed, you can remove the keyboard screws and gently lift the keyboard out because there is definitely a cable under it that you will have to remove from the board where it plugs in. Next you will have to remove the screw from the lcd hinge and lift the lcd off. You should be able to just disconnect the lcd cable and have enough room to sit the lcd right behind the base without taking the wifi antennas off. If not you will need to remove the wifi card and antenna from the bottom of the laptop. Next you can pry the palmrest off, but be careful and remove any cables that are plugged in before you remove it. There might also be some screws that hold the palmrest to the motherboard so check for them.
May 12, 2012 | Toshiba Computers & Internet
I had to open the L355d-s7815 Toshiba lap top to replace a broken power connector. The power problem is fixed, however, the touch pad and mouse buttons no longer function and are not recognized by the...
That Floppy Strip connects the touch pad to the motherboard.
Remove the top assembly againg and look specifically at the base of the touch pad, there is a connector that takes the cable. The other end connctes to the motherboard.
If you put it in the wrong way up, it will not damage, just won't work.
Have fun!!
Jan 02, 2011 | Toshiba Satellite L355D-S7815 Notebook
The touch pad, left & right clck buttons.
  • Hi, click on the "Start Button," next in the (right area) click on the "Control Panel." In the window there will be "listings" different categories; choose the "Mouse," from the "Hardware and Sound" click on it to open the next window. Next select the "Device Setting" button, once the window open, click on the "Setting" button just below the"highlighted" TouchPad, or Mouse. The area of your immediate concern is the "Buttons" put a [check] mark into "Enable" buttons. Try out some of the "items listed" Tapping, Virtual Scrolling... "You must click on the "Apply, OK buttons when finished." Note: Restart the computer; this will make sure the changes are correctly applied, and working properly. "Rating the solution will let me know if the problem is fixed, or you will need further assistance, thanks."
Jun 19, 2010 | Toshiba Satellite A135-S4527 Notebook
I have a Toshiba 2435-s255 laptop. I want to add memory. It has (2) 256 PC2100 SODIMM sticks. If I put in (2) 512K PC2700 sticks, will I gain any benifits for the faster speed?
You can put (2) 1 GB sticks in that computer and you would see very, very fast results and the machine will thank you for the upgrade because it will not have to work as hard. Just remember though that you still have the same processor as you did before so if that is the bottleneck in the system, then it will run as fast as the processor allows it. The extra RAM will free up 90% of bottleneck issues.
Oct 11, 2009 | Toshiba Satellite 2435-S255 Notebook
Deactivate the touch pad
Try holding down FN key and F( key. This activated and de-activates the touch pad
Apr 25, 2009 | Toshiba Satellite A20 Satellite A25 Series...
I need to know how to open a Toshiba Satellite 2435-S255
Here is one of the sites I use for Repairing Toshiba Laptops. Hope it helps and have a good day.
Jan 31, 2009 | Toshiba Satellite 2435-S255 Notebook
Whirlpool duet washer model GHW9400PWO
Removing the Washer Top
Three screws secure the washer top at the back of the washer. Remove the three screws and lift the top from the washer.
Removing the Console from the Cabinet
Disconnect the Touch Pad/LED Assembly ribbon connector from the left side of the Central Control Unit and release it from the wiring harness brackets on the right side of the washer top
Remove the detergent dispenser drawer by pressing down on the release tab at the back of the drawer and pulling it completely out of the washer.
Once the drawer is removed, remove the screw in the recessed hole next to the drawer opening. Release the tab securing the right side of the console to the washer
Open the washer door and place a flat-bladed screwdriver into the slot in the bottom center of the console. Push the console up to release center console tab. Be sure the ribbon cable clears the cabinet frame.
Removing the Touch Pad/LED Assembly from the Console
The Touch Pad/LED Assembly is removed as a single unit and contains the Push Buttons, LEDs, cable, etc. The buttons can be replaced separately
Jun 28, 2008 | Whirlpool GHW9400 Duet Washer
Laptop computer cursor
yes, Toshiba models have a function key combination that will disable the built in touch pad, it is next to the function button to enable the external display output.
Oct 01, 2007 | Computers & Internet
Toshiba Satellite 2435-S255 Notebook Logo
264 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
