Question about Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television
Weak audio gets weaker
My over 4-year old 26-inch Sharp LCD LC-26GA4U has worked just fine all these years except for the audio which has always been weak and needed to be turned up almost all the way.
Now I'm hearing "ocean" sound in the background.
I have read from you letters that pulling out cables in the back and putting them back on (sort of rebooting it) may work. Then there are letters that say the problem got worse (audio dissappeared completely) after rebooting.
Before I start pulling........... is there a NO don't do it??
Merry Christmas, Happy Holidays!
    New Friend:
  • 19 Answers
The ocean sound is 'noise' which means a bad connection. Best thing is to unplug & plug back in all cinch & scart etc cables, while turned off, of course. do this a few times for each cable, then turn it on.
Sometimes it is the headphone jack, have you used it recently?
Try plugging & unplugging the headphones quickly a few times, that normally solves the problem.
If you still have a problem then it's internal and the TV needs looking at.
Posted on Apr 22, 2017
  • 208 Answers
SOURCE: Sharp Aquos LC 37D6U
Please be aware that this a big problem on this unit. The insulator material used by sharp to between the IC's on the AV board both on top of the boards and underneath the the AV pcb is failing. This insulator is mounted to the IC and under the metal heat sinc. Remove the back and pull the AV Board out of the unit. Use zylene or alcohol and clean all of the grey insulator from between the pins on the ic and order the replacement insulators from Sharp. Most times this will correct the no sound problem. Sometimes this has also damaged the AV pcb and it will have to be replaced. The parts that should be replaced come in a kit with sharp part # PSPKIT663WHZZ. If the kit is not available the 2 parts needed are PSPAZA663WJKZ AND PRDARA216WJFW.
Posted on Feb 05, 2008
SOURCE: TV No Picture
My 32D40U would turn on for 5-10 seconds (Please Wait would appear) and the screen would go black. Sound Normal. It would also sometimes do this after running 5-10 minutes. I read somewhere that the inverter board would come loose and lose proper ground. I took the set apart, removed the board, and cleaned up the grounding points. I reassembled using some copper paste on the ground points and LockTite on the screws. I used some contact cleaner on all the connectors going to the board. I noticed two cables that are covered with copper shield tape where too tight at their connectors and repositioned the tape to give them some slack. The problem hasn't occurred since the fix.
Posted on Mar 22, 2008
SOURCE: Sharp Aquos LC-26D4U sound problem
i had the same problem lc26d4u. called sharp and they gave me a place to send it to . cost me 260.00 estimate to fix tv. have not heard from them since. but heard they may have sent the tv to the manufacturer. same sound board problem
Posted on Apr 02, 2008
  • 10 Answers
SOURCE: Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Posted on Jan 08, 2009
dsacco86
  • 1077 Answers
SOURCE: Sharp Aquos - switches input modes by itself, only when cold.
I believe your TV needs the latest version software upgrade. The current software may have been corrupted.
There is a USB service port on the side of your TV. You can download the software to a USB memory stick at sharpusa.com then upgrade your TV from the service port.
If any problems doing this, call 1-800-BE-SHARP and they will run through the procedure.
Posted on Apr 01, 2009
I have a Sharp Aquos. A video cable is connected to interface EXT-4. Video is working fine. Which audio interface can |I use to get audio too and what do I have to set in the TV menu?
There should be RCA type audio input connections near the ext-4 video cable. One red and one white. If you connect these cables you won't have to do anything in the menu.
Aug 30, 2011 | Sharp Aquos LC-26GA5E 26 in. HDTV-Ready...
Sharp lc-26dv12u about 2years old. All of a sudden
Sounds like the Main mother board is the problem. When the processor chip overheats, the programming information passing through the chip slows down. Most cases, replacing the main mother board will fix the problem.
Dec 29, 2009 | Sharp LC-26DV12U 26 in. LCD TV/DVD Combo
Sharp aquos no sound through hdmi
Reset all audio factory setting.Tries unplug,replug it well work,if ur backlight video board it still good.
Dec 17, 2009 | Sharp Aquos LC32D41U 32 in. LCD TV
My 32-inch lcd tv from sharp has no picture but audio works fine. No picture ever comes up, not even the "please wait" message. Whats going on?
My 3 year old Sharp LC-40C32U would start up fine but within a minute would go dark (audio continued fine). For a while I could turn the set off and on again and it would be fine, but over time this became less effective. My solution, which has worked for a week now, was to a) unplug the set's power cord; b) after 3 minutes plug it back in and turn the set on; c) on the remote hit MENU and slide over to SETUP (3 clicks to the right if the screen is dark) and one up to RESET; d) hit ENTER and follow the prompts. This puts the set in it's factory configuration so you will have to rescan for channels. Worked for me.
Dec 05, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
LC-32D6U GETTING NO SOUND
Almost all intermittent audio or audio failure problems with Sharp Aquos LC**D4U, LC**D5U, LC**D6U, and LC**D7U televisions are the result of a relatively simple design flaw involving the heatsink pad compound used on the Tripath TA-2024 amplifier chip (IC2502) found on the A/V board. This compound has a fairly low melting point and, over time, tends to seep out from between both top and bottom heatsinks onto the legs of this chip as well as onto circuitry immediately surrounding it. Further, over time the seeping compound also becomes somewhat conductive creating bridges which short the audio amplifier circuit causing everything from intermittent audio to complete audio failure.
Fortunately, in almost every case audio can be completely restored by cleaning the old compound from both top/bottom heatsinks and from both sides of the PC board in the area immediately surrounding the chip (rubbing alcohol works quite well). Despite what the images say,
YOU MUST REMOVE ALL BLACK RESIDUE FROM BOARD. IT WILL NOT WORK IF ALL THE RESIDUE IS NOT REMOVED.
This kit is Sharp Part Number: PSPKIT663WJZZ and is available from Partstore.com for $19.95. http://www.partstore.com/Part/Sharp/Sharp/PSPKIT663WJZZ/New.aspx
It’s possible to get the heat pad only, Sharp Part Number: PSPAZA663WJKZ for only $9.95. http://www.partstore.com/PartSearch.aspx?PartNumber=PSPAZA663WJKZ&hiddenInputToUpdateATBuffer_CommonToolkitScripts=1&x=26&y=14
Jun 21, 2009 | Sharp LC-26D4U 26 in. LCD Television
I lose the sound on my 1 year old SHARP aquos Lc-42D62U tv??
There is a fix for this. Call a Sharp servicer or Sharp electronics the cost of repair is around 200.00 dollars.
Apr 01, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How much is a 1998 26 inch Sharp tv worth?
If it is in good working condtion and looking very clean you may be able to get about $60 to $100 for it. Remember that there are new LCD TV sets that are very low in cost and will out perform your set.
I have seen some 24 inch models on sale for under $250 with a 3 year warranty. And, these sets will work in 16:9, has component inputs, and are packed with features.
In these times, people are trying to get rid of their CRT sets and change for the LCD types.
A 24 inch flat screen TV has about the same viewing as a 25 to 26 inch CRT TV.
Jerry G.
Jan 17, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Tv not working
i have the LC-26GA4U LCD TV & mine has the exact same problem. I brought it to an authorized sharp tv repair shop it turns out its the LCD panel. the panel costs $1700 & with labor installed it comes to $2055.43. almost exactly what I paid for the tv 2 years ago. good luck. Mike
Jul 11, 2007 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television Logo
55 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
